MyDomoticz - Testers wanted!
chimit
Target OS: Raspberry Pi
Domoticz version: master
Re: MyDomoticz - Testers wanted!
Post by chimit » Sunday 04 November 2018 0:11
There have been some stability changes to MyDomoticz.
You may now find the service more friendly to use and less error prone.
As usual, please report any issues below in this thread.
== Rene
chimit
Post by chimit » Sunday 04 November 2018 12:08
Some more background about the previous post: Basically two severe bugs have been resolved, besides minor fixes.
1. The main server intermittently stopped accepting https connections.
2. After a while, one was unable to access their Domoticz instance via MyDomoticz.
Apologies for any inconvenience this may have caused.
Ignacio
Post by Ignacio » Sunday 04 November 2018 14:43
Now it is working OK . Thank you.
The only problem comes from the local cache.
chimit
Post by chimit » Friday 16 November 2018 11:52
For the people that get an intermittent "Invalid login" message, even after entering a correct password, sometimes it helps to refresh the login page before trying to log in.
hjzwiers
Post by hjzwiers » Wednesday 21 November 2018 10:29
I have a strange issue with mydomoticz. After enabling in the setup page all works well, also with my vanity name. So all settings and port forwarding in the router are fine.
The strange thing is that every time I want to connect externally I need to switch off enabling in the settings and enable again. The moment I apply the settings en login turns green and I can login. (I change the settings through a direct connection to my domoticz system to test this)
Once I do this it works till I need to login again ???
Why do I need to re-enable every time I use it. Anyone have a clue?
Last edited by hjzwiers on Wednesday 21 November 2018 13:08, edited 1 time in total.
ppaciek
Post by ppaciek » Wednesday 21 November 2018 11:51
I have a problem with my.domoticz.com - when I try to log in I get the message "invalid error", even though the password is correct. Only after a few attempts I manage to log in. What's is wrong? This will be corrected?
JanK
Post by JanK » Wednesday 21 November 2018 13:10
Hi, I have the same problem from Firefox and Chrome.
By Android Firefox, time to time help longer press "Sign in" button.
Is any solution?
chimit
Post by chimit » Wednesday 21 November 2018 13:11
You may want to refresh the page (F5) before logging in.
This is a known issue and on our to-fix list.
== Rene
ppaciek
Post by ppaciek » Wednesday 21 November 2018 13:15
== Rene
Thanks for your answer. Is good news, so I am waiting impatiently to fix the issue :)
Regards,
Sway06
Domoticz version: 4.9700
Post by Sway06 » Monday 03 December 2018 0:24
Hi! I have exactly the same problem you have. Did you manage to resolve it?
hjzwiers
Post by hjzwiers » Monday 03 December 2018 9:14
No I have not resolved it, have no clue why this is happening.
Sway06
Post by Sway06 » Monday 03 December 2018 22:10
What kind of Internet connection do you have linked to your domoticz installation? I have mobile broadband giving access to the Raspberry Pi where Domoticz is running, internet is given to the Pi via a 4G router. Since my internet provider only allows dynamic IP, I wonder if this has anything to do with MyDomoticz losing the access upon next login? I think I only tried to re-access MyDomoticz the day after when it was not working so maybe the fact that the IP changes makes the connection between MyDomoticz and Domoticz broken. Just a guess but it could be that I have no clue what I am talking about :)
hjzwiers
Post by hjzwiers » Monday 03 December 2018 23:40
I log in from a PC at work. I think it has something to do within Domoticz, because if I toggle the enabling (also remotely, but then through a direct link to Domotics through the router) the icon turns green immediately in mydomoticz. So it does not allow connection to the server without toggling. I use the mydomoticz to see a combined graph on a full screen instead of a phone. The app also connects without problems, its only the mydomoticz server that has this connection issue.
hjzwiers
Post by hjzwiers » Monday 03 December 2018 23:44
After the toggle I do see: Status: Proxymanager started in the logging. Does this give anyone a clue?
Deruut
Post by Deruut » Thursday 06 December 2018 22:28
Hey there,
im just starting with my domoticz and registered with my.domoticz.com to test domoticz with ifttt.com.
is there a way to put the authentication of my.domoticz.com in the url or is the a way to genrate a authentication token to put in the url ?
greeting for a newbie user with great/ wild ideas on what domoticz can do!!!
Mark
sorampage
Domoticz version: LastStab
Post by sorampage » Monday 10 December 2018 19:50
Hello ;)
It's possible to use Android Domoticz App, and connect via MyDomoticz ???
I use a 4G router, i can't forward port .. ;)
hjzwiers
Post by hjzwiers » Wednesday 12 December 2018 10:23
No-one has a clue? Why do I always need to toggle enabled before the I can connect remotely (icon turns green the second I turn enabled back on)
MyDomoticz Settings:
MyDomoticz Instance ID: 2CDADF07F3A2E9D
MyDomoticz API Key:
8F82A55FDDD7E0C
MyDomoticz Password:
Enabled
Tonny
Post by Tonny » Wednesday 12 December 2018 14:48
MyDomoticz API Key:
8F82A55FDDD7E0C
Enabled
I'm suffering from the same issue, only re-enabling allows me to connect next time. That situation causes that remote access doesn't work at all in fact as in order to re-enable I have to be in my local network from which I have access all the time.
Sent from my SM-G900F using Tapatalk
