Cheap Chinese Power Meter made wireless
tastycarp
Target OS: Raspberry Pi
Re: Cheap Chinese Power Meter made wireless
Post by tastycarp » Sunday 20 May 2018 2:25
Raspberry Piet wrote:
Monday 02 October 2017 22:38
Now i flashed espurna 1.9.5 for my ECH1560 Chinese powermeter. (wemos d1-mini inside)
It is showing some values but it is a bit jumpy:
I have done the same mod (wemos mini wired directly) and it is jumpy as well just like your gif. Did you get to the bottom of this?
Raspberry Piet
Post by Raspberry Piet » Sunday 20 May 2018 9:49
No but xoseperez wants to fix it someday issue 596
tastycarp
Post by tastycarp » Monday 21 May 2018 8:07
Ahh Thanks for the info. It sounds like he owns a few ehc1560 now. so hopefully not too far off. I will put mine into the one day project pile!
DaNii78
Post by DaNii78 » Friday 27 July 2018 19:18
Kapee wrote:
Wednesday 20 September 2017 10:37
I ordered three powermeters and all three have a different printed circuit board. The 1st and the 3rd with spi interface, the 2nd with serial interface.
For the 3rd powermeter I made a pcb for the wemos and power supply, it just fitted in height.
How did you wire the 3rd power meter?
Kapee
Post by Kapee » Monday 30 July 2018 13:55
Here is the schematic
3rd powermeter.jpg (80.64 KiB) Viewed 567 times
DaNii78
Post by DaNii78 » Saturday 04 August 2018 12:34
Thanks you so much!
I just recieved a power meter with an unknown chip. It's labeled with "BL6523GX". Does anybody knows if it's compatible or how can be hacked?
Thanks you!
SweetPants
Domoticz version: V4.10055
Post by SweetPants » Saturday 04 August 2018 12:44
Just a remark, I made the same 'mistake' viewtopic.php?f=38&t=7325&start=40#p149833 and added some opto-couplers between the powermeter board and the ESP for safety because I used ESP07 and external antenna's.
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
DaNii78
Post by DaNii78 » Saturday 04 August 2018 13:38
So it's better add the opto-couplers?
SweetPants
Post by SweetPants » Saturday 04 August 2018 14:19
Only if you have external connections (like a WiFi antenna)
DaNii78
Post by DaNii78 » Saturday 11 August 2018 21:30
I can't make it work with a ESP-01...
Anybody has tried with this ESP?
SweetPants
Post by SweetPants » Sunday 12 August 2018 8:50
ESP-01 has not enough memory i think. You probably get compiler/link errors?
DaNii78
Post by DaNii78 » Sunday 12 August 2018 14:41
No, I can compile and the code gets uploaded but I always obtain a 0 value in the voltage measure.
Users browsing this forum: Madgeni and 3 guests
