[667] Ability to execute script:/// from Blocky
Laulo7
Target OS: Raspberry Pi
Domoticz version: 3.9030
Re: [667] Ability to execute script:/// from Blocky
Post by Laulo7 » Sunday 18 March 2018 15:46
add "1/" in parameter(s)
It's a long way to the top..
DennisD
Post by DennisD » Sunday 18 March 2018 19:59
Having the same issue, strangely tho was that the scripts did work. If i call them directly in terminal the script (sending a snapshot to my telegram) works flawlessly but when i true to call the script through domoticz nothing happens. I did try changing the url, adding "1/" in the parameters even the space after the script text area. After adding the space or changing the url i get no error msgs but i don't get the script to run
I am running the latest (beta)version 3.9052 but come to think of it i did have it before that build (not sure which one).
tontze
Post by tontze » Sunday 18 March 2018 20:30
Why ? where are you referring to ? To remove # ?
Rpi 3 / Razberry 2
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
ESP82xx
DennisD
Post by DennisD » Sunday 18 March 2018 20:39
If you run the whole path the backspace isn't needed mine is in /home/pi/domoticz/scripts/bash/ and specify it like that and i have no #.
Strange problem with my problem is that the script seems to work partially, since the snapshot is uploaded to the directory which is specified in the script, i how ever don't get a msg via telegram (it does so when i locally call the script)
dnlauto
Post by dnlauto » Sunday 06 May 2018 18:10
Did you ever get this resolved? I have the same issue. Adding "1/" as a parameter does not help for me.
olafmarcos
Domoticz version: 9999
Post by olafmarcos » Monday 27 August 2018 13:40
I'm in the same situation:
2018-08-27 12:54:56.672 Status: Executing script: /usr/local/domoticz/var/scripts/tv_alert.sh#
2018-08-27 12:54:56.682 Error: Error executing script command (/usr/local/domoticz/var/scripts/tv_alert.sh#). returned: 32512
The script runs perfectly from CLI.
For workaround, i add a blankspace and ampersand to send the job to background and it seems to work.
Status: Executing script: /usr/local/domoticz/var/scripts/tv_alert.sh &#
Any advances?
Synology NAS ds215j, DSM 6.2
Domoticz Beta from Jadahl 9999
Z-wave (AEOTEC Aeotec Z-Stick Series GEN5,Fibaro FGRM222, FGS222, FGMS001-ZW5 Motion Sensor+)
Philips Hue Bridge
Nuki Lock Plugin
