Support for the Resol VBUS protocol?
bbqkees
Domoticz version: 3.8x
Re: Support for the Resol VBUS protocol?
Post by bbqkees » Monday 04 June 2018 16:05
Likely yes.
have you tried any other sketch that sends data to the serial port so you know that works anyway?
Intel NUC-> Philips Hue, Aeon Zwave stick V2, Qubino, Fibaro, Everspring, Philio, RFXCom, X10, Harmony Hub, Xiaomi Flora + Gateway, BS440. And P1 / Resol VBus / Nefit EMS bus / DHT21 / DS18B20 / Sonoff / I2C display, all via Arduino/ESP8266.
Wass1
Post by Wass1 » Tuesday 05 June 2018 13:47
No I haven't can you enlighten me about this feature ?? what kind of sketch ??
Wass1
Post by Wass1 » Tuesday 05 June 2018 16:04
Hello
Finaly i am getting data from my circuit the problem was the cable connecting my resol regulator to the circuit , everything is working fine now... :D :D :D but if you don't mind me asking do you have any idea on how to store this data on a SD card ??
Bernoo
Target OS: Raspberry Pi
Domoticz version: 4.97
Re: Support for the Resol VBUS USB Adapter?
Post by Bernoo » Sunday 22 July 2018 22:09
i have a Resol BX controller and a VBUS to USB adapter and i would like to display the temperatures with domoticz. did anyone else do this before? I do not know how.
Grettings Bernoo
don't drink whisky without water and don't drink water without whisky...
mrccore
Domoticz version: 3.5877
Post by mrccore » Wednesday 25 July 2018 22:39
Hi.
I have build the vbus sensor and connected it to arduino mega that is using a wiznet w5100.
On serial console i can see that my setup is workin OK, i get the values from my DeltaSol C 0x4212 heres a debug info:
Destination: 10
Source: 4212
Protocol Version: 1
Command: 100
Framecount: 7
Checksum: 3
Now decoding for DeltaSol C 0x4212
------Decoded VBus data------
Destination: 10
Source: 4212
Protocol Version: 1
Command: 100
Framecount: 7
Checksum: 3
------Values------
Sensor 1: 24.30
Sensor 2: 35.70
Sensor 3: 50.40
Sensor 4: 0.00
Relay 1: 0
Relay 2: 0
0
------END------
My problem is that i cant get any data to be display in my domoticz server.
I can ping the mega on my network but no data on my domoticz server.
Can anyone help me out on this problem
This is the ethernet shield i have on my mega:
And here's the link to protoboard i have build:
https://1drv.ms/u/s!ADyQTNUUw6kNgoUt
https://1drv.ms/u/s!ADyQTNUUw6kNgoUs
bbqkees
Post by bbqkees » Thursday 26 July 2018 9:31
First make sure that you have chosen a proper IP address and a unique mac address.
Then make sure both the Arduino and the machine running Domoticz are on the same subnet (so f.i. 192.168.1.x).
If there two devices with the same IP address then it won't work.
A good next step would be to modify the sketch such that it only sends a dummy httpRequestTemp(IDX, value) so you know that works as well.
Wass1
Post by Wass1 » Sunday 09 September 2018 18:29
Dear programers
I have built my own dattaloger for vbus resol, using the vbus library, it worked fine with the Resol DeltaSol C4 and Resol DeltaSol BS , but using the same code and library for the Resol Delta Sol E generated many errors , and i can't seem to figure out why any suggestions ??
Wass1
Post by Wass1 » Wednesday 12 September 2018 11:11
Help please i m still getting the same error values any suggestions ??
Users browsing this forum: Bing [Bot] and 3 guests
