BETA: Browser Cache refresh failed.
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
johanahlen
Domoticz version: 3.5075
Re: BETA: Browser Cache refresh failed.
Post by johanahlen » Friday 22 April 2016 9:22
I had the cache issue when accessing domoticz behind an nginx https proxy, even though I pointed my proxy to domoticz http on port 8080 I still got the error. I trired a bunch of restarts etc. but once I put the same certificate I have for nginx in the domoticz server_cert.pem it went away and I haven't seen the issue in a while.
edwin72
Post by edwin72 » Wednesday 22 February 2017 14:09
Yesterday updated Domoticz with latest beta. After that I could not connect to domoticz anymore. The browsers gave the cache refresh failed error.
What helped me:
cd domoticz
./updatebeta
I am running domoticz on a raspberry pi 2.
zanco
Target OS: Raspberry Pi
Post by zanco » Monday 20 March 2017 21:55
edwin72 wrote:Yesterday updated Domoticz with latest beta. After that I could not connect to domoticz anymore. The browsers gave the cache refresh failed error.
What helped me:
cd domoticz
./updatebeta
Thanks ! That saved me from a lot of headaches !
Regards,
Ben
Jethz
Post by Jethz » Thursday 25 May 2017 21:34
Does anyone have the same problem again with the latest beta?
zicht
Domoticz version: 3.8xxx
Post by zicht » Monday 29 May 2017 13:10
Jethz wrote:Does anyone have the same problem again with the latest beta?
Not over here.
Only accros https but that is normal behaviour (due to login a 404 error)
If you are on chrome you can rightclick and choose inspect, There wil be a clue of the cause in console log
Rpi & Win x64. Using : cam's,Nest,RFXCom,Kaku,LaCrosse,RFY,IsAlive,Dummy,Wether Underground, standard Lua, Curl on windows,Domoticz Android App & Tasker,
"The only source of knowledge is experience (A.Einstein)"
pbakkers
Domoticz version: 3.8153
Post by pbakkers » Tuesday 12 December 2017 11:35
I have this problem when I was trying too add some devices.
Domotcs asks for username and password. Then I get this message
I'am using RaspberryPI3, RFXcom, and KAKU switches
last new version of Domoticz
regards Peter
ibniba
Post by ibniba » Wednesday 13 December 2017 2:17
I have the same problem - I have cleared the cache
V3.8153
Windows 10
Plugin/Hardware - sorry I don't know what this means.
Description according to inspect:
Application Cache Progress event (578 of 578)
:8080/#/Dashboard:1 Application Cache Cached event
jquery-1.12.0.min.js:4 GET http://127.0.0.1:8080/json.htm?type=dev ... 1513123775 net::ERR_CONNECTION_REFUSED
send @ jquery-1.12.0.min.js:4
ajax @ jquery-1.12.0.min.js:4
RefreshFavorites @ DashboardController.js:113
(anonymous) @ DashboardController.js:4234
n @ angular.min.js:107
$eval @ angular.min.js:145
$digest @ angular.min.js:142
$apply @ angular.min.js:146
(anonymous) @ angular.min.js:107
astrapowerrr
Post by astrapowerrr » Wednesday 03 January 2018 0:03
hi all,
little bit in a panic here.
this night i am triong to make a copy of my sd card for backup.
now domoticz is not working anymore.
domoticz is ofline and i get the same as i see the picture before.
it is complete dead look like it...
i unplugged already some lights to shutdown and i have a toilet now without lightning...
please help
error is manifest fetch failed http://192.168.xxx.xxx:8080 html5.appcache
edit: yesterday i was trying to get ip camera motion to work .
i think this was om the same ip/port or something.
i typed localhost:8080 and i came to settings of the motion service.
so same port was confussing for me so stopped the motion servive and rebooted now domoticz is not offline anymore..
so this was a mixed up ip port thing... i think
any thoughts on this?
advokatb
Post by advokatb » Thursday 12 April 2018 14:34
I've just changed port to 8899 and all starts working
Hansbit
Post by Hansbit » Thursday 14 June 2018 9:13
When browser cache fails on specific line number, you could check that line/file in html5.appcache
In my example, line 146 of 586 would not load. Change to your line number in error-message. (Don't forget to add the 'p')
grep -v '^$\|^\s*\#' ~/domoticz/www/html5.appcache | grep -Ev '^([A-Z]|.$)' | sed -n '146p'
In my case there was a problem with custom icons. Removed these custom icons in het Domoticz settings and problem was solved...
Regards,
Hans
Charley
Domoticz version: V3.9030
Post by Charley » Thursday 14 June 2018 14:40
I have started Google Dev Tools and it shows me while this error appears some json requesteds are not loaded.
Users browsing this forum: No registered users and 14 guests
