Different Backups from Crontab to network
All kinds of 'OS' scripts
sschouten
Re: Different Backups from Crontab to network
Post by sschouten » Monday 19 June 2017 23:51
i found my problem,
i was edtitng the script whit notepad++ but did not chnage to LF now the script is working fine :)
renerene
Post by renerene » Sunday 25 June 2017 20:55
sebitop wrote:2 MB this is the point !
if I directly ave the db from the browser, the file is 2 MB and I can restore it.
if I simply use : /usr/bin/curl http://192.168.0.30:8080/backupdatabase.php > /tmp/test.db
test.db is 91kb .... and impossible to restore it
same here. Any solutions yet?
Derik
Target OS: Raspberry Pi
Post by Derik » Sunday 25 June 2017 23:24
#!/bin/bash
    # LOCAL/FTP/SCP/MAIL PARAMETERS
    SERVER="192.168.6.10"         # IP of Network disk, used for: ftp mail scp
    USERNAME="root"         # FTP username of Network disk used for: ftp mail scp
    PASSWORD="root"               # FTP password of Network disk used for: ftp mail scp
    DESTDIR="/opt/backup"      # used for: local
    DOMO_IP="192.168.6.70"      # Domoticz IP used for all
    DOMO_PORT="8080"         # Domoticz port used for all
    ### END OF USER CONFIGURABLE PARAMETERS
    TIMESTAMP=`/bin/date +%Y%m%d%H%M%S`
    BACKUPFILE="Xu4_Domoticz_DB_$TIMESTAMP.db" # verander  domoticz_xx_  en je backup krijgt deze naam.
    BACKUPFILEGZ="$BACKUPFILE".gz
    ### Create backup and ZIP it
    /usr/bin/curl -s http://$DOMO_IP:$DOMO_PORT/backupdatabase.php > /tmp/$BACKUPFILE
    gzip -9 /tmp/$BACKUPFILE
    ### Send to Network disk through FTP
    curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/media/hdd/Domoticz_backup/"
    ### Remove temp backup file
    /bin/rm /tmp/$BACKUPFILEGZ
    ### Done!
    # noot gebruik zo min mogelijk spaties En zorg dat het adres via filezilla gezien is
try this..
Activate with a crontab
renerene
Post by renerene » Tuesday 04 July 2017 23:14
Derik wrote: try this..
I've compared the code with my own that does not work, looks the same:
(variable DESTDIR is old?)
#!/bin/bash
    SERVER="192.168.0.20"  # IP of Synology NAS, used for ftp
    USERNAME="xxxx"         # FTP username of Network disk used for ftp
    PASSWORD="xxxx"         # FTP password of Network disk used for ftp
    DESTDIR="/opt/backup"   # used for temorarily storage <-- wordt verderop niet gebruikt??
    #DESTDIRNAS="/homes/domoticz/backup/" # Path to your Synology NAS backup folder
    DESTDIRNAS="/domoticz/" # Path to your Synology NAS backup folder
    DOMO_IP="192.168.0.xxx"   # Domoticz IP
    BACKUPFILE="domoticz_$TIMESTAMP.db" # backups will be named "domoticz_YYYYMMDDHHMMSS.db.gz"
    tar -zcvf /tmp/domoticz_scripts_$TIMESTAMP.tar.gz /home/pi/domoticz/scripts/
    #tar -zcvf /tmp/telegram_scripts_$TIMESTAMP.tar.gz /home/pi/tg/scripts/
    curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/$DESTDIRNAS"
    curl -s --disable-epsv -v -T"/tmp/domoticz_scripts_$TIMESTAMP.tar.gz" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/$DESTDIRNAS"
    #curl -s --disable-epsv -v -T"/tmp/telegram_scripts_$TIMESTAMP.tar.gz" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/$DESTDIRNAS"
    /bin/rm /tmp/domoticz_scripts_$TIMESTAMP.tar.gz
    #/bin/rm /tmp/telegram_scripts_$TIMESTAMP.tar.gz
    ### Done!
Derik
Post by Derik » Sunday 27 August 2017 14:43
Dear all...
i have a minecraft server for my kids on a BP1 M2
Running great...
Only they build and build like real miners..
I wil try to make a backup with a loop from a week.
Backup everyday monday / sunday, en then again... [ overwrite teh backups ]
The problem i am a noob...
I still have a script only do not get this working.
setup BPi runs on latest armbian.
i do have a hdd in my network i can reach with ftp etc. [ it is a HDD in satellite receiver, from lan with direct acces, with ftp i need root root to login ]
And the route to it:
\\ET9X00\Harddisk\minecraft
I created on that hdd a map minecraft where i try to place the backups.
The script i use:
#!/bin/sh
# Backup minecraft world to a
# specified folder.
# What to backup.  Name of minecraft folder
backup_files="minecraft"
# Where to backup to. I backup to an external hd connected
# to my Pi.  enter the folder name where you want your backups to go.
# Just make sure you have enough space to hold 7 days of backups. This
# can be on the pi itself, to an external hard drive or mounted network share.
dest="/et9x00/media/hdd/minecraft"
# Create backup archive filename.
day=$(date +%A)
archive_file="$day-$backup_files-.tar.gz"
# Backup the files using tar.
cd /root && tar zcvf $dest/$archive_file $backup_files
From a Minecraft site.....
The problem this script is not working :-)
Is there perhaps a option that i can run a script from Domoticz
To make a backup from my Bpi to the hdd in my network..
Hope some one can/will help me this script..
I am a noob, in scripting....
Thanks from my kids..... [ And there friends..:-) ]
Derik
Post by Derik » Friday 08 September 2017 8:11
did install domoticz on the Bpi... En can make a daily backup like i did with the domoticz map.
So works fine....
Only is there perhaps a option to remove automatically a backup from my backup hdd.
Or a overwrite option?
Like i make a weakly backup that is overwrite after 4 weeks
astrapowerrr
Post by astrapowerrr » Thursday 28 December 2017 23:19
hi
i have trouble with the script can someone help me??
#!/bin/bash
    SERVER="192.168.1.100"  # IP of Synology NAS, used for ftp
    USERNAME="Marco"         # FTP username of Network disk used for ftp
    PASSWORD="XXXX"         # FTP password of Network disk used for ftp
    DESTDIRNAS="ftp://openmediavault.local/cfs_share02/domoticz_backup" # Path to your Synology NAS backup folder
    DOMO_IP="192.168.1.101"   # Domoticz IP
    ### Done!
i get this error??
pi@raspberrypi:~ $ sudo /home/pi/domoticz/scripts/domoticz_backup.sh
tar: Leidende '/' wordt uit lidnamen weggelaten
/home/pi/domoticz/scripts/python/
/home/pi/domoticz/scripts/python/googlepubsub.py
/home/pi/domoticz/scripts/python/domoticz.py
/home/pi/domoticz/scripts/python/script_device_PIRsmarter.py
/home/pi/domoticz/scripts/python/reloader.py
/home/pi/domoticz/scripts/python/__pycache__/
/home/pi/domoticz/scripts/python/__pycache__/domoticz.cpython-34.pyc
/home/pi/domoticz/scripts/python/__pycache__/reloader.cpython-34.pyc
/home/pi/domoticz/scripts/python/script_time_demo.py
/home/pi/domoticz/scripts/python/script_device_demo.py
/home/pi/domoticz/scripts/lua_parsers/
/home/pi/domoticz/scripts/lua_parsers/example_json.lua
/home/pi/domoticz/scripts/lua_parsers/example_xml.lua
/home/pi/domoticz/scripts/lua_parsers/example_owm.lua
/home/pi/domoticz/scripts/lua_parsers/example.lua
/home/pi/domoticz/scripts/logrotate/
/home/pi/domoticz/scripts/logrotate/domoticz
/home/pi/domoticz/scripts/readme.txt
/home/pi/domoticz/scripts/buienradar_rain_example.pl
/home/pi/domoticz/scripts/templates/
/home/pi/domoticz/scripts/templates/Device.Lua
/home/pi/domoticz/scripts/templates/All.Lua
/home/pi/domoticz/scripts/templates/global_data.dzVents
/home/pi/domoticz/scripts/templates/Time.Lua
/home/pi/domoticz/scripts/templates/Seurity.dzVents
/home/pi/domoticz/scripts/templates/All.dzVents
/home/pi/domoticz/scripts/templates/UserVariable.dzVents
/home/pi/domoticz/scripts/templates/Device.dzVents
/home/pi/domoticz/scripts/templates/Security.Lua
/home/pi/domoticz/scripts/templates/Bare.dzVents
/home/pi/domoticz/scripts/templates/Timer.dzvents
/home/pi/domoticz/scripts/templates/All.Python
/home/pi/domoticz/scripts/templates/UserVariable.Lua
/home/pi/domoticz/scripts/lua/
/home/pi/domoticz/scripts/lua/JSON.lua
/home/pi/domoticz/scripts/lua/script_device_sensorWU.lua
/home/pi/domoticz/scripts/lua/script_time_demo.lua
/home/pi/domoticz/scripts/lua/script_device_demo.lua
/home/pi/domoticz/scripts/lua/script_time_toonselector.lua
/home/pi/domoticz/scripts/dzVents/
/home/pi/domoticz/scripts/dzVents/data/
/home/pi/domoticz/scripts/dzVents/data/README.md
/home/pi/domoticz/scripts/dzVents/.gitignore
/home/pi/domoticz/scripts/dzVents/documentation/
/home/pi/domoticz/scripts/dzVents/documentation/dzvents-smoothing.png
/home/pi/domoticz/scripts/dzVents/documentation/history.md
/home/pi/domoticz/scripts/dzVents/documentation/README.md
/home/pi/domoticz/scripts/dzVents/documentation/pandoc.md
/home/pi/domoticz/scripts/dzVents/documentation/README.wiki
/home/pi/domoticz/scripts/dzVents/generated_scripts/
/home/pi/domoticz/scripts/dzVents/generated_scripts/README.md
/home/pi/domoticz/scripts/dzVents/runtime/
/home/pi/domoticz/scripts/dzVents/runtime/Device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/temperature_humidity_barometer_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/soilmoisture_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/zone_heating_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/opentherm_gateway_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/scene_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/leafwetness_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/gas_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/p1_smartmeter_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/barometer_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/lux_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/temperature_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/scaleweight_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/group_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/percentage_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/generic_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/ampere_1_phase_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/voltage_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/evohome_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/solar_radiation_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/distance_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/pressure_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/ampere_3_phase_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/security_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/wind_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/zwave_thermostat_mode_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/kodi_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/thermostat_setpoint_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/airquality_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/Adapters.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/custom_sensor_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/alert_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/rain_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/uv_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/temperature_humidity_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/electric_usage_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/waterflow_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/text_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/switch_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/soundlevel_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/kwh_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/visibility_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/counter_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/humidity_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/device-adapters/rgbw_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/Time.lua
/home/pi/domoticz/scripts/dzVents/runtime/todo.md
/home/pi/domoticz/scripts/dzVents/runtime/Domoticz.lua
/home/pi/domoticz/scripts/dzVents/runtime/Utils.lua
/home/pi/domoticz/scripts/dzVents/runtime/TimedCommand.lua
/home/pi/domoticz/scripts/dzVents/runtime/persistence.lua
/home/pi/domoticz/scripts/dzVents/runtime/Variable.lua
/home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
/home/pi/domoticz/scripts/dzVents/runtime/misc/
/home/pi/domoticz/scripts/dzVents/runtime/misc/smoothing.xlsx
/home/pi/domoticz/scripts/dzVents/runtime/HistoricalStorage.lua
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/testIntegration.lua
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/varString.lua
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/secArmedAway.lua
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/stage1.lua
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/vdSwitchDimmer.lua
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/README.md
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/File.lua
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/global_data.lua
/home/pi/domoticz/scripts/dzVents/runtime/integration-tests/stage2.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/
/home/pi/domoticz/scripts/dzVents/runtime/tests/testUtils.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/testTime.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/data/
/home/pi/domoticz/scripts/dzVents/runtime/tests/data/README.md
/home/pi/domoticz/scripts/dzVents/runtime/tests/testDevice.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/testVariable.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/testScriptdzVentsDispatching.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/testTimedCommand.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/.luacov
/home/pi/domoticz/scripts/dzVents/runtime/tests/generated_scripts/
/home/pi/domoticz/scripts/dzVents/runtime/tests/generated_scripts/internal1.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/generated_scripts/internal2.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scandir/
/home/pi/domoticz/scripts/dzVents/runtime/tests/scandir/.f3.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scandir/f1.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scandir/f1lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scandir/f2.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scandir/.f3.lua.swp
/home/pi/domoticz/scripts/dzVents/runtime/tests/scandir/lua.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scandir/f3.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/testEventHelpers.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/tstData.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/README.md
/home/pi/domoticz/scripts/dzVents/runtime/tests/testEventHelpersStorage.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script1.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_wildcard1.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_with_time-contrained_device.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_timer_classic.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_inactive.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_variable2.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_incomplete_missing_on.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_notable.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script5.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_timer_table.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_variable1.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script6.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_timer_single.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script7.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script3.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script4.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_incomplete_missing_execute.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script2.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_logging.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/global_data.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_security.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_error.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_data.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_variable3.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_with_active_method.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_security_grouped.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_wildcard2.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_combined.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/scripts/script_timer_function.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/testfile
/home/pi/domoticz/scripts/dzVents/runtime/tests/devices.lua
/home/pi/domoticz/scripts/dzVents/runtime/tests/testDomoticz.lua
/home/pi/domoticz/scripts/dzVents/runtime/EventHelpers.lua
/home/pi/domoticz/scripts/dzVents/examples/
/home/pi/domoticz/scripts/dzVents/examples/notify for dead system-alive check devices.lua
/home/pi/domoticz/scripts/dzVents/examples/intruder alert.lua
/home/pi/domoticz/scripts/dzVents/examples/random night light.lua
/home/pi/domoticz/scripts/dzVents/examples/fake presence.lua
/home/pi/domoticz/scripts/dzVents/examples/garage door.lua
/home/pi/domoticz/scripts/dzVents/examples/check dead devices.lua
/home/pi/domoticz/scripts/dzVents/examples/external_light.lua
/home/pi/domoticz/scripts/dzVents/examples/respond to switch.lua
/home/pi/domoticz/scripts/dzVents/examples/check dead devices by desc.lua
/home/pi/domoticz/scripts/dzVents/examples/templates/
/home/pi/domoticz/scripts/dzVents/examples/templates/bare.lua
/home/pi/domoticz/scripts/dzVents/examples/templates/variable.lua
/home/pi/domoticz/scripts/dzVents/examples/templates/complete.lua
/home/pi/domoticz/scripts/dzVents/examples/templates/timer.lua
/home/pi/domoticz/scripts/dzVents/examples/templates/device.lua
/home/pi/domoticz/scripts/dzVents/examples/templates/global_data.lua
/home/pi/domoticz/scripts/dzVents/examples/templates/security.lua
/home/pi/domoticz/scripts/dzVents/examples/check battery levels.lua
/home/pi/domoticz/scripts/dzVents/examples/schedule fish pond pump.lua
/home/pi/domoticz/scripts/dzVents/examples/leak_detection.lua
/home/pi/domoticz/scripts/dzVents/examples/only run script when button pressed.lua
/home/pi/domoticz/scripts/dzVents/examples/calc temp delta.lua
/home/pi/domoticz/scripts/dzVents/examples/simple room heating with hysteresis control.lua
/home/pi/domoticz/scripts/dzVents/examples/get sensor values.lua
/home/pi/domoticz/scripts/dzVents/scripts/
/home/pi/domoticz/scripts/dzVents/scripts/README.md
/home/pi/domoticz/scripts/_domoticz_main.bat
/home/pi/domoticz/scripts/restart_domoticz
/home/pi/domoticz/scripts/update_domoticz
/home/pi/domoticz/scripts/script_time_toonselector.lua
/home/pi/domoticz/scripts/download_update.sh
tar: /home/pi/tg/scripts: Functie stat() is mislukt: Bestand of map bestaat niet
tar: Gestopt in fouttoestand vanwege eerdere fouten
* Hostname was NOT found in DNS cache
*   Trying 192.168.1.100...
* Connected to 192.168.1.100 (192.168.1.100) port 21 (#0)
< 220 ProFTPD 1.3.5 Server ready.
> USER Marco
< 331 Password required for Marco
> PASS XXXX
< 230-Welcome user Marco@192.168.1.101 to 127.0.1.1 FTP server.
< 230-The local time is: Thu Dec 28 22:15:02 2017
< 230 User Marco logged in
> PWD
< 257 "/" is the current directory
* Entry path is '/'
> CWD ftp:
* ftp_perform ends with SECONDARY: 0
< 550 ftp:: Bestand of map bestaat niet
* Server denied you to change to the given directory
* Uploaded unaligned file size (0 out of 587074 bytes)
* Connection #0 to host 192.168.1.100 left intact
> USER Marco
> PASS XXXX
> PWD
* Entry path is '/'
> CWD ftp:
* Uploaded unaligned file size (0 out of 226393 bytes)
> USER Marco
> PASS XXXX
> PWD
* Entry path is '/'
> CWD ftp:
* Uploaded unaligned file size (0 out of 45 bytes)
pi@raspberrypi:~ $
changed password to xxxx
if there needs to be more info please ask...
is my second script ever i started trough the wiki page so...
greets marco
jvdz
Domoticz version: Stable
Post by jvdz » Thursday 28 December 2017 23:26
It looks to me that this variable must have the worng path:
as it is used in this FTP command:
so the last part: "ftp://$SERVER/$DESTDIRNAS" translates to:
"ftp://192.168.1.100/ftp://openmediavaul ... icz_backup"
Catch my drift? :-)
Jos
astrapowerrr
Post by astrapowerrr » Friday 29 December 2017 8:28
This script is Copied straight out of the domoticz wiki!!
So it isn’t correct in the wiki I may assume??
I will try to change today and see what happens
astrapowerrr
Post by astrapowerrr » Friday 29 December 2017 9:15
Tried with
#!/bin/bash
curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "$DESTDIRNAS"
curl -s --disable-epsv -v -T"/tmp/domoticz_scripts_$TIMESTAMP.tar.gz" -u"$USERNAME:$PASSWORD" "$DESTDIRNAS"
curl -s --disable-epsv -v -T"/tmp/telegram_scripts_$TIMESTAMP.tar.gz" -u"$USERNAME:$PASSWORD" "$DESTDIRNAS"
### Done!
Now I get this error.
* Connected to openmediavault.local (192.168.1.100) port 21 (#0)
> USER Marco
> PASS xxxx
< 230-The local time is: Fri Dec 29 08:06:36 2017
> PWD
* Entry path is '/'
> CWD cfs_share02
< 250 CWD command successful
> PASV
* Connect data stream passively
< 227 Entering Passive Mode (192,168,1,100,228,220).
* Connecting to 192.168.1.100 (192.168.1.100) port 58588
> TYPE I
< 200 Type set to I
> STOR domoticz_backup
< 550 domoticz_backup: Not a regular file
* Failed FTP upload: 550
* Remembering we are in dir "cfs_share02/"
* Uploaded unaligned file size (0 out of 581699 bytes)
* Connection #0 to host openmediavault.local left intact
> USER Marco
> PASS xxxx
> PWD
* Entry path is '/'
> CWD cfs_share02
> PASV
< 227 Entering Passive Mode (192,168,1,100,229,195).
* Connecting to 192.168.1.100 (192.168.1.100) port 58819
> TYPE I
< 200 Type set to I
* Uploaded unaligned file size (0 out of 226385 bytes)
> USER Marco
> PASS xxxx
> PWD
* Entry path is '/'
> CWD cfs_share02
> PASV
< 227 Entering Passive Mode (192,168,1,100,227,101).
* Connecting to 192.168.1.100 (192.168.1.100) port 58213
> TYPE I
< 200 Type set to I
Derik
Post by Derik » Friday 29 December 2017 11:56
mmm: i see 100 and 101 for domoticz ip?
jvdz
Post by jvdz » Friday 29 December 2017 12:37
Couple of things here:
It looks like this directory doesn't exists:
These errors likely come from the fact that the target directory doesn't end with a slash (/):
So this line should be:
DESTDIRNAS="ftp://openmediavault.local/cfs_share02/domoticz_backup/" # Path to your Synology NAS backup folder
Jos
astrapowerrr
Post by astrapowerrr » Friday 29 December 2017 14:22
So this should be correct now?
> USER Marco
> PASS xxxx
< 230-The local time is: Fri Dec 29 13:19:43 2017
> PWD
* Entry path is '/'
> CWD cfs_share02
> CWD domoticz_backup
> PASV
< 227 Entering Passive Mode (192,168,1,100,226,240).
* Connecting to 192.168.1.100 (192.168.1.100) port 58096
> TYPE I
< 200 Type set to I
> STOR domoticz_20171229131837.db.gz
< 150 Opening BINARY mode data connection for domoticz_20171229131837.db.gz
} [data not shown]
* We are completely uploaded and fine
* Remembering we are in dir "cfs_share02/domoticz_backup/"
< 226 Transfer complete
> USER Marco
> PASS xxxx
< 230-The local time is: Fri Dec 29 13:19:44 2017
> PWD
* Entry path is '/'
> CWD cfs_share02
> CWD domoticz_backup
> PASV
< 227 Entering Passive Mode (192,168,1,100,201,214).
* Connecting to 192.168.1.100 (192.168.1.100) port 51670
> TYPE I
< 200 Type set to I
> STOR domoticz_scripts_20171229131837.tar.gz
< 150 Opening BINARY mode data connection for domoticz_scripts_20171229131837.tar.gz
} [data not shown]
jvdz
Post by jvdz » Friday 29 December 2017 14:30
-snip-
> USER Marco
-snip-
< 200 Type set to I
} [data not shown]
> USER Marco
-snip-
> TYPE I
< 200 Type set to I
} [data not shown]
Think your are the only one that can confirm whether it worked fine by checking the NAS, but the log states it successfully uploaded 2 files. ;)
Jos
astrapowerrr
Post by astrapowerrr » Friday 29 December 2017 14:40
I can confirm that is is sending files to the nas!!
so i am happy! yeejj
thanks all for the good help here!
and a happy 2018...!!
Erwin92
Post by Erwin92 » Friday 19 January 2018 14:07
Hi everyone,
I'm using the back-up script for a few months now, to make a back-up of domoticz every night a send it to my nas.
Making the back-up, and put it on the nas works fine, but I received a error with the extension of automated pruning.
The error occurred says line 46: dirlist: acces denied.
Schermafbeelding 2018-01-19 om 13.04.50.png (18.95 KiB) Viewed 1818 times
But the domoticz user, has full rights for acces the directory.
Schermafbeelding 2018-01-19 om 13.06.00.png (58.21 KiB) Viewed 1818 times
Can someone help me?
dennis075
Post by dennis075 » Saturday 20 January 2018 13:18
Hello all,
First time here on the forum so feedback is welcome if you are missing information :).
I want to use the backup function since my SD card went corrupt a few days ago. Starting all over but first want to have a decent backup just in case..
Now I have a problem with the backup script from the wiki. Code is:
#!/bin/bash
    ## LOCAL/FTP/SCP/MAIL PARAMETERS
    SERVER="ftp://192.168.1.150:21"         # IP of Network disk, used for: ftp mail scp
    USERNAME="xx"         # FTP username of Network disk used for: ftp mail scp
    PASSWORD="xx"               # FTP password of Network disk used for: ftp mail scp
    DOMO_IP="192.168.1.22"      # Domoticz IP used for all
    BACKUPFILEDIR="domoticz_$TIMESTAMP.tar.gz" # Change the xxx to yours
    tar -zcvf /tmp/$BACKUPFILEDIR /home/pi/domoticz/scripts/   # Change the xxx to yours    # Or try /home/pi/domoticz/
    curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEDIR" -u"$USERNAME:$PASSWORD" "ftp://192.168.1.150/Dennis/Backup/RPi/domoticz/"  # Change the ftp to yours !!!
    /bin/rm /tmp/$BACKUPFILEDIR
    ### Done!]
where xx is replaced ofcourse. When running the script I got the following error:
* Trying 192.168.1.150...
* TCP_NODELAY set
* Connected to 192.168.1.150 (192.168.1.150) port 21 (#0)
< 220 ProFTPD 1.3.4a Server (ProFTPD) [46.129.119.45]
> USER xx
< 331 Password required for admin
> PASS xx
< 230 User admin logged in
> PWD
* Entry path is '/'
> CWD Dennis
> CWD Backup
> CWD RPi
> CWD domoticz
> PASV
< 227 Entering Passive Mode (46,129,119,45,217,4).
* Trying 46.129.119.45...
* TCP_NODELAY set
* Connecting to 46.129.119.45 (46.129.119.45) port 55556
* connect to 46.129.119.45 port 21 failed: Connection timed out
* Failed to connect to 192.168.1.150 port 21: Connection timed out
* Closing connection 0
The only thing I see is the IP adress from proftpd looks like an external adress. Any suggestions to fix this?
jerry
Post by jerry » Monday 26 February 2018 22:03
Have you tried my solution? Simply write backups to a fileshare on your NAS:
viewtopic.php?f=63&t=20229
Works like a charm. No FTP needed.
jannl
Post by jannl » Thursday 01 March 2018 8:27
I recently saw the same error on this forum. It has something to do withe the active passive setting of ftp. Please search.
DAVIZINHO
Post by DAVIZINHO » Saturday 19 May 2018 16:56
hello.
I use this method and works great. i make a backup of various folders in my nas, every day
The problem for me is in the part of script to delete de files with XX days:
# get directory listing from remote source
echo "
cd $putdir
ls -l
"|$ftpsite >dirlist
the return to me:
Host key verification failed.
Couldn't read packet: Connection reset by peer
any idea?
