MyDomoticz - Testers wanted!
modF
Re: MyDomoticz - Testers wanted!
Post by modF » Tuesday 21 August 2018 17:52
I am still having this same issue even after grabbing today's 4.9917 version. I believe I have tried just about everything I can think of short of uninstalling and removing everything, I would really like to not lose the last couple years of data. If anyone has any suggestions please tell! :)
chimit
Target OS: Raspberry Pi
Domoticz version: master
Post by chimit » Friday 24 August 2018 12:00
tgg3 wrote:
Thursday 21 June 2018 6:37
If I login with my vanity hostname I see a blank page with only the colored background. I don't even get to select an instance. This worked previously.
Logging into www.mydomoticz.com works correctly.
When you log in with your vanity hostname, you will be directed directly to the Domoticz screen. There's no instance selection, since you already do that by choosing the hostname.
chimit
Post by chimit » Friday 24 August 2018 12:02
Tmaster2018 wrote:
Friday 29 June 2018 17:51
NOT ANYMOre!
It is related with release of Domoticz new version?
can we do something about that?for example de paid/donate version don't have this long failures?
I know i still on free version :oops: ,but just to understand what happens :mrgreen:
To the people that were experiencing mydomoticz being intermittently offline.
I've been working for the past week or so on fixing this. I think I got it now. It took a bit because of the holidays as well.
But mydomoticz should be more infrequent offline since now.
chimit
Post by chimit » Friday 24 August 2018 12:05
modF wrote:
Wednesday 08 August 2018 19:50
What is the correct procedure for removing an instance ID from my local installation on Windows? In another location, I have a raspberry pi connected and functioning, but I can't seem to get my windows version connected to MyDomoticz. I keep getting the error of invalid credentials for this instance/api. I know they are good, so I tried to get a new instance ID and this one will not go away. I've tried removing all of my credentials from the settings page, enabling/disabling, restarting, upgrading to the latest version. The instance ID on the windows one is the same one that has been there for at least a year or more.
If you like, PM me your api key and instance key so I look into your matter.
chimit
Post by chimit » Friday 24 August 2018 14:39
MobileDomUser wrote:
Wednesday 11 July 2018 22:17
Lately I have been having issues connecting to mydomoticz.com, my instance is showing offline now. I think this may be a symptom:
2018-07-11 16:03:18.872 Accepting shared server connections via MyDomotiz (see settings menu).
2018-07-11 16:03:18.886 Active notification Subsystems: email, pushbullet (2/13)
2018-07-11 16:03:18.869 Status: Proxymanager started.
2018-07-11 16:03:20.991 Status: PROXY: Authenticate result: Disallowing due to maxinstances (2725773122DF087)..
I have tried enabling and disabling in MyDomoticz settings of the settings page multiple times, tried removing my instance with it disabled several times (each time I get "Cannot delete while the instance is online"), making sure the Rpi3 this runs on is up-to-date, etc.
Is it possibly a server-ralated issue, it seems there was a similar issue reported in viewtopic.php?t=7764&start=60#p68702?
By chance I caught this one in the server code. One also got this error message erroneously when a whitelist ip was entered and the domoticz connected from a different ip.
This caused a lot of confusion as well. A fix will be put online in the next release, within a day, more or less.
Rene
gcoupe
Domoticz version: v4.9700
Post by gcoupe » Sunday 09 September 2018 13:34
Is there some reason why the incorrect URL is given for the MyDomoticz service in the Wiki pages? It gives https://my.domoticz.com/ as the URL in at least two places instead of http://mydomoticz.com/ (using my.domoticz.com gives a "site not found" warning, and using https://mydomoticz.com gives a security warning...)
Cees
Post by Cees » Sunday 09 September 2018 13:41
Thanks for the info.. I didn't know it changed.(did it?)
https://my.domoticz.com was working until a few days ago (Maybe a week)..
Maybe it's an idea to make a redirect from the old URL to the new URL?
(For now I am not even will try to login on the new URL until I know for sure it is legit)
mirikbb
Post by mirikbb » Wednesday 12 September 2018 14:24
while activating mydomoticz, (together with creating account etc...) in Domoticz settings, I can't get Instance ID and can't see any Domoticz instance in web my.domoticz.com dashboard.
It looks like that the https://my.domoticz.com doesn't work/ is stopped. I used non secured version of web page http://my.domoticz.com to create account and check web dashboard, but apparently the Domoticz application is communicating with my.domoticz over secured https only.
Please, is there running any maintenance on the https web server, or is it turned off for a reason, or permanently?
Thank you.
Ignacio
Post by Ignacio » Saturday 15 September 2018 20:25
Currently i am not able to connect my systems neither using https://my.domoticz.com/ nor http://my.domoticz.com/ . Fortunately I still can connect using Dataplicity service and Wormhole.
tomchees
Domoticz version: 4.999
Post by tomchees » Wednesday 19 September 2018 12:52
I can also confirm that https://my.domoticz.com is not responding.
On the other hand I'm able to log in to non-secure http://my.domoticz.com and see instance of my system online can't go any further than this (e.g. see the dashboard).
Tomasz
Users browsing this forum: Google [Bot] and 0 guests
