Enphase
groetg
Target OS: Raspberry Pi
Domoticz version: V2.4025
Enphase
Post by groetg » Saturday 26 September 2015 17:19
Is it possible to let Domoticz read Enphase solar data (just like Solar Edge?), or do I need to use
Master: RPI Model 2B
Sub 1: RPI Model 2B
RFX transmitter/receiver 433 Mhz
13 KAKU units (3 window sensors, 1 door sensor, 7 light switches, 1 dusk sensor, 1 motion sensor)
4 IP cam
Meteostick
OTGW
P1 cable
Davis Vantage Pro weatherstation (incl. solar/UV)
gizmocuz
Re: Enphase
Post by gizmocuz » Sunday 27 September 2015 8:50
I think this could get you started:
https://github.com/gouldner/ST-Projects ... ten.groovy
KoenVanduffel
Re: Enphase
Post by KoenVanduffel » Sunday 27 September 2015 12:02
The above solution takes it from the Enphase servers.
I wrote a bash script to get the day values off my Enphase gateway. The second half of the script also calculates the actual total power consumption and daily total. (I made a quick update turning variables into English and a few cosmetic things. hope i didn't make an error, a quick test worked fine)
#!/bin/bash
# bash script to read current and actual day power from Enphase gateway
# second part caluclates the actual total power consumption and day consumption for the whole house
# V1.3 27/09/2015
# By Koen Vanduffel
# variables
solar_idx="57"
electricitydaily_idx="58"
enphase_IP="192.168.1.143"
# Read Enphase status page and store as of Currently
DATA=`wget -q -O - $enphase_IP/production | awk '/Currently/{print $0}'`
# Extract current and currentunits, power and powerunits reported
CURRENT=`echo $DATA | awk '/Currently/{print $3}'`
CURRENTUNIT=`echo $DATA | awk '/Currently/{print substr ($4, 1, 1)}'`
kWh=`echo $DATA | awk '/Currently/{print $6}'`
kWhUNIT=`echo $DATA | awk '/Currently/{print substr ($7, 1, 1)}'`
echo $CURRENT
echo $CURRENTUNIT
echo $kWh
echo $kWhUNIT
# convert to Watt and Wh if needed
if [ "$CURRENTUNIT" == "k" ]; then
CURRENT=`awk "BEGIN {print $CURRENT * 1000}"`
fi
if [ "$kWhUNIT" == "k" ]; then
kWh=`awk "BEGIN {print $kWh * 1000}"`
fi
echo $CURRENT
echo $kWh
# Execute curl command to post current and power to Domoticz
curl -i -H "Accept: application/json" "http://localhost:8080/json.htm?type=command&param=udevice&idx=$solar_idx&nvalue=0&svalue=$CURRENT;$kWh"
# part 2:
# now calculate the total power consumed
# get actual consumption from P1 meter reading in Domoticz and return data
# there might be an easier way than to awk is from the json output
DATA=`wget -q -O - '192.168.1.9:8080/json.htm?type=devices&rid=12' | awk '/CounterDelivToday/{print $3}'`
CURRENTRETURNTODAY=`echo $DATA | awk -F, '{gsub(/"/,"",$1); print $1}'`
DATA=`wget -q -O - '192.168.1.9:8080/json.htm?type=devices&rid=12' | awk '/CounterToday/{print $3}'`
CURRENTUSAGETODAY=`echo $DATA | awk -F,  '{gsub(/"/,"",$1); print $1}'`
echo $CURRENTUSAGETODAY
echo $CURRENTRETURNTODAY
TOTALCONSUMPTION=$(python -c "print $CURRENTUSAGETODAY*1000-$CURRENTRETURNTODAY*1000+$kWh")
echo $TOTALCONSUMPTION
# when 5 min around midnight post a zero otherwise Domoticz gets confused with not restarting at zero at 0:00 hours
# probably an imporvement is possible by continuing to calculate the total power long term
time=`date +%k%M` ;
if [ $time -gt 2355 ] || [ 6 -gt $time ]
then
TOTALCONSUMPTION=0
fi
echo $time
# now do the same for current
DATA=`wget -q -O - '192.168.1.9:8080/json.htm?type=devices&rid=12' | awk '/Usage/{print $3}'`
CURRENTUSAGE=`echo $DATA | awk '{print substr ($1, 2, 4)}'`
CURRENTRETURN=`echo $DATA | awk '{print substr ($2, 2, 4)}'`
echo $CURRENTUSAGE
echo $CURRENTRETURN
TOTALCURRENT=$(python -c "print $CURRENTUSAGE-$CURRENTRETURN+$CURRENT")
echo $TOTALCURRENT
# Execute curl command to post total electricity consumption today
curl -i -H "Accept: application/json" "http://localhost:8080/json.htm?type=command&param=udevice&idx=$electricitydaily_idx&nvalue=0&svalue=$TOTALCURRENT;$TOTALCONSUMPTION"
groetg
Re: Enphase
Post by groetg » Tuesday 16 February 2016 20:39
Sorry for the late reply, but how do I get these Enphase data in Domoticz?
There is a API program, maybe it could be implemented in Domoticz just like solaregdge support?
https://developer.enphase.com/docs/quickstart.html
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
KoenVanduffel
Re: Enphase
Post by KoenVanduffel » Wednesday 17 February 2016 21:11
I basically do the same as in this wiki page: https://www.domoticz.com/wiki/Monitor_memory_usage
make the virtual sensors in Domoticz and note their idx
Make the basch script using your idx numbers for the variables and the local ip address of your enphase gateway and make the script executable.
setup cron to execute the script every 5 min
that should be it.
My script does not take the data from the enphase servers but direct from the local gateway
Machielw
Re: Enphase
Post by Machielw » Saturday 22 October 2016 10:40
not working anymore?
this is working well:
http://www.domoticz.com/forum/viewtopic ... ase#p99980
Jumper3126
Re: Enphase
Post by Jumper3126 » Saturday 15 September 2018 12:56
Used the script of Koen van Duffel to read out the production of each panel
see http://www.domoticz.com/forum/viewtopic ... 62#p191562
