RFLink: List of supported devices
433Mhz opensource Receiver & Transmitter.
Moderator: Stuntteam
Heldestad
Target OS: Raspberry Pi
Re: RFLink: List of supported devices
Post by Heldestad » Sunday 19 March 2017 18:28
tontze wrote:
Heldestad wrote:
tontze wrote:Prologue 36-4744 (Clas Ohlsson) works out of the box.
I have one of those but it does not work so well for me. I have home assistant on my RPi2 with a tellstick duo.
Is there any connection procedure I'm supposed to do?
Im using rflink, dont know anything about tellstick :)
Of course, though this was a generic home automation forum. Perhaps I should post on a more tellstick oriented forum :)
Saughassy
Post by Saughassy » Monday 01 May 2017 12:27
Hey guys!
RFLink via Domoticz can use http://www.smart-home.hu/index.php?lang=en these stuffs. I'm using a blind with wind and sun sensor + additional remotes with no flaws.
mivo
Post by mivo » Friday 30 June 2017 16:55
I get new RFLink 433 gateway from Nodo-shop. It is my pleasure to report it is working out of the box with my home Temp-Humidity sensors, reported as Cresta:
RFLink: 20;02;Cresta;ID=5802;TEMP=00e2;HUM=39;BAT=OK;
It is marketed in Czech Republic as Garni 652EL (meteo station) and Garni TS33F (sensors).
Thank you RFLink developers for great work !
Garni 652EL and TS33F.jpg (39.64 KiB) Viewed 3443 times
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
kijdhfcjdks
Post by kijdhfcjdks » Sunday 02 July 2017 20:20
Hi, these 433 MHz temp/humidity sensors work. 3 channels per type so you could have 6 in total:
http://www.biltema.se/sv/Kontor---Tekni ... 000036036/
Extra sensor: 84-0863, 84-0864
As well as:
Extra sensor: 84-0865
These switches work:
Luxorparts (1000W):
https://www.kjell.com/se/sortiment/el-v ... ack-p50969
Telldus (3680W):
https://www.kjell.com/se/sortiment/el-v ... ack-p50813
Edit 2: The "Biltema" sensors works fine, got another one and switched the channels around followed by reset until i showed up in the log.
kijdhfcjdks
Post by kijdhfcjdks » Sunday 10 September 2017 16:14
This 433 4-channel relay works fine:
https://www.aliexpress.com/item/RF22A04 ... sstype=600
From the log:
10;EV1527;021ee3;1;ON
Tosha74
Domoticz version: V3.8153
Post by Tosha74 » Monday 27 November 2017 18:18
Hi! I'm glad to tell, that cheap (~ $15 on Aliexpress) VHome switch with RF remote work fine.
pacitzu
Post by pacitzu » Thursday 07 December 2017 15:26
Can you tell me about the battery life of this Vhome switch?
Tosha74
Post by Tosha74 » Thursday 07 December 2017 16:56
I bought this switch only a few weeks ago.
marcojpolet
Post by marcojpolet » Thursday 26 April 2018 19:42
Received my rainmeter /temp / remote display today and I can confirm it working out of the box with latest RFLink version. For 20 euro's delivered :-)
https://www.aliexpress.com/item/Wireles ... 07674.html
Brand: OOTDTY
Model: WH0531
Detected in Devices as TFA (rain) and LaCrosseTX3 (temp). Not 100% sure but I believe AlectoV5 from RFLink in Domoticz Log.
Regards,
Marco
marcojpolet
Post by marcojpolet » Saturday 23 June 2018 7:48
My previous post (one above this one) was about a rainmeter. It still works fine, but I noticed that every time the batteries are removed/replaced, the device gets picked up by RFLink under another device-id/unit. The standalone receiver still sees the rainmeter, but in Domoticz I have to change my devices to match the new id/unit. Any ideas how this can be automated/skipped?
SweetPants
Domoticz version: V4.10196
Post by SweetPants » Saturday 23 June 2018 10:37
This is normal behaviour and initiated by the device itself. There is nothing domoticz can do about that. You can always try to edit->replace the device with the new one to preserve your data.
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
mpx2
Post by mpx2 » Saturday 13 October 2018 16:40
As well as:
Luxorparts (1000W):
Telldus (3680W):
Looks similar to Renkforce KL4931. https://www.conrad.com/ce/en/product/12 ... o-24-hours.
Looks similar to Techno Line TX 6000 sensor which is used with weather stations WS6600, WS6620, WS6650, WS6740 and WS6850 https://www.technoline.eu/. WS6740 is identical to Biltema Art. 84-0865 weather station.
I cannot find any working Biltema sensor besides the old 84-0871.
RFLink firmware R48.
Biltema sensor Art. 84-0871, fits weather station Art. 84-0865
Older batch works OK! Recognized as Prologue. Clas Ohlson Prologue 36-4744 is not available anymore.
Newer batch doesn't work! RFLink does not recognize. If I press tx button many times sometimes RFLink shows Alecto V4 but temperature and humidity are wrong.
20;40;DEBUG;Pulses=76;Pulses(uSec)=480,3780,390,1860,390,1860,390,3780,390,3780,390,1860,420,3780,420,1860,390,1860,420,3780,420,3780,390,3780,390,1860,420,3780,390,1860,390,3780,420,1860,390,1860,390,1860,420,1860,390,3780,420,3780,420,3780,390,3780,390,1860,390,3780,390,3780,390,1860,420,1860,390,1860,390,3780,390,1860,390,1860,390,3780,420,3780,390,3780,390,3810,420,6990;
20;41;DEBUG;Pulses=44;Pulses(uSec)=450,1740,360,1770,390,1800,390,1860,390,3780,420,3780,420,3780,390,3780,390,1860,420,3780,390,3780,390,1860,420,1860,390,1860,390,3780,390,1860,390,1860,420,3780,390,3780,390,3780,390,3810,420,6990;
20;42;DEBUG;Pulses=58;Pulses(uSec)=450,3570,390,3600,390,3780,390,1860,420,3780,390,1860,420,3780,420,1860,390,1860,420,1860,420,1860,390,3780,420,3780,420,3780,390,3780,390,1860,420,3780,390,3780,390,1860,420,1860,390,1860,420,3780,420,1860,390,1860,420,3780,420,3780,390,3780,390,3810,420,6990;
20;43;DEBUG;Pulses=52;Pulses(uSec)=450,1740,390,3630,390,1860,420,3780,420,1860,390,1860,420,1860,420,1860,390,3780,420,3780,420,3780,390,3780,390,1860,420,3780,390,3780,390,1860,420,1860,390,1860,390,3780,420,1860,390,1860,390,3780,420,3780,390,3780,390,3810,420,6990;
20;44;DEBUG;Pulses=54;Pulses(uSec)=450,3600,390,1800,420,3780,390,1860,420,3780,390,1860,390,1860,390,1860,420,1860,390,3780,420,3780,420,3780,390,3780,390,1860,420,3780,390,3780,390,1860,420,1860,390,1860,420,3780,420,1860,390,1860,420,3780,420,3780,390,3780,390,3810,420,6990;
20;45;DEBUG;Pulses=54;Pulses(uSec)=450,3600,390,1740,390,3780,390,1860,420,3780,420,1860,390,1860,420,1860,420,1860,390,3780,420,3780,420,3780,390,3780,420,1860,420,3780,390,3780,390,1860,420,1860,390,1860,420,3780,420,1860,390,1860,420,3780,390,3780,390,3780,390,3810,420,6990;
20;46;DEBUG;Pulses=52;Pulses(uSec)=450,3600,390,1740,390,3780,390,1860,420,3780,420,1860,390,1860,420,1860,420,1860,390,3780,420,3780,420,3780,390,3780,390,1860,390,3780,390,3780,390,1860,420,1860,390,1860,420,3780,390,1860,390,1860,390,3780,420,3780,390,3780,390,6990;
Biltema sensor Art. 84-0820, fits weather station Art. 84-0866
Doesn't work! RFLink does not recognize.
20;A1;DEBUG;Pulses=76;Pulses(uSec)=390,3780,390,1860,390,1860,390,3780,390,3780,390,3780,390,1860,390,1860,390,3780,390,3780,390,1860,390,1860,390,1860,390,3780,390,1860,390,3780,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,3780,390,3780,390,3780,390,1860,390,3810,420,6990;
20;A2;DEBUG;Pulses=44;Pulses(uSec)=270,1770,360,1770,360,1770,360,3750,390,1860,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,3780,390,3780,390,3780,390,1860,390,3810,420,6990;
20;A3;DEBUG;Pulses=58;Pulses(uSec)=450,3600,390,1770,390,1860,390,1860,390,3780,390,1860,390,3780,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,3780,390,3780,390,3780,390,1860,390,3840,420,6990;
20;A4;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3600,360,1830,390,3780,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,3780,390,3780,390,3780,390,1860,390,3810,420,6990;
20;A5;DEBUG;Pulses=56;Pulses(uSec)=450,1770,360,1770,360,1770,360,3750,390,1860,390,3780,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,3780,390,3780,390,3780,390,1860,390,3810,420,6990;
20;A6;DEBUG;Pulses=54;Pulses(uSec)=150,1770,390,1770,360,3600,420,1860,390,3780,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,3780,390,3780,390,3780,390,1860,390,3840,420,6990;
20;A7;DEBUG;Pulses=52;Pulses(uSec)=450,1770,390,1770,360,3690,390,1860,390,3780,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,1860,390,3780,390,1860,390,3780,390,3780,390,3780,390,1860,390,6990;
Biltema sensor Art. 84-0870, fits weather station Art. 84-0863 and 84-0864
20;71;DEBUG;Pulses=76;Pulses(uSec)=450,3780,390,1860,420,1860,390,3780,390,3780,420,3780,420,3780,390,3780,420,1860,420,3780,390,3780,390,3780,420,1860,390,3780,390,3780,420,1860,390,1860,390,1860,390,1860,390,1860,420,3780,420,3780,390,3780,390,3780,390,3780,420,1860,390,3780,390,3780,420,1860,390,1860,390,3780,420,1860,390,3780,420,1860,420,3780,390,3780,420,3810,420,6990;
20;72;DEBUG;Pulses=46;Pulses(uSec)=450,1770,390,1770,390,1860,390,1860,420,1860,390,3780,420,3780,420,3780,390,3780,390,3780,420,1860,420,3780,390,3780,420,1860,420,1860,390,3780,420,1860,420,3780,390,1860,420,3780,420,3780,390,3810,420,6990;
20;73;DEBUG;Pulses=60;Pulses(uSec)=450,1740,390,3600,390,3720,420,3780,420,1860,390,3780,420,3780,420,1860,390,1860,420,1860,390,1860,390,1860,390,3780,420,3780,390,3780,420,3780,420,3780,390,1860,420,3780,420,3780,390,1860,420,1860,420,3780,390,1860,420,3780,420,1860,390,3780,420,3780,420,3810,420,6990;
20;74;DEBUG;Pulses=54;Pulses(uSec)=450,3600,390,1770,360,3750,390,3780,420,1860,420,1860,390,1860,420,1860,390,1860,420,3780,420,3780,390,3780,390,3780,420,3780,420,1860,420,3780,420,3780,420,1860,390,1860,420,3780,420,1860,390,3780,390,1860,420,3780,390,3780,390,3810,420,6990;
20;75;DEBUG;Pulses=56;Pulses(uSec)=450,3570,390,3630,390,1860,420,3780,420,3780,390,1860,420,1860,420,1860,390,1860,420,1860,390,3780,390,3780,420,3780,420,3780,390,3780,390,1860,420,3780,390,3780,390,1860,420,1860,420,3780,390,1860,420,3780,390,1860,420,3780,420,3780,420,3810,420,6990;
20;76;DEBUG;Pulses=54;Pulses(uSec)=450,3570,390,1830,390,3780,420,3780,420,1860,420,1860,420,1860,420,1860,390,1860,420,3780,390,3780,390,3780,420,3780,420,3780,390,1860,420,3780,420,3780,390,1860,390,1860,420,3780,420,1860,420,3780,420,1860,390,3780,390,3780,420,3810,420,6990;
20;77;DEBUG;Pulses=54;Pulses(uSec)=450,3600,390,3630,420,1860,420,3780,390,3780,390,1860,420,1860,390,1860,420,1860,390,1860,390,3780,420,3780,420,3780,390,3780,420,3780,420,1860,390,3780,390,3780,420,1860,390,1860,390,3780,390,1860,390,3780,390,1860,420,3780,390,3780,390,6990;
Debug logs are catured when pressing tx button. Temperature should be around 23 C and humidity 30 %.
More info
I tried to decode the pulses with help of this https://github.com/merbanan/rtl_433/blo ... prologue.c . There's nothing different in the first lines between different sensors. Looks like some ID values are not detected.
/* Prologue sensor protocol
* also FreeTec NC-7104 sensor for FreeTec Weatherstation NC-7102.
* the sensor sends 36 bits 7 times, before the first packet there is a sync pulse
* the packets are ppm modulated (distance coding) with a pulse of ~500 us
* followed by a short gap of ~2000 us for a 0 bit or a long ~4000 us gap for a
* 1 bit, the sync gap is ~9000 us.
* the data is grouped in 9 nibbles
* [model] [id0] [id1] [flags] [temp0] [temp1] [temp2] [humi0] [humi1]
* model is 1001 (9) or 0110 (5)
* id is a random id that is generated when the sensor starts, could include battery status
* the same batteries often generate the same id
* flags(3) is 0 the battery status, 1 ok, 0 low, first reading always say low
* flags(2) is 1 when the sensor sends a reading when pressing the button on the sensor
* flags(1,0)+1 forms the channel number that can be set by the sensor (1-3)
* temp is 12 bit signed scaled by 10
* humi0 is always 1100 (0x0C) if no humidity sensor is available
* humi1 is always 1100 (0x0C) if no humidity sensor is available
* The sensor can be bought at Clas Ohlson
More info 2
Looks like the 5th bit has to be 0. This means that the sencod hex number of the ID from the left has to be lower than 8. For example ID 9521 is OK because that number 5 is lower than 8.
I have been trying to get that 5th bit to 0 by pressing reset button but it takes some time.
