Support for the Resol VBUS protocol?
bbqkees
Domoticz version: 3.8x
Re: Support for the Resol VBUS protocol?
Post by bbqkees » Monday 04 June 2018 16:05
Likely yes.
have you tried any other sketch that sends data to the serial port so you know that works anyway?
Intel NUC-> Philips Hue, Aeon Zwave stick V2, Qubino, Fibaro, Everspring, Philio, RFXCom, X10, Harmony Hub, Xiaomi Flora + Gateway, BS440. And P1 / Resol VBus / Nefit EMS bus / DHT21 / DS18B20 / Sonoff / I2C display, all via Arduino/ESP8266.
Wass1
Post by Wass1 » Tuesday 05 June 2018 13:47
No I haven't can you enlighten me about this feature ?? what kind of sketch ??
Wass1
Post by Wass1 » Tuesday 05 June 2018 16:04
Hello
Finaly i am getting data from my circuit the problem was the cable connecting my resol regulator to the circuit , everything is working fine now... :D :D :D but if you don't mind me asking do you have any idea on how to store this data on a SD card ??
Bernoo
Target OS: Raspberry Pi
Domoticz version: 4.97
Re: Support for the Resol VBUS USB Adapter?
Post by Bernoo » Sunday 22 July 2018 22:09
i have a Resol BX controller and a VBUS to USB adapter and i would like to display the temperatures with domoticz. did anyone else do this before? I do not know how.
Grettings Bernoo
don't drink whisky without water and don't drink water without whisky...
mrccore
Domoticz version: 3.5877
Post by mrccore » Wednesday 25 July 2018 22:39
Hi.
I have build the vbus sensor and connected it to arduino mega that is using a wiznet w5100.
On serial console i can see that my setup is workin OK, i get the values from my DeltaSol C 0x4212 heres a debug info:
Destination: 10
Source: 4212
Protocol Version: 1
Command: 100
Framecount: 7
Checksum: 3
Now decoding for DeltaSol C 0x4212
------Decoded VBus data------
Destination: 10
Source: 4212
Protocol Version: 1
Command: 100
Framecount: 7
Checksum: 3
------Values------
Sensor 1: 24.30
Sensor 2: 35.70
Sensor 3: 50.40
Sensor 4: 0.00
Relay 1: 0
Relay 2: 0
0
------END------
My problem is that i cant get any data to be display in my domoticz server.
I can ping the mega on my network but no data on my domoticz server.
Can anyone help me out on this problem
This is the ethernet shield i have on my mega:
And here's the link to protoboard i have build:
https://1drv.ms/u/s!ADyQTNUUw6kNgoUt
https://1drv.ms/u/s!ADyQTNUUw6kNgoUs
bbqkees
Post by bbqkees » Thursday 26 July 2018 9:31
First make sure that you have chosen a proper IP address and a unique mac address.
Then make sure both the Arduino and the machine running Domoticz are on the same subnet (so f.i. 192.168.1.x).
If there two devices with the same IP address then it won't work.
A good next step would be to modify the sketch such that it only sends a dummy httpRequestTemp(IDX, value) so you know that works as well.
Wass1
Post by Wass1 » Sunday 09 September 2018 18:29
Dear programers
I have built my own dattaloger for vbus resol, using the vbus library, it worked fine with the Resol DeltaSol C4 and Resol DeltaSol BS , but using the same code and library for the Resol Delta Sol E generated many errors , and i can't seem to figure out why any suggestions ??
Wass1
Post by Wass1 » Wednesday 12 September 2018 11:11
Help please i m still getting the same error values any suggestions ??
bramv
Domoticz version: 4.10228
Post by bramv » Friday 23 November 2018 22:24
I didn't want to connect an Arduino to my Resol SLT because it already has a LAN interface.
This is how I connected my Resol device to Domoticz by using vbus over lan with Node Red and MQTT.
It should work with other vbus devices as well
1) install Resol library from https://github.com/danielwippermann/resol-vbus
npm install --save resol-vbus
2)
git clone https://github.com/danielwippermann/resol-vbus.git
cd resol-vbus
npm install
3) install /compile json live data server
See: https://github.com/danielwippermann/res ... ata-server
cd /resol-vbus/examples/json-live-data-server
copy config.js.example to config.js
nano config.js
Change your ip and password
<code>
/*! resol-vbus | Copyright (c) 2013-2018, Daniel Wippermann | MIT license */
'use strict';
var path = require('path');
var config = {
* The port number for the HTTP server to listen to.
* @type {Number}
httpPort: 3333,
* The inteval in milliseconds between two writes of the logging file.
* @type {Number}
loggingInterval: 10000,
* The filename of the logging file.
* @type {String}
loggingFilename: path.resolve(__dirname, 'live-data.json'),
* The name of the `Connection` subclass to use for connecting to the VBus.
* @type {String}
connectionClassName: 'TcpConnection',
connectionOptions: {
* The host name / IP address of the VBus/LAN or Datalogger device.
* @type {String}
host: '192.168.178.41',
* The password for the VBus/LAN or Datalogger device.
* @type {String}
password: 'vbus',
</code>
4) Check if web server works
Start live data server:
sudo node resol-vbus/examples/json-live-data-server/index.js
Open page in browser: http://192.168.178.32:3333/api/v1/live-data/
Should look like
<code>
"id": "00_0010_1001_10_0100_000_4_0",
"name": "System date",
"rawValue": 564698061
"id": "00_0010_1001_10_0100_004_2_0",
"name": "Temperature sensor 1",
"rawValue": 12
"id": "00_0010_1001_10_0100_006_2_0",
"name": "Temperature sensor 2",
"rawValue": 23
etc.
</code>
6) Automatic start up the live data server
crontab -e
add following line
@reboot sudo node resol-vbus/examples/json-live-data-server/index.js
7)
Add couple of dummy/virtual devices.
I used 5 temperature, one counter device for the PWM pump and one switch for the heating assistant valve
The idx's of these sensors must be used later.
8) Import in Node red
<code>
[{"id":"22d84f5c.31346","type":"inject","z":"e8a6bafb.256b68","name":"GetSensorData","topic":"","payload":"","payloadType":"date","repeat":"60","crontab":"","once":false,"onceDelay":0.1,"x":114.10685729980469,"y":679.4766540527344,"wires":[["b07b8430.15cc68"]]},{"id":"b07b8430.15cc68","type":"http request","z":"e8a6bafb.256b68","name":"","method":"GET","ret":"txt","url":"http://192.168.178.32:3333/api/v1/live- ... 032,"wires":[["31962303.00ff2c"]]},{"id":"31962303.00ff2c","type":"json","z":"e8a6bafb.256b68","name":"","property":"payload","action":"","pretty":true,"x":451.1042823791504,"y":680.0079431533813,"wires":[["5d661853.27cd68"]]},{"id":"5d661853.27cd68","type":"function","z":"e8a6bafb.256b68","name":"FilterVBUSSensors","func":"var idlist = [\n \"004\",\n \"006\",\n \"008\",\n \"010\",\n \"012\",\n \"030\",\n \"031\"\n ];\n\ni=0;\ndo {\n id= msg.payload.id.substr(21, 3);\n if(idlist.indexOf(id)==-1){\n msg.payload.id=id;\n msg.payload.splice(i,1);\n } else\n {\n msg.payload.id=id;\n i++;\n }\n} while (i<msg.payload.length)\n\nreturn msg;","outputs":1,"noerr":0,"x":616.0990600585938,"y":681.086109161377,"wires":[["1688f22d.03186e"]]},{"id":"1688f22d.03186e","type":"split","z":"e8a6bafb.256b68","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":798.0963096618652,"y":681.1616096496582,"wires":[["b12163cd.79176"]]},{"id":"b12163cd.79176","type":"function","z":"e8a6bafb.256b68","name":"IdentifySensor","func":"var devices = [\n [\"004\",1987], \n [\"006\",1988],\n [\"008\",1989],\n [\"010\",1990],\n [\"012\",1991],\n [\"030\",1992],\n [\"031\",1993]\n ]\n \nsensid=msg.payload.id;\n\nfor (i = 0; i < devices.length; i++) {\n if(sensid==devices[0]){\n msg.payload.idx=devices[1];\n msg.payload.svalue=msg.payload.rawValue.toString();\n }\n if(sensid==\"031\"){\n msg.payload.nvalue = 0 ;\n if(msg.payload.rawValue>0){\n msg.payload.switchcmd=\"On\";\n } else {\n msg.payload.switchcmd=\"Off\";\n }\n msg.payload.command =\"switchlight\";\n }\n}\nreturn msg;","outputs":1,"noerr":0,"x":783.6068649291992,"y":727.7579135894775,"wires":[["7aa248b.bcbe0b8","a792fd8f.4957b"]]},{"id":"7aa248b.bcbe0b8","type":"debug","z":"e8a6bafb.256b68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":975.1068382263184,"y":713.6824169158936,"wires":[]},{"id":"a792fd8f.4957b","type":"mqtt out","z":"e8a6bafb.256b68","name":"test","topic":"domoticz/in","qos":"0","retain":"false","broker":"3cd8a35a.e2ae2c","x":946.9999732971191,"y":853.3332901000977,"wires":[]},{"id":"3cd8a35a.e2ae2c","type":"mqtt-broker","z":"","name":"Local","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"15","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""}]
</code>
9) Change Node red to your environment
a) Change node “http request” to match your IP
b) Change the node “FilterVBUSSensors” if you have different sensors. Use list of sensors from step 4
c) Change the node “IdentifySensor” to match the idx of your dummy/virtual sensors of Domoticz
