Domoticz logging the output of a Kostal Piko inverter
niki_lauda
Target OS: Raspberry Pi
Post by niki_lauda » Sunday 28 June 2015 21:26
I made a lua script that logs the output from my solar panels. The actual output I use as a kind lux meter to switch on lights.
It makes use off a Python script piko.py. You can find it here. http://sourceforge.net/projects/piko/files/
I have one problem to solve. Some string manupilation.
And a question how can I get the total energy in Domoticz. Currently only the Current watts and the energy generated today is shown.
By the way if I look in the log at the chart for today it shows the same data as yesterday. Tomorrow it shows the correct data.
Here is it.
    -- Get the actual production data from a Kostal Piko Inverter
    -- Base lua used IsItGonnaRain
    -- Uses Piko.py  http://sourceforge.net/projects/piko/files/
    -- Written in LUA by Hans Roijmans
    -- summer 2015
    -- 26-06-2015 v0.1 Initial release
    -- Todo: routine to get the data between ':' and 'W(h)'
    -- Output of tempfilename = '/var/tmp/piko.tmp'
    -- Total energy    : 11651331 Wh
    -- Today energy    : 13104 Wh
		-- DC Power        : 1454 W
		-- AC Power        : 1342 W
		-- Efficiency      : 92.3%
    -- Domoticz IDX and names of the needed device
    local PIKOIDX = 1121
    -- Script parameter
    -- CommandArray
       read = os.execute('python /home/pi/domoticz/scripts/piko.py --host=10.0.0.2 -p -i -d > /var/tmp/piko.tmp') --
       file = io.open(tempfilename, "r")
       -- Read lines.
       line = file:read("*line")
       total=string.sub(tostring(line),18,27)
       today=string.sub(tostring(line),18,23)
       nowdc=string.sub(tostring(line),18,22)
       nowac=string.sub(tostring(line),18,22)
       file:close()
       commandArray = {['UpdateDevice'] = PIKOIDX .. '|0|' .. nowac .. ';' .. today }
luusje
Domoticz version: V3.5021
Re: Domoticz logging the output of a Kostal Piko inverter
Post by luusje » Tuesday 29 March 2016 10:20
Was just browsing the forum. Did you manage to get the Piko logging fully working? I have one also and would be nice to add to Domoticz.
Greetz
I'm trying
It just doesn't always work
:D
niki_lauda
Post by niki_lauda » Tuesday 29 March 2016 19:10
Ja
Yes
sejonr
Post by sejonr » Friday 05 May 2017 12:42
I tryed to implement this code but i cant get any data from Kostal Inverter 4.2 that i have. I have stored the piko.py in right place and did exactlly as decribed in code above but i get nothing.
I realy need help!!!! I have tryed for several houers. This is my first LUA code.
sejonr
Of cource i changed IP adress
niki_lauda
Post by niki_lauda » Friday 05 May 2017 13:52
Do you run domitcz on a raspberry Pi?
What happens if you run from the commandline
niki_lauda
on a Pi look in /var/temp
sejonr
Post by sejonr » Friday 05 May 2017 22:42
Yes i got the file but i got this message when i run from commandline what is this? Do i need a new file?
File "Piko.py", line 40, in <module>
import MySQLdb as mdb
ImportError: No module named MySQLdb
niki_lauda
Post by niki_lauda » Saturday 06 May 2017 22:22
I think in your case this is the solution.
http://stackoverflow.com/questions/3504 ... ed-mysqldb
First ensure you have a python mysql driver installed:
sudo pip install pymysql
niki_lauda
Post by niki_lauda » Saturday 06 May 2017 22:31
sejonr wrote:Yes i got the file but i got this message when i run from commandline what is this? Do i need a new file?
OR
apt-get install python-mysqldb
sejonr
Post by sejonr » Tuesday 16 May 2017 13:16
Thank you for your help :) :) Everything works now but not kwh.
The Kwh shows the day after (for example sunday kwh is shown on monday) and i cant see kwh per hour .??
niki_lauda
Post by niki_lauda » Tuesday 16 May 2017 21:16
Where is your luascript stored?
Mine is stored in /home/pi/domoticz/scripts/lua and is named script_time_kostal.lua so it runs every minute.
2017-05-16 21:09:02.655 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_kostal.lua
2017-05-16 21:10:04.107 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_kostal.lua
2017-05-16 21:11:01.995 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_kostal.lua
2017-05-16 21:12:02.227 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_kostal.lua
You could try to upload your daily yield to Pvoutput http://www.domoticz.com/wiki/Upload_ene ... o_PVoutput
sejonr
Post by sejonr » Wednesday 17 May 2017 8:54
My Lua is stored under the right meny - settings / more settings/eventhandling
and i selected Lua in stead of Blockly and the lua script is on time (per min)
niki_lauda
Post by niki_lauda » Wednesday 17 May 2017 19:39
try to store the script on the sd card. And name it script_time_kostal.lua
niki_lauda
Post by niki_lauda » Thursday 18 May 2017 18:26
sejonr wrote:My Lua is stored under the right meny - settings / more settings/eventhandling
Did you set the time option under the Lua option in settings / more settings/eventhandling
sejonr
Post by sejonr » Wednesday 11 October 2017 9:08
Ja
Yes
Hi niki
How did you do?? I copyed your lua but get the same problem as you.
Thank you for help :D
jonathan12
Post by jonathan12 » Sunday 31 December 2017 18:32
What am I doing wrong? The temp file is staying empty.
Error in de log:
2017-12-31 17:31:00.300 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_kostal.lua: /home/pi/domoticz/scripts/lua/script_time_kostal.lua:36: attempt to call global 'fileread' (a nil value)
niki_lauda
Post by niki_lauda » Tuesday 15 May 2018 21:01
Error in de log:
Nothing an updated script is attached
script_time_kostal.zip
(1.28 KiB) Downloaded 33 times
twosteps
Post by twosteps » Thursday 23 August 2018 7:48
I have a noob question regarding the connection to the Kostal Inverter:
On my Piko device, I have both Ethernet and RS485 (RJ45 both) connections.
To retrieve the data using the script, do I have to connect to RS485 or ethernet..?
I have a rapberry Pi 3. If RS485 is needed, I guess I need to connect to my Pi using a RS485 card, right?
Many thanks for your help and again sorry for this basic question
Herve
niki_lauda
Post by niki_lauda » Sunday 09 September 2018 10:36
Herve
If you reply to an message you will get an bnotification. I accendentally stumbled over your message.
I connected the PIKO via an Ethernet cable.
Don't excuse yourself for asking a question. Only by asking an question you can learn.
