Gigaset Elements Cli - domoticz support
Dlanor
Target OS: Raspberry Pi
Re: Gigaset Elements Cli - domoticz support
Post by Dlanor » Saturday 23 June 2018 22:07
Great work! I am trying to get it start on boot but cannot get it working. Any advice?
Domoticz | Dashticz V2 | Raspberry Pi | RFXCOM RFXtrx433E USB | RFlink 433Mhz | SONOFF
dynasticorpheus
Domoticz version: 2.3295
Post by dynasticorpheus » Monday 25 June 2018 9:04
First thing that comes to mind is you try to start the cli as root during early phase of startup and it therefore can't find the config file. Easily solved by setting the config file location explicitly but please note it's bad practice to run stuff under root if not strictly needed hence not advisable.
--config
Can you enable logging and share the output? (remove sensitive information)
--log /tmp/gigasetelements-cli.log
Husker84
Post by Husker84 » Friday 13 July 2018 16:35
Someone knows why I'm getting this error
[-] HTTP ERROR        | 400      | Bad Request /identity/api/v1/user/login
when running
gigasetelements-cli -u email@email.email -p password -m home
I'm using latest version on github, upgraded with
pip install --upgrade https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
dynasticorpheus
Post by dynasticorpheus » Monday 16 July 2018 14:54
when running
Sure you are using correct email and/or password? I have no issues and only get 400 ERROR when using wrong password hence asking
Users browsing this forum: fremar and 1 guest
