MyDomoticz - Testers wanted!
Nautilus
Target OS: Raspberry Pi
Re: MyDomoticz - Testers wanted!
Post by Nautilus » Wednesday 09 May 2018 14:34
Nautilus wrote:
Wednesday 25 April 2018 20:23
chimit wrote:
Wednesday 25 April 2018 12:49
One reason can be that you have two Domoticz instances.
It's possible that they have an identical apikey, when a backup from the first is transferred to the second at some point.
Another reason can be a network hitch. When you domoticz notices a disconnect it tries to connect again.
But if meanwhile MyDomoticz didn't notice the disconnect yet, it thinks your instance tries to connect multiple times at once.
Thanks for the reply. I only have one Domoticz instance and this issue has been there for a while. I was last able to use the service on March 13th (i.e. over a month ago) and since then it has shown "red" on my.domoticz. If I disable/enable the service in Domoticz I get the mentioned errors. So it is not at least any temporary network glitch. Not sure what else I could try?
I ended up removing the instance and creating a new. It worked for a while but now I'm getting the same error message again. Not much have changed, still only one Domoticz instance running and network working in a normal manner....
Slokoavac
Domoticz version: 3.8153
Post by Slokoavac » Saturday 19 May 2018 10:56
I have same issue. What is worse. I have tried to delete instance, but it says it is online, although i turned off raspi with that domoticz. I have deleted name field and user pass, now i can not even access menu to try to delete instance. I have donated few euros, but this system seems to be deeply broken :(
can mydomoticz admin PM me so i can send him instance ID so it can be removed on server side? Otherwise i am stuck with this no name fake online instance i can't remove.
Pi 2 (raspbian stretch) w. Conrad VOC USB, Xiaomi PM 2.5 detector , Xiaomi/Philips bulbs, Mi Flora BT, Xiaomi GW (w. temp/humidity/pir)
Pi Zero W (raspbian stretch) w. - Xiaomi GW (temp/hum/door)
tgg3
Domoticz version: 3.9453
Post by tgg3 » Saturday 19 May 2018 17:02
I'm getting a "Oops!!" message when I try to start my instance. What should I do?
Version: 3.9459
Platform: Raspberry Pi 3 B+ (Stretch)
Plugin/Hardware: MySensors 2.2.0 with a Serial Gateway
Tom
Slokoavac
Post by Slokoavac » Saturday 19 May 2018 23:04
@chmit
this is definetly UI bug. If i delete name of instance in mydomoticz, i can not edit it anymore since the name was the link to edit. Can you please delete instance that is stuck and fix this UI bug? :)
thanks!
