Is it gonna rain within the next X minutes?
poudenes
Domoticz version: 3.8993
Re: Is it gonna rain within the next X minutes?
Post by poudenes » Wednesday 24 January 2018 13:33
Hi All,
no matter what i do i get a error
2018-01-24 12:31:00.305  LUA: http://gadgets.buienradar.nl/data/raintext/?lat=52.06&lon=4.39
2018-01-24 12:31:00.420  Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_raintext.lua: /home/pi/domoticz/scripts/lua/script_time_raintext.lua:14: attempt to index global 'file' (a nil value)
How can i solve this?
output of the http link:
000|12:30
000|12:35
000|12:40
000|12:45
000|12:50
000|12:55
000|13:00
000|13:05
000|13:10
000|13:15
000|13:20
000|13:25
000|13:30
000|13:35
000|13:40
000|13:45
000|13:50
000|13:55
000|14:00
000|14:05
000|14:10
000|14:15
000|14:20
000|14:25
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
Mace
Domoticz version: 3.8153
Post by Mace » Sunday 28 January 2018 10:42
mvroosmalen wrote:
Tuesday 23 January 2018 8:51
He mace,
In that case change then commandArray['SendNotification']=....... to code to only send to for example pushbullet or change settings.
s6
Mark
Thanks Mark, I however have no clue on how to doe that... ;)
mvroosmalen
Target OS: Raspberry Pi
Post by mvroosmalen » Sunday 28 January 2018 12:05
Hi Mace,
Google is your friend :-)..... viewtopic.php?t=8231
create a bash file pushbullet.sh:
#!/bin/bash
api=<Put_Your_API_KEY_HERE>
title=$1
body=$2
curl -u $api: https://api.pushbullet.com/v2/pushes -d type=note -d title=$title -d body=$body
and in the script:
os.execute('/home/pi/domoticz/scripts/pushbullet.sh "Rain alert" "blabla......."')
or directly use this as a HTML code in the script...
s6 Mark
bobke77
Post by bobke77 » Tuesday 30 January 2018 14:07
SInce I'm new here (or call me NOOB :D ) I just used the script as mentioned in the start post.
On my dashboard I get the text message : Regen verwacht, so the text file seems to be working (took me some time to figure out I had to use the chmod 0666).
Now I've got one problem: When I look in the Log it says:
2018-01-30 12:57:00.239 LUA: -- Regen verwacht(0-255 hoe hoger hoe meer regen): nan binnen 15 minuten.
Looking further iI notice that in the /var/tmp/ folder I can't open the rain.tmp file
It says: Object moved, this document can be found here
Then I get forwarded in Chromium and I can see the values.
How can I solve this ?
poudenes
Post by poudenes » Tuesday 30 January 2018 22:33
Does someone have at the full script for me that work on dzVents 2.4.0?
mickmack82
Post by mickmack82 » Wednesday 31 January 2018 16:09
Try to add the -L paramter in the curl command: read = os.execute('curl -L -s -o '..tempfilename..' "'..url..'"')
This enable follow redirects using the location header flag
bobke77
Post by bobke77 » Wednesday 31 January 2018 16:26
That's the one !
I had already changed this, but made it -s -o -L instead of -L -s -o :lol: :lol:
Many thanks mickmack !!!!!
poudenes
Post by poudenes » Wednesday 31 January 2018 16:38
the -L parameter also solved my NIL problem :)
EdwinK
Post by EdwinK » Wednesday 31 January 2018 17:17
Now noticing an error regarding
2018-01-31 16:09:12.436 Error: EventSystem: in Regen: [string "---------------------------------------------..."]:27: module 'socket.http' not found:
no field package.preload['socket.http']
no file '/usr/local/share/lua/5.2/socket/http.lua'
no file '/usr/local/share/lua/5.2/socket/http/init.lua'
no file '/usr/local/lib/lua/5.2/socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http/init.lua'
no file './socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './socket/http.so'
no file '/usr/local/lib/lua/5.2/socket.so'
no file './socket.so'
Didn't check often so don't know when this started to happen. Thought I had to do a sudo apt-get install socket.http, but that doesn't seem to work.
Now what?
Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | RFxcom | Dashticz V2
mvroosmalen
Post by mvroosmalen » Wednesday 31 January 2018 20:52
You need to install the socket library and supporting code somewhere that Lua 5.2 can find.
It is explained on this page http://www.domoticz.com/wiki/Philips_Hu ... ng_Colours and the necassary supporting libraries are attached to the linked forum message.
Mark
EdwinK
Post by EdwinK » Thursday 01 February 2018 10:27
But it used to work
jvdz
Domoticz version: Stable
Post by jvdz » Thursday 01 February 2018 12:50
But it used to work
.. and then the next line should read: "and I haven't changed anything".. right? :D
In general these things happen when you either initially do an install or changed things on your system.
Jos
EdwinK
Post by EdwinK » Thursday 01 February 2018 14:57
But it used to work
Jos
Almost ;) But I'm getting the hint.
EdwinK
Post by EdwinK » Sunday 11 February 2018 19:06
Still no luck :(
mvroosmalen
Post by mvroosmalen » Sunday 11 February 2018 19:59
still about the socket?? Please list the files found in /usr/local/share/lua/5.2 and dir below. It should list all the needed files...
EdwinK
Post by EdwinK » Monday 12 February 2018 11:05
Nope, this time it's the following.
2018-02-12 10:03:00.440 Error: EventSystem: in Regen: [string "---------------------------------------------..."]:45: attempt to call global 'UrlEncode' (a nil value)
2018-02-12 10:04:00.360 Error: EventSystem: in Regen: [string "---------------------------------------------..."]:45: attempt to call global 'UrlEncode' (a nil value)
Had to look it up again, as I was trying several different scripts at different times.
EdwinK
Post by EdwinK » Monday 12 February 2018 11:19
And also this still
./buienradar.py
File "./buienradar.py", line 23, in <module>
import ssl
File "/usr/local/lib/python3.5/ssl.py", line 98, in <module>
import _ssl # if we can't import it, let the error propagate
ImportError: No module named '_ssl'
domoticz@domo-server:/usr/local/share/lua/5.2 $ ls
ansicolors.lua luacolors.lua mobdebug.lua socket.lua
ltn12.lua mime.lua socket
mvroosmalen
Post by mvroosmalen » Monday 12 February 2018 12:59
Hi Edwin,
You miss the relevant files in /usr/local/share/lua/5.2. It should list:
socket
ssl
ansicolors.lua
JSON.lua
ltn12.lua
luacolors.lua
mime.lua
mobdebug.lua
socket.lua
ssl.lua
you could reinstall...
Mark
Venzent
Post by Venzent » Wednesday 30 May 2018 20:56
I had this script previous and it was running fine. Re-installed Domoticz and did create this script again, but it just won't run.
Created a dummy switch "Rain expected"
Copy-pasted the script in the eventsystem and added my lat and lon (52.39 and 5.30).
Created the /var/tmp/rain.tmp file and chmodded it to 0777.
Sometimes when fiddling around I see it trigger once after changing or re-creating the script, but only once, the next minute is not triggered.
Currently it is not triggered at all.
I saved the script as Rain expected, type Lua and trigger Time. The script is activated and under settings, other, Event system "not active" is not checked....
Any thoughts?
Venzent
Post by Venzent » Wednesday 30 May 2018 21:09
Any thoughts?
I just enabled debugging and after 3 minutes i see this, so it did run (once), but now 5 minutes later, it didn't run again.
2018-05-30 21:00:00.532 dzVents: https://gadgets.buienradar.nl/data/rain ... 9&lon=5.30
2018-05-30 21:00:00.896 dzVents: Line:000|21:00
2018-05-30 21:00:00.896 dzVents: Linetime: 21:00
2018-05-30 21:00:00.896 dzVents: 0
2018-05-30 21:00:00.896 dzVents: Line:000|21:05
2018-05-30 21:00:00.896 dzVents: Linetime: 21:05
2018-05-30 21:00:00.896 dzVents: 300
2018-05-30 21:00:00.896 dzVents: Line in time range found
2018-05-30 21:00:00.896 dzVents: Rain in timerange: 0
2018-05-30 21:00:00.896 dzVents: Total rain now: 0
2018-05-30 21:00:00.896 dzVents: Line:000|21:10
2018-05-30 21:00:00.896 dzVents: Linetime: 21:10
2018-05-30 21:00:00.897 dzVents: 600
2018-05-30 21:00:00.897 dzVents: Line in time range found
2018-05-30 21:00:00.897 dzVents: Rain in timerange: 0
2018-05-30 21:00:00.897 dzVents: Total rain now: 0
2018-05-30 21:00:00.897 dzVents: Line:000|21:15
2018-05-30 21:00:00.897 dzVents: Linetime: 21:15
2018-05-30 21:00:00.897 dzVents: 900
2018-05-30 21:00:00.897 dzVents: Line:000|21:20
2018-05-30 21:00:00.897 dzVents: Linetime: 21:20
2018-05-30 21:00:00.897 dzVents: 1200
2018-05-30 21:00:00.897 dzVents: Line:000|21:25
2018-05-30 21:00:00.897 dzVents: Linetime: 21:25
2018-05-30 21:00:00.897 dzVents: 1500
2018-05-30 21:00:00.897 dzVents: Line:000|21:30
2018-05-30 21:00:00.897 dzVents: Linetime: 21:30
2018-05-30 21:00:00.897 dzVents: 1800
2018-05-30 21:00:00.897 dzVents: Line:000|21:35
2018-05-30 21:00:00.897 dzVents: Linetime: 21:35
2018-05-30 21:00:00.897 dzVents: 2100
2018-05-30 21:00:00.897 dzVents: Line:000|21:40
2018-05-30 21:00:00.898 dzVents: Linetime: 21:40
2018-05-30 21:00:00.898 dzVents: 2400
2018-05-30 21:00:00.898 dzVents: Line:000|21:45
2018-05-30 21:00:00.898 dzVents: Linetime: 21:45
2018-05-30 21:00:00.898 dzVents: 2700
2018-05-30 21:00:00.898 dzVents: Line:000|21:50
2018-05-30 21:00:00.898 dzVents: Linetime: 21:50
2018-05-30 21:00:00.898 dzVents: 3000
2018-05-30 21:00:00.898 dzVents: Line:000|21:55
2018-05-30 21:00:00.898 dzVents: Linetime: 21:55
2018-05-30 21:00:00.898 dzVents: 3300
2018-05-30 21:00:00.898 dzVents: Line:000|22:00
2018-05-30 21:00:00.898 dzVents: Linetime: 22:00
2018-05-30 21:00:00.898 dzVents: 3600
2018-05-30 21:00:00.898 dzVents: Line:000|22:05
2018-05-30 21:00:00.898 dzVents: Linetime: 22:05
2018-05-30 21:00:00.898 dzVents: 3900
2018-05-30 21:00:00.898 dzVents: Line:000|22:10
2018-05-30 21:00:00.898 dzVents: Linetime: 22:10
2018-05-30 21:00:00.898 dzVents: 4200
2018-05-30 21:00:00.898 dzVents: Line:000|22:15
2018-05-30 21:00:00.898 dzVents: Linetime: 22:15
2018-05-30 21:00:00.898 dzVents: 4500
2018-05-30 21:00:00.898 dzVents: Line:000|22:20
2018-05-30 21:00:00.898 dzVents: Linetime: 22:20
2018-05-30 21:00:00.898 dzVents: 4800
2018-05-30 21:00:00.899 dzVents: Line:000|22:25
2018-05-30 21:00:00.899 dzVents: Linetime: 22:25
2018-05-30 21:00:00.899 dzVents: 5100
2018-05-30 21:00:00.899 dzVents: Line:000|22:30
2018-05-30 21:00:00.899 dzVents: Linetime: 22:30
2018-05-30 21:00:00.899 dzVents: 5400
2018-05-30 21:00:00.899 dzVents: Line:000|22:35
2018-05-30 21:00:00.899 dzVents: Linetime: 22:35
2018-05-30 21:00:00.899 dzVents: 5700
2018-05-30 21:00:00.899 dzVents: Line:000|22:40
2018-05-30 21:00:00.899 dzVents: Linetime: 22:40
2018-05-30 21:00:00.899 dzVents: 6000
2018-05-30 21:00:00.899 dzVents: Line:000|22:45
2018-05-30 21:00:00.899 dzVents: Linetime: 22:45
2018-05-30 21:00:00.899 dzVents: 6300
2018-05-30 21:00:00.899 dzVents: Line:000|22:50
2018-05-30 21:00:00.899 dzVents: Linetime: 22:50
2018-05-30 21:00:00.899 dzVents: 6600
2018-05-30 21:00:00.899 dzVents: Line:000|22:55
2018-05-30 21:00:00.899 dzVents: Linetime: 22:55
2018-05-30 21:00:00.899 dzVents: 6900
2018-05-30 21:00:00.899 dzVents: Regen verwacht: 0 mm binnen 20 minuten.
