BETA: Browser Cache refresh failed.
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
thorbj
Target OS: Raspberry Pi
Post by thorbj » Monday 26 January 2015 14:33
After upgradeing BETA versjon to V2.2245, I get a red box in my upper right corner saying "Browser Cache refresh failed. Loaded 498 out of 502 files Resource fetch http://www.my-address.com/views/utility.html"
I don't know if it is a bug, or my browsers thats giving me problems. I did reset my browsers cache after upgrade due to domoticz giving me the "Offline" message.
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
Siewert308SW
Re: BETA: Browser Cache refresh failed.
Post by Siewert308SW » Monday 26 January 2015 16:03
same here, same version and all browsers...
Setup:
- RPi3 - PIco HV3.0A / Domo Beta 3.9XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco HV3.0A / PiHole / PiVPN / NAS / Print Server
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
MyDomoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
geantvert
Post by geantvert » Tuesday 27 January 2015 19:57
Same issue with same version
bizziebis
Domoticz version: 3.8805
Post by bizziebis » Tuesday 27 January 2015 21:55
If you use Chrome browser you can right click on the website and select "inspect element". If you change to the tab "console" you can see which element fails to load. Maybe it will give you some information about the cause.
kivster
Post by kivster » Wednesday 28 January 2015 15:25
I'm also getting this problem, regardless of browser or operating system.
The console in Chrome reveals that it is failing each time on html5.appcache
Document was loaded from Application Cache with manifest https://*****/html5.appcache
(index):1 Application Cache Checking event
(index):1 Application Cache Error event: Manifest fetch failed (401) https://*****/html5.appcache
The error is coming from line 2 of index.html:
<!DOCTYPE html>
<html manifest="html5.appcache">
I can see in commit [r2239] the following comment was made "Added error event to appcache" to these two files:
changed	/trunk/www/index.html
changed	/trunk/www/html5.appcache
+			}, false);
+			window.applicationCache.addEventListener('error', function(e)
+				var errText = $.i18n('Browser Cache refresh failed.');
+				errText += (typeof($.cachecount) != 'undefined') ? '<br>Loaded ' + $.cachecount + ' of ' + $.cachetotal + ' files' : '';
+				errText += (typeof(e.message) != 'undefined') ? '<br>' + e.message : '';
+				ClearNotifyCacheRefresh();
+				generate_noty('error', errText, false);
+			}, false);
+			window.applicationCache.addEventListener('progress', function(e)
+				$.cachecount=e.loaded
+				$.cachetotal=e.total
http://sourceforge.net/p/domoticz/code/2239/
So either:
1. The error has always happened and the new error handling message in [r2239] is exposing it.
2. The problem is new.
Last edited by kivster on Wednesday 04 February 2015 13:32, edited 2 times in total.
Raspberry Pi + Domoticz + Aeon Labs Z-Wave USB
1x Aeon multi-sensor, 1x Popp dimmer, 1x Fibaro dimmer, HRT4-ZW thermostat/ASR-ZW receiver, home-made oil tank monitor - http://www.domoticz.com/forum/viewtopic.php?f=38&t=7275
bbqkees
Domoticz version: 3.8x
Post by bbqkees » Thursday 29 January 2015 12:45
I have the same issue.
But it would be a nice option to get rid of these cache popups all together.
They are a bit annoying, they do not add a single piece of useful information to the user experience.
Intel NUC-> Philips Hue, Aeon Zwave stick V2, Qubino, Fibaro, Everspring, Philio, RFXCom, X10, Harmony Hub, Xiaomi Flora + Gateway, BS440. And P1 / Resol VBus / Nefit EMS bus / DHT21 / DS18B20 / Sonoff / I2C display, all via Arduino/ESP8266.
Dnpwwo
Post by Dnpwwo » Thursday 29 January 2015 22:55
So either:
Number 1 I believe. Prior to r2239 you would have seen the 'Refreshing Browser Cache...' popup but the popup would never have closed itself (which it does after a successful refresh) and you had to click on it to close it. I saw that on Chrome and my iPad a lot and never knew what was going on.
As you can see from the code extracted below, the 'red popup' will only ever be shown when the browser throws an 'error' event so this is not a bug but may be showing up issues that people have had for a while that may cause strange behaviors (particularly after updates).
Domoticz makes extensive use of the application cache, surely it is better to know if it isn't working properly?
groetg
Domoticz version: V2.4025
Post by groetg » Sunday 01 February 2015 19:48
Same problem too. After the update I got online the domoticz offline message.
Is iT possible too downgrade to previous version?
Master: RPI Model 2B
Sub 1: RPI Model 2B
RFX transmitter/receiver 433 Mhz
13 KAKU units (3 window sensors, 1 door sensor, 7 light switches, 1 dusk sensor, 1 motion sensor)
4 IP cam
Meteostick
OTGW
P1 cable
Davis Vantage Pro weatherstation (incl. solar/UV)
Whatsek
Domoticz version: Latest B
Post by Whatsek » Sunday 01 February 2015 22:24
groetg wrote:Same problem too. After the update I got online the domoticz offline message.
Just start the domoticz service again, login with ssh and:
sudo service domoticz.sh start
Check if it is running:
sudo service domoticz.sh status
If it stops again, start it a few times until it stays started.
a3vd
Post by a3vd » Monday 02 February 2015 15:38
Same (Manifest fetch failed (401)) problem here, what can we do to find and eliminate the problem ? :?:
Raspberry B / Raspberry B+ / Raspberry 2 / Raspberry 3 / Raspberry 3+
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12
Several Kaku switches/ Weather Underground / Razberry / 2 Everspring 142 dimmers
groetg
Post by groetg » Tuesday 03 February 2015 20:37
The problems dissapeared when I updated to V2.2252 for just a just a few days. Now the problem is back :cry:
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Henri
Post by Henri » Tuesday 03 February 2015 23:09
I was trying 2.2252 and the Problem is still there, i did no upgrade i installed from scratch :-(
If i use No Authentication the cache works (beside the blue message that stays on the screen), but if i use Login Page Authentication it doesnt work.
groetg
Post by groetg » Wednesday 04 February 2015 9:41
Domoticz 'hangs' all the time now, a few times a day I SSH to Domoticz and start the service again. Is there no permanent solution? Or do I have to be a little more patient?
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
kivster
Post by kivster » Wednesday 04 February 2015 14:23
I think Domoticz hanging for you is a different probelm to the cache error issue.
When the Blue message stays on the screen it is effectively the same problem as the red error message appearing. I.e. A component in the cache fails to update and either a) the blue "updating cache" message never goes away or b) the red error message is triggered.
The problem is intermittent for me too. I think when Domoticz is updated it goes away for a while, but I'll need to confirm that.
groetg
Post by groetg » Wednesday 04 February 2015 21:54
I had a safari link on my iPhone to domoticz and Today almost everytime when i logged in from my iPhone i got the red message and domoticz stopped. I deleted the link on homescreen and use now, for a test, Google Chrome iOS app to enter domoticz. I Will keep hou posted
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
groetg
Post by groetg » Wednesday 04 February 2015 21:56
No that is also not the solution. After a refresh i got the red screen again and domoticz stopped
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
groetg
Post by groetg » Wednesday 04 February 2015 23:22
I am really sick About iT.
I am going to clean the rpi and build a New sd card with an Old release tomorrow.
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
webster
Post by webster » Thursday 05 February 2015 11:18
I have the red popup when i login from external ip just click it away and domoticz is working fine for me
RPI B+
RPI 2
Fibaro motion sensors , Philips Hue, Z-Wave dimmers, Eneco Toon
Honeywell Evohome 1-Wire Wifi sensors
Dnpwwo
Post by Dnpwwo » Thursday 05 February 2015 15:04
I have managed to reproduce this as well. Kivster is correct that the red message only appears when the cache load fails. Previously the blue one would have just stayed there.
That said, I've uploaded a new beta version where the red one will only stay for a second and then force a window refresh. Sadly this will actually just hides issues because if anything fails during a cache refresh, it will dump the new content and use 100% of the old cache .
Dnpwwo
Post by Dnpwwo » Friday 06 February 2015 1:42
I've managed to reproduce this again and the last fix has made thing worse not better, I will back it out in a few hours.
Users browsing this forum: felix63 and 2 guests
