BakSeeDaa´s Google Calendar for Domoticz (deprecated)
four2six
Target OS: Raspberry Pi
Re: BakSeeDaa´s Google Calendar for Domoticz V 1.0.2 Released
Post by four2six » Tuesday 13 September 2016 10:28
my bad... somehow those files were created when copying the originals. ignore my rambling :-) sorry!
Aadr
Domoticz version: V2.2536
Post by Aadr » Monday 24 October 2016 19:55
Hello BakSeeDaa,
thank you for this application in Domoticz. I have been using it al summer at our soccerclub for the climatcontrol. But last week it suddenly started to mess up. I made a fresh install, but no luck. I'm on the latest beta of Domoticz, but I don't know when things went wrong.
Perhaps can you help me.
This is the log,
as you can see, the appointments are recognised, but then the log reports 0 events.
2016-10-24 19:36:21.761 User: Admin initiated a switch command (365/GCalCheck Commissiekamer/On)
2016-10-24 19:36:21.801 LUA: GCal3 V 1.0.2: Calendar device GCal Commissiekamer (idx:369 ) initializing
2016-10-24 19:36:21.818 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/ returned true
2016-10-24 19:36:21.832 LUA: GCal3 V 1.0.2: Command /bin/rm -f /home/pi/domoticz/GCal3/GCal3.sem returned true
2016-10-24 19:36:21.839 LUA: GCal3 V 1.0.2: Command bin/rm -f /home/pi/domoticz/GCal3/*.token returned nil
2016-10-24 19:36:21.839 LUA: GCal3 V 1.0.2: Checking semaphore
2016-10-24 19:36:21.849 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.sem returned nil
2016-10-24 19:36:21.849 LUA: GCal3 V 1.0.2: Semaphore file returned nil
2016-10-24 19:36:21.849 LUA: GCal3 V 1.0.2: Device 369 requested semaphore
2016-10-24 19:36:21.858 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.sem returned true
2016-10-24 19:36:21.858 LUA: GCal3 V 1.0.2: Device 369 claimed semaphore
2016-10-24 19:36:21.858 LUA: GCal3 V 1.0.2: Variables initialized ...
2016-10-24 19:36:21.867 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/scripts/lua/json.lua returned true
2016-10-24 19:36:21.870 LUA: GCal3 V 1.0.2: local function: checkforcredentials
2016-10-24 19:36:21.879 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.json returned true
2016-10-24 19:36:21.888 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.json returned true
2016-10-24 19:36:21.899 LUA: GCal3 V 1.0.2: Command find /home/pi/domoticz/GCal3/ -type f ! -newer GCal3.json -name GCal3.pem -delete returned nil
2016-10-24 19:36:21.909 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.pem returned true
2016-10-24 19:36:21.909 LUA: GCal3 V 1.0.2: Timezone is 2 hrs and 0 min
2016-10-24 19:36:21.909 LUA: GCal3 V 1.0.2: Running Plugin ...
2016-10-24 19:36:21.911 LUA: GCal3 V 1.0.2: local function: checkGCal
2016-10-24 19:36:21.911 LUA: GCal3 V 1.0.2: Checking semaphore
2016-10-24 19:36:21.920 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.sem returned true
2016-10-24 19:36:21.920 LUA: GCal3 V 1.0.2: Semaphore file returned 369
2016-10-24 19:36:21.929 LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.sem returned true
2016-10-24 19:36:21.930 LUA: GCal3 V 1.0.2: Device 369 claimed semaphore
2016-10-24 19:36:21.930 LUA: GCal3 V 1.0.2: StartMin is 2016-10-23T22:00:00Z StartMax is 2016-10-25T17:36:00Z
2016-10-24 19:36:21.930 LUA: GCal3 V 1.0.2: End of day is 2016-10-24T23:59:59
2016-10-24 19:36:21.930 LUA: GCal3 V 1.0.2: local function: requestCalendar
2016-10-24 19:36:21.930 LUA: GCal3 V 1.0.2: local function: get_access_token
2016-10-24 19:36:21.930 LUA: GCal3 V 1.0.2: Getting a new token
2016-10-24 19:36:22.140 Hardware Monitor: Fetching data (System sensors)
2016-10-24 19:36:22.396 LUA: GCal3 V 1.0.2: Got new token
2016-10-24 19:36:22.397 LUA: GCal3 V 1.0.2: Checking google calendar
2016-10-24 19:36:22.750 LUA: GCal3 V 1.0.2: Device 369 released the semaphore - reason: calendar check complete
2016-10-24 19:36:22.750 LUA: GCal3 V 1.0.2: local function: getEvents
2016-10-24 19:36:22.751 LUA: GCal3 V 1.0.2: There were 6 events retrieved
2016-10-24 19:36:22.751 LUA: GCal3 V 1.0.2: Effective Event Name TRAINING JEUGD[0,0]{}
2016-10-24 19:36:22.751 LUA: GCal3 V 1.0.2: Effective Event Name SCHOONMAKEN KANTINE[0,0]{}
2016-10-24 19:36:22.752 LUA: GCal3 V 1.0.2: Effective Event Name NLL <23 - SCHELLUINEN <23[0,0]{}
2016-10-24 19:36:22.753 LUA: GCal3 V 1.0.2: Effective Event Name DAMESTEAM OVERLEG[0,0]{}
2016-10-24 19:36:22.753 LUA: GCal3 V 1.0.2: Effective Event Name TRAINING JEUGD[0,0]{}
2016-10-24 19:36:22.754 LUA: GCal3 V 1.0.2: Effective Event Name TRAINING 1 EN 2[0,0]{}
2016-10-24 19:36:22.754 LUA: GCal3 V 1.0.2: Events Today = 0
2016-10-24 19:36:22.754 LUA: GCal3 V 1.0.2: Events Left Today = 0
2016-10-24 19:36:22.754 LUA: GCal3 V 1.0.2: local function: saveEvents
2016-10-24 19:36:22.762 LUA: GCal3 V 1.0.2: Command echo "[]" >/home/pi/domoticz/GCal3/events369.json&&chmod 744 /home/pi/domoticz/GCal3/events369.json returned true
2016-10-24 19:36:22.762 LUA: GCal3 V 1.0.2: Next Event: No more events today
2016-10-24 19:36:22.762 LUA: GCal3 V 1.0.2: Cancel any active event
2016-10-24 19:36:22.762 LUA: GCal3 V 1.0.2: local function: setTrippedOff
2016-10-24 19:36:22.762 LUA: GCal3 V 1.0.2: Event-End Inactive
2016-10-24 19:36:22.763 LUA: GCal3 V 1.0.2: Next check will be in 10800 sec on 2016-10-24 at 22:36:22
2016-10-24 19:36:22.763 LUA: GCal3 V 1.0.2: Device 369 released the semaphore - reason: initialization complete
2016-10-24 19:36:22.763 LUA: GCal3 V 1.0.2: Switch recent status: Off
2016-10-24 19:36:22.768 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_gcal.lua
2016-10-24 19:36:21.761 (Virtueel) Light/Switch (GCalCheck Commissiekamer)
2016-10-24 19:36:23.705 (Virtueel) Light/Switch (GCalCheck Commissiekamer)
I hope you can help me.
archen
Post by archen » Sunday 08 January 2017 22:09
Thanks to BakSeeDaa I've managed to create a carheater script where you can trigger the carheater from google cal.
It takes the outside temperature as a parameter and calculates when the carheater needs to be turned on so the car is ready on the time you have set in google cal.
Thank you very much BakSeeDaa for your work, highly appriciated!
Link to carheater project (some text in swedish). https://github.com/riksarchen/carheater_domoticz
fremar
Post by fremar » Monday 27 February 2017 9:38
archen wrote:Hi all,
Hi looks great been looking for a car heater script for Domoticz so will try this when I have installed a switch in the garage to control the outlet on the garage wall. Is it possible to run the script on Domoticz on windows or is it required to run on a raspberry pi? Is it possible in Domoticz to create a virtual device like this in HC2 where you can start the car heater manually or set a starting time quickly? http://zwaveforum.se/viewtopic.php?f=12 ... &start=100
BakSeeDaa
Post by BakSeeDaa » Thursday 27 April 2017 9:26
This project is now deprecated and unsupported by me.
I have started a new project https://github.com/BakSeeDaa/GCal It's still in an early development stage but it will have many benefits over this project.
If You feel that You want to contribute to the new project as a tester, coder or something else, please have a look at http://www.domoticz.com/forum/viewtopic ... 65&t=17302
Last edited by BakSeeDaa on Friday 23 February 2018 10:14, edited 1 time in total.
BakSeeDaa
Re: BakSeeDaa´s Google Calendar for Domoticz (deprecated)
Post by BakSeeDaa » Tuesday 02 May 2017 8:52
UNINSTALLING instructions has now been added to the initial post.
jasifil
Domoticz version: 4.9700
Post by jasifil » Sunday 01 July 2018 2:27
Hello!
Is there still any support for this plugin? I can try at least to get som respons here :)
Today I replaced my Raspberry Pi with a new one and finally I got it all up and running. But unfortunately the script that checks my Google-calendar returns an error. I just can´t figure out what is wrong. Could anyone please try to help me?
The log shows this:
 2018-07-01 02:16:19.365 Status: User: Admin initiated a switch command (35/GCalCheck name.name/On)
2018-07-01 02:16:19.398 Status: LUA: GCal3 V 1.0.2: Calendar device GCal name.name (idx:33 ) initializing
2018-07-01 02:16:19.413 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/ returned true
2018-07-01 02:16:19.425 Status: LUA: GCal3 V 1.0.2: Command /bin/rm -f /home/pi/domoticz/GCal3/GCal3.sem returned true
2018-07-01 02:16:19.435 Status: LUA: GCal3 V 1.0.2: Command bin/rm -f /home/pi/domoticz/GCal3/*.token returned nil
2018-07-01 02:16:19.436 Status: LUA: GCal3 V 1.0.2: Checking semaphore
2018-07-01 02:16:19.451 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.sem returned nil
2018-07-01 02:16:19.451 Status: LUA: GCal3 V 1.0.2: Semaphore file returned nil
2018-07-01 02:16:19.451 Status: LUA: GCal3 V 1.0.2: Device 33 requested semaphore
2018-07-01 02:16:19.466 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.sem returned true
2018-07-01 02:16:19.466 Status: LUA: GCal3 V 1.0.2: Device 33 claimed semaphore
2018-07-01 02:16:19.467 Status: LUA: GCal3 V 1.0.2: Variables initialized ...
2018-07-01 02:16:19.481 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/scripts/lua/json.lua returned true
2018-07-01 02:16:19.486 Status: LUA: GCal3 V 1.0.2: local function: checkforcredentials
2018-07-01 02:16:19.500 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.json returned true
2018-07-01 02:16:19.515 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.json returned true
2018-07-01 02:16:19.535 Status: LUA: GCal3 V 1.0.2: Command find /home/pi/domoticz/GCal3/ -type f ! -newer GCal3.json -name GCal3.pem -delete returned nil
2018-07-01 02:16:19.549 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.pem returned true
2018-07-01 02:16:19.550 Status: LUA: GCal3 V 1.0.2: Timezone is 2 hrs and 0 min
2018-07-01 02:16:19.550 Status: LUA: GCal3 V 1.0.2: Running Plugin ...
2018-07-01 02:16:19.554 Status: LUA: GCal3 V 1.0.2: local function: checkGCal
2018-07-01 02:16:19.554 Status: LUA: GCal3 V 1.0.2: Checking semaphore
2018-07-01 02:16:19.568 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.sem returned true
2018-07-01 02:16:19.568 Status: LUA: GCal3 V 1.0.2: Semaphore file returned 33
2018-07-01 02:16:19.583 Status: LUA: GCal3 V 1.0.2: Command /bin/ls /home/pi/domoticz/GCal3/GCal3.sem returned true
2018-07-01 02:16:19.583 Status: LUA: GCal3 V 1.0.2: Device 33 claimed semaphore
2018-07-01 02:16:19.584 Status: LUA: GCal3 V 1.0.2: StartMin is 2018-06-30T22:00:00Z StartMax is 2018-07-02T00:16:00Z
2018-07-01 02:16:19.584 Status: LUA: GCal3 V 1.0.2: End of day is 2018-07-01T23:59:59
2018-07-01 02:16:19.584 Status: LUA: GCal3 V 1.0.2: local function: requestCalendar
2018-07-01 02:16:19.584 Status: LUA: GCal3 V 1.0.2: local function: get_access_token
2018-07-01 02:16:19.584 Status: LUA: GCal3 V 1.0.2: Getting a new token
2018-07-01 02:16:19.891 Status: LUA: GCal3 V 1.0.2: The token request returned an error: {
2018-07-01 02:16:19.891 "error" : "invalid_request",
2018-07-01 02:16:19.891 "error_description" : "Bad Request"
2018-07-01 02:16:19.891 }
2018-07-01 02:16:19.891 Status: LUA: GCal3 V 1.0.2: Fatal error trying to get access token
2018-07-01 02:16:19.892 Status: LUA: GCal3 V 1.0.2: Device 33 released the semaphore - reason: calendar check complete
2018-07-01 02:16:19.892 Status: LUA: GCal3 V 1.0.2: Next check will be in 500 sec on 2018-07-01 at 02:24:39
2018-07-01 02:16:19.926 Status: LUA: GCal3 V 1.0.2: Device 33 released the semaphore - reason: initialization complete
2018-07-01 02:16:19.926 Status: LUA: GCal3 V 1.0.2: Switch recent status: Off
2018-07-01 02:16:19.930 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_gcal.lua
TheeDude
Post by TheeDude » Tuesday 18 September 2018 22:30
Hello!
I am having the exact same problem!
Did you find any solution?
My calendar haven´t made an update since 11th september, and I can´t think of anything that I have done, other than updating domoticz a couple of times.
Edit:
I have now found out that we are not alone with the problem..
The original author of the script has a thread on this forum:
http://forum.micasaverde.com/index.php/ ... 2.690.html
And they have noticed the same, and "Stuart" have come up with a solution.
I have tried to check what the difference is between the files and tried to merge them to this project, but I gave up for now, will give it a little more time when I have more motivation. :)
TheeDude
Post by TheeDude » Thursday 20 September 2018 16:23
Hello again, or am I just talking to myself? :)
I did try it out yesterday, but failed.
I got a couple of fail messages that I had to resolve, but now when I initiate the switch, nothing happens, not a word in the log, nothing.
I have tried to compare both Stuarts files, and the latest gcal3 file from BakSeeDaa and tried to merge them together, but as I said before, lua/scripting isn´t really my strong side.
Anyone else that can check it out or help me/us in the right direction?
Here are the files!
Gcal3.rar
(67.46 KiB) Downloaded 1 time
EdwinK
Post by EdwinK » Thursday 20 September 2018 18:39
The title says 'deprecated', so this plugin might not be maintained any longer, besides, the author of it, BakSeeDa, has left Domoticz for another system. Not sure if anyone has picked it up.
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
TheeDude
Post by TheeDude » Thursday 20 September 2018 20:15
At least I know it, that is why I am asking if someone else that is good with coding might help out.
Or if there is another alternative that I have missed out on.
I feel that I need this script really bad. :)
jasifil
Post by jasifil » Friday 21 September 2018 23:39
Hello!
Edit:
Hi!
I have not found any solution unfortunaterly. Have given up on this! I just deleted the plugin since there is no support. Sorry! If you find a solution it would be nice if you could post your solution here :)
TheeDude
Post by TheeDude » Monday 24 September 2018 0:24
Hi!
Hello again!
I think I have come up with a solution.
Atleast it did connect for me, and updated my calendar events, so I guess it work.
Try it out if you like to!
script_device_gcal 1.0.3.rar
(14.31 KiB) Downloaded 1 time
