EFERGY API json, energy sensor. advice needed
raxor
Post by raxor » Friday 17 April 2015 21:08
Hi.
Efergy energy meter have a open API to retrieve info.
You only need create a new token for apps:
1- login with your efergy credentials in energyhive (efergy is a energyhive rebranded)
http://www.energyhive.com/settings/tokens
- Click on add token
And you can test json with this token here:
http://www.energyhive.com/content/about/develop
your url with token are like this: http://www.energyhive.com/mobile_proxy/getCurrentValuesSummary?token=xxxxxxxxmytokenxxxxxxxxxx
this url returns exactly this:
[{"cid":"PWER","data":[{"1429296007000":609.385}],"sid":"591051","units":"kWm","age":8}]
My goal is parse "data" 609,385 watts to send every 1 minutes to Energy sensor in Domoticz.
PD: Finally it works, see next post
raxor
Re: EFERGY API json, energy sensor. advice needed
Post by raxor » Monday 20 April 2015 0:27
Finally i solved with jq
How-to install jq:
http://www.domoticz.com/wiki/Battery_le ... ing_system
input
[{"cid":"PWER","data":[{"1429473875000":285.085}],"sid":"591051","units":"kWm","age":12}]
jq -r .[].data`
returns
|cut -f2 -d":"|cut -f1 -d"}"| tr -d ' '`
returns
285.085
finally mi Shellscript working perfectly (change token and domoticz IP and port)
#!/bin/bash
energy=`curl 'http://www.energyhive.com/mobile_proxy/getCurrentValuesSummary?token=xxxxxxxxxxxxxxxxxxxxx' | jq -r .[].data`
resultado=`echo $energy |cut -f2 -d":"|cut -f1 -d"}"| tr -d ' '`
curl -s -i -H "Accept: application/json" "http://192.168.1.xx:8080/json.htm?type=command&param=udevice&idx=26&nvalue=0&svalue=$resultado;$resultado"
I put on crontab run every minute
*/1 *   * * *   root	/home/pi/domoticz/scripts/efergy.sh
korniza
Target OS: Raspberry Pi
Domoticz version: V3.6028
Post by korniza » Thursday 27 August 2015 21:06
I m facing a problem with the script
I can get the results running on web browser, I installed jq 1.5 but i have the following running manual the script:
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100    88    0    88    0     0    357      0 --:--:-- --:--:-- --:--:--   606
HTTP/1.1 200 OK
Content-Length: 24
Content-Type: application/json;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
Access-Control-Allow-Origin: *
   "status" : "ERR"
I m not a linux geek, so what I miss?
>>>> Google Home <<<<<
korniza
Post by korniza » Thursday 27 August 2015 21:33
I found the issue (sorry I m 3 hours user of the platform). I created a dummy hardware and after I created a virtual sensor as power meter. SO, I had tp get the id of new senson and replace it on
http://192.168.1.xx:8080/json.htm?type= ... &[b]idx=26[/b]&nvalue=0&svalue=$resultado;$resultado
so everything is working right now! :D
Thank you for making this "dummy" power meter smart!
>>>> Google Home <<<<<
dpui7736
Domoticz version: 4.9700
Post by dpui7736 » Friday 19 August 2016 11:23
raxor wrote:Finally i solved with jq
How-to install jq:
input
jq -r .[].data`
returns
returns
285.085
#!/bin/bash
Thank you for the script, it works well for me with some changes.
In Raspberry Pi 3:
I install jq with apg-get install jq
Add permissions to execute the script with sudo chmod +x /home/pi/domoticz/scripts/efergy.sh
Edit crontab with crontab -e and add line * * * * * /home/pi/domoticz/scripts/efergy.sh
Snapperud
Post by Snapperud » Tuesday 27 September 2016 20:48
Thanks for the info, very good.
I needed to pick two values, so I did this:
#!/bin/bash
energy=`curl 'http://www.energyhive.com/mobile_proxy/ ... xxxxxxxxxx' | jq -r .[].data`
tot=`echo $energy |cut -f2 -d":"|cut -f1 -d"}"| tr -d ' '`
car=`echo $energy |cut -f3 -d":"|cut -f1 -d"}"| tr -d ' '`
curl -s -i -H "Accept: application/json" "http://192.168.xxx.xxx:8080/json.htm?ty ... =$tot;$tot"
curl -s -i -H "Accept: application/json" "http://192.168.xxx.xxx:8080/json.htm?ty ... =$car;$car"
Ric68
Post by Ric68 » Sunday 23 October 2016 9:53
This was great, but I have a small problem which is probably very easy to solve, but since this is the first time I ever heard of jq, I thought that maybe someone with some more knowledge of jq could help making the script little more robust?
The problem that I have is that the meter is at the limit of the range, and I sometimes receive an error when reading from Efergy
The output is:
{"error":{"id":500,"desc":"Server Error","more":"Unable to get channel data for hid"}}
Instead of not updating the energy meter I get 0 as energy consumption
mungbeans
Post by mungbeans » Wednesday 01 August 2018 7:17
Big thanks for figuring this out and giving us the tutorial.
I just want to add in what I did to get a little more utility out of this bash script.
I created a bash script for crontab to run on bootup called autorun.sh
editing crontab (sudo crontab -e)
@reboot sudo bash /home/pi/domoticz/scripts/autorun.sh
autorun.sh made in the scripts folder containing:
#!/bin/bash
while true; do /home/pi/domoticz/scripts/efergy.sh
  # Do something
  sleep 6;
done
Looking at the API it has a 6 second refresh. I wanted to grab data every 6 seconds so I can log this in Domoticz.
This runs neatly in the background every 6 seconds. No ill effect on the system.
