[MyDomoAtHome] Support thread
anoriel
Target OS: Raspberry Pi
Re: [MyDomoAtHome] Support thread
Post by anoriel » Thursday 05 April 2018 20:49
Hi RedRaven,
Actually no...
I think we need to copy another instance in another folder maybe ?
But this mean everything must be copied, service systems, config files...
What do you think ?
12345caravan
Post by 12345caravan » Sunday 15 April 2018 12:35
After last domoticz update imperihome is not showing my rflink milight devices/switches anymore....
Tryed to reload switches but there gone.
Anyone else have this problem? Or better a solution? :D
Domoticz app is showing them and they are working through the browser so the problem is within imperihome.
kmccor
Post by kmccor » Monday 16 April 2018 11:56
Hi, I've just updated Domoticz to beta build V3.9227 to fix an unrelated issue but now my RGB Yeelights are no longer available as an RGB switch in MyDomoAtHome, although the Dimmer and White Temp for the same lights are. They've worked fine with full RGB functionality up until this point and still work correctly from within Domoticz.
I've updated MyDomoAtHome to version 0.2.36 which has made no difference.
Is there anything I can do to fix this?
Karl
DomoArigato
Post by DomoArigato » Thursday 10 May 2018 16:57
Hi all.
First of all - thanks a lot to everyone using their precious time to create this solution!
Great work.
Have installed domoticz (3.8153) and MyDomoatHome (0.2.36) on a Synology NAS. I used both from jadalh.com
In principle it works like a charm!
One issue I still have - once I add new devices to the domoticz system, I cannot see them in ImperiHome on iOS.
I see and can use the previous devices but not the new ones. The devices are in domoticz and are usable there.
Only when I delete ImperiHome app from phone and start all new (including building new dashboard in ImperiHome app) I see all devices up to that point in time.
When adding devices after that, they are not listed in the devices list on ImperiHome app. So I would have to delete and reinstall the app on the phone again. :o
Anybody having an idea?
Thanks a lot in advance.
marcojpolet
Post by marcojpolet » Sunday 13 May 2018 7:22
If you're missing devices in ImperiHome, you might check the /devices link of your DomoAtHome server (i.e. http://serverip:port/devices). In there you should get a list of all your devices. If you don't see your device there, it for sure won't show up in ImperiHome. If it does, you need to check ImperiHome settings.
Regards,
Marco
DomoArigato
Post by DomoArigato » Sunday 13 May 2018 13:25
Hi back.
Thanks for the support.
I see all those devices in domoticz and I can use them (e.g. switches). Just it seems that my MyDomoAtHome service on the system might not get updates when I create new devices.
After I set up MyDomoAtHome and the ImperiHome app on the phone (all worked great...) I added new devices to domoticz. Only those new ones I cannot see in the ImperiHome app. I can see/use them in domoticz (also see them in "domoticz-ip/#/devices").
Last time I had this issue (after adding two new devices), I tried to stop/start the services (stop MyDomoAtHome, then stop domoticz and restart them both in revers order) result = nothing. ImperiHome app worked well, just not see the newly added devices.
Only when I deleted the ImperiHome app from phone, reinstalled it and set up a new dashboard, I also see the newly added devices and can use them in ImperiHome app.
Seems to me there might be a kind of configuration issue somewhere (e.g. something like "only use previous devices" or something like that....). Looked in ImperiHome app configuration but cannot make any changes there on this behaviour.
Don't know enough of the MyDomoAtHome service on my NAS. Maybe I need to make some config changes there? I just took it, installed it and in ran.
Just think that deleting/reinstalling each time I add new devices might not be the way it is meant to work.
Question is: How can I make it that the ImperiHome app on iOS always gets the actual device list?
Apart from that all works fine.
Maybe someone with same experience? Or a solution (would be even better :) )
Thanks a lot.
DomoArigato
Post by DomoArigato » Sunday 13 May 2018 22:28
Ah well ..... consider my problem as solved!
All is working great - except my brain. :shock: :?
It was me not seeing the ‚reload‘ button in the ImperiHome app. :roll:
Once a clever user press this, the app reloads the actual device list from domoticz and everything is running very smooth.
Shame on me!
Working now! Good guys! Thanks a lot for this solution!
kmccor
Post by kmccor » Thursday 17 May 2018 17:04
Yeah, I've tried that and the RGB switch for all of my RGB devices is no longer showing in the /devices list. I'm assuming that there's been a change in how these devices are handled within Domoticz that stops them working with MDAH.
Regards,
Marco
vulbas
Post by vulbas » Thursday 24 May 2018 10:08
Hello
I can not connect to MDAH anymore :(
it worked well before.
I do not understand. :?
can you help me ?
Xztraz
Post by Xztraz » Thursday 24 May 2018 18:42
Same problem. No devices page on mydomoathome server. Used to work. constantly updating domoticz to latest build and now it's not giving any data to imperihome.
tried the /device page. can't reach(browser gives error)
page in/ works so i assume something is working.
log just repeats:
{"level":"info","message":"OS version: Linux linux 4.1.18-v7+","timestamp":"2018-05-24T16:38:37.762Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.199 in /var/www /","timestamp":"2018-05-24T16:38:37.769Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2018-05-24T16:38:45.390Z"}
{"level":"info","message":"Node version: 4.9.1","timestamp":"2018-05-24T16:38:45.411Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.36","timestamp":"2018-05-24T16:38:45.414Z"}
{"level":"info","message":"OS version: Linux linux 4.1.18-v7+","timestamp":"2018-05-24T16:38:45.416Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.199 in /var/www /","timestamp":"2018-05-24T16:38:45.423Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2018-05-24T16:38:50.884Z"}
{"level":"info","message":"Node version: 4.9.1","timestamp":"2018-05-24T16:38:50.905Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.36","timestamp":"2018-05-24T16:38:50.908Z"}
{"level":"info","message":"OS version: Linux linux 4.1.18-v7+","timestamp":"2018-05-24T16:38:50.910Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.199 in /var/www /","timestamp":"2018-05-24T16:38:50.916Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2018-05-24T16:39:01.408Z"}
{"level":"info","message":"Node version: 4.9.1","timestamp":"2018-05-24T16:39:01.430Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.36","timestamp":"2018-05-24T16:39:01.434Z"}
{"level":"info","message":"OS version: Linux linux 4.1.18-v7+","timestamp":"2018-05-24T16:39:01.437Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.199 in /var/www /","timestamp":"2018-05-24T16:39:01.446Z"}
Also. isn't latest version .37? cant update with apt-get says i have latest
kmccor
Post by kmccor » Friday 25 May 2018 13:26
Having looked through some of the recent changes made in the latest beta of Domoticz this one seems to be the potential culprit -
https://github.com/domoticz/domoticz/issues/2078 - "Feature suggestion: WW / RGB / RGBW / RGBWW dimmers"
There's now a sub-type of RGBWW, I can see within MDAH that the sub-types RGB & RGBW are handled but not RGBWW -
case 'Dimmer':
                                if (data.result[i].SubType == 'RGB') {
                                    //console.log("OK"+data.result[i].SubType);
                                    result.push(DevRGBLight(data.result[i]));
                                } else if (data.result[i].SubType == 'RGBW') {
                                } else {
                                    result.push(DevDimmer(data.result[i]));
I'm far from being a coder but as far as I can tell this may be the cause of my issue.
UPDATE - I've just noticed that I have one RGBW device and that's not showing in /devices either so there must be more to it than I was thinking.
vulbas
Post by vulbas » Friday 25 May 2018 15:05
Hello
can you help me ?
Hello
I tested with a new installation of domoticz, the problem is the same.
V3.9485.
same problem with
v3.9501
hhheeelllppppp mmmmeeeee ppplleeeaassseeee :cry: :D
vulbas
Post by vulbas » Friday 25 May 2018 18:47
i just plugged my pi2, clean install of domoticz with stable version v3.8153 it works
I switch to beta v3.9501 and it does not work anymore. so this is a problem in the beta ....... and the problem is that I need the beta
je viens de rebrancher mon pi2, install propre de domoticz avec la version stable v3.8153 ça fonctionne
je passe en beta v3.9501 et ça ne fonctionne plus. c'est donc bien un probleme dans la beta ....... et le probleme c'est qu'il me faut la beta
a new video
someone else has the same problem on a synology.
with version V3.9478
https://easydomoticz.com/forum/viewtopi ... 622#p54621
