MyDomoticz - Testers wanted!
Nautilus
Target OS: Raspberry Pi
Re: MyDomoticz - Testers wanted!
Post by Nautilus » Wednesday 09 May 2018 14:34
Nautilus wrote:
Wednesday 25 April 2018 20:23
chimit wrote:
Wednesday 25 April 2018 12:49
One reason can be that you have two Domoticz instances.
It's possible that they have an identical apikey, when a backup from the first is transferred to the second at some point.
Another reason can be a network hitch. When you domoticz notices a disconnect it tries to connect again.
But if meanwhile MyDomoticz didn't notice the disconnect yet, it thinks your instance tries to connect multiple times at once.
Thanks for the reply. I only have one Domoticz instance and this issue has been there for a while. I was last able to use the service on March 13th (i.e. over a month ago) and since then it has shown "red" on my.domoticz. If I disable/enable the service in Domoticz I get the mentioned errors. So it is not at least any temporary network glitch. Not sure what else I could try?
I ended up removing the instance and creating a new. It worked for a while but now I'm getting the same error message again. Not much have changed, still only one Domoticz instance running and network working in a normal manner....
Slokoavac
Domoticz version: 3.8153
Post by Slokoavac » Saturday 19 May 2018 10:56
I have same issue. What is worse. I have tried to delete instance, but it says it is online, although i turned off raspi with that domoticz. I have deleted name field and user pass, now i can not even access menu to try to delete instance. I have donated few euros, but this system seems to be deeply broken :(
can mydomoticz admin PM me so i can send him instance ID so it can be removed on server side? Otherwise i am stuck with this no name fake online instance i can't remove.
Pi 2 (raspbian stretch) w. Conrad VOC USB, Xiaomi PM 2.5 detector , Xiaomi/Philips bulbs, Mi Flora BT, Xiaomi GW (w. temp/humidity/pir)
Pi Zero W (raspbian stretch) w. - Xiaomi GW (temp/hum/door)
tgg3
Domoticz version: 4.9700
Post by tgg3 » Saturday 19 May 2018 17:02
I'm getting a "Oops!!" message when I try to start my instance. What should I do?
Version: 3.9459
Platform: Raspberry Pi 3 B+ (Stretch)
Plugin/Hardware: MySensors 2.2.0 with a Serial Gateway
Tom
Slokoavac
Post by Slokoavac » Saturday 19 May 2018 23:04
@chmit
this is definetly UI bug. If i delete name of instance in mydomoticz, i can not edit it anymore since the name was the link to edit. Can you please delete instance that is stuck and fix this UI bug? :)
thanks!
zaakal
Post by zaakal » Tuesday 29 May 2018 7:42
So checked all units - no special characters.
Still empty dashboard.
And if i make new account everything works....... but account i donated doesnt work.
zaakal wrote:
Monday 07 May 2018 20:49
In this unit i copied the error I have not used special charaters.
In another unit i may have used it. It is in remote location and i dont remember its web login so i have to check it at place.
Is it possible that beacuse of first unit the second one is giving error?
Now i have posted enough posts in forum so if u prefer I can PM afterwards. :D
chimit wrote:
Monday 07 May 2018 19:04
I meant Domoticz name.
I suppose the device names with special characters used to work before the name change?
zaakal wrote:
Monday 07 May 2018 18:17
Do you mean Device names or Domoticz name?
In device names i use some .
chimit
Domoticz version: master
Post by chimit » Wednesday 30 May 2018 7:49
PM me your API KEY so I can transfer the donation to the new account.
== Rene
AllesVanZelf
Re: Testers wanted!
Post by AllesVanZelf » Wednesday 30 May 2018 18:00
chimit wrote:
Saturday 23 January 2016 23:13
You can click on the green icon and you will have access to your Domoticz.
Something to include on the Wiki pages.
Thanks for this. I took me some time to find out how to see my domoticz 'instance'. :(
AllesVanZelf
Post by AllesVanZelf » Thursday 07 June 2018 8:41
Is:
mydomoticz.com
the same as:
my.domoticz.com
It looks the same. But just to make sure.
chimit
Post by chimit » Thursday 07 June 2018 8:46
Hi, yes. You have a very good question here.
But yes, it's the same. mydomoticz.com is the domain that the vanity hosts reside on.
my.domoticz.com is the official (legacy) host name.
AllesVanZelf
Post by AllesVanZelf » Thursday 07 June 2018 9:34
Okay thank you!
Prutsium
Post by Prutsium » Tuesday 19 June 2018 16:24
Is My.Domoticz offline?
Had it running today and all worked great with 2 systems but sudden its gone. (domoticz offline message after clicking them while they show online)
Restarted both Pi's but no result i see them online in My.Domoticz but the data counter doesnt go up so seems no data comes in.
Cees
Post by Cees » Tuesday 19 June 2018 16:33
For what is worth: Everything seems to be working on my side.
Prutsium
Post by Prutsium » Tuesday 19 June 2018 17:47
Strange enough suddenly it works again had to enable and disable My.Domoticz in the Domoticz setup a few times.
Not sure if that helped or it was just a matter of time ......
tgg3
Post by tgg3 » Thursday 21 June 2018 6:37
If I login with my vanity hostname I see a blank page with only the colored background. I don't even get to select an instance. This worked previously.
Logging into www.mydomoticz.com works correctly.
Tom
Prutsium
Post by Prutsium » Tuesday 26 June 2018 20:17
Seems that there are some issues with My.Domoticz ????
Site often doesn't respond or comes with an offline page.
tomchees
Domoticz version: 4.999
Post by tomchees » Wednesday 27 June 2018 15:13
@Prutsium, I also confirm my.domoticz.com appears to be offline since at least yesterday :(
Prutsium
Post by Prutsium » Friday 29 June 2018 9:30
Seems to be online again Yahooooo!
Tmaster2018
Post by Tmaster2018 » Friday 29 June 2018 17:51
NOT ANYMOre!
It is related with release of Domoticz new version?
can we do something about that?for example de paid/donate version don't have this long failures?
I know i still on free version :oops: ,but just to understand what happens :mrgreen:
MobileDomUser
Domoticz version: 3.8.8153
Post by MobileDomUser » Wednesday 11 July 2018 22:17
Lately I have been having issues connecting to mydomoticz.com, my instance is showing offline now. I think this may be a symptom:
2018-07-11 16:03:18.872 Accepting shared server connections via MyDomotiz (see settings menu).
2018-07-11 16:03:18.886 Active notification Subsystems: email, pushbullet (2/13)
2018-07-11 16:03:18.869 Status: Proxymanager started.
2018-07-11 16:03:20.991 Status: PROXY: Authenticate result: Disallowing due to maxinstances (2725773122DF087)..
I have tried enabling and disabling in MyDomoticz settings of the settings page multiple times, tried removing my instance with it disabled several times (each time I get "Cannot delete while the instance is online"), making sure the Rpi3 this runs on is up-to-date, etc.
Is it possibly a server-ralated issue, it seems there was a similar issue reported in viewtopic.php?t=7764&start=60#p68702?
modF
Post by modF » Wednesday 08 August 2018 19:50
What is the correct procedure for removing an instance ID from my local installation on Windows? In another location, I have a raspberry pi connected and functioning, but I can't seem to get my windows version connected to MyDomoticz. I keep getting the error of invalid credentials for this instance/api. I know they are good, so I tried to get a new instance ID and this one will not go away. I've tried removing all of my credentials from the settings page, enabling/disabling, restarting, upgrading to the latest version. The instance ID on the windows one is the same one that has been there for at least a year or more.
