Disable log in some device
jackslayter
Target OS: Raspberry Pi
Domoticz version: LastBeta
Post by jackslayter » Thursday 09 October 2014 10:37
Its possible to add in roadmap an option for disable log in some device (virtual device or information device) ?
Thank you
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
Thyraz
Re: Disable log in some device
Post by Thyraz » Tuesday 01 September 2015 14:56
Would love to see that too. ;)
I like to keep temperature data as long as possible but other devices like motion sensors in every room are more sensible.
It just feels wrong if you try to avoid services that track you in the internet and then implementing your own tracking system at home. ;)
jackslayter
Post by jackslayter » Tuesday 24 November 2015 16:12
its possible to add this function , my memory card want it ;)
jannl
Post by jannl » Tuesday 24 November 2015 16:17
You can set the log time to a very short period of time or is that not what you mean?
jackslayter
Post by jackslayter » Tuesday 24 November 2015 16:18
yes and no, I would like disable log in device you I choice
roblom
Post by roblom » Thursday 26 November 2015 23:03
jackslayter wrote:its possible to add this function , my memory card want it ;)
mine too, there is a pulse counter with more than 2.400.000 log records where now the database is more than 120MB so also a lot of DB backups of more than 120MB so no space left on my SD. I try to remove the records but that takes about a day for 50.000 records... so yes i like this disable log functionality.
jackslayter
Post by jackslayter » Wednesday 02 December 2015 16:17
its possible to remove log by command (in script) ?
olafmarcos
Domoticz version: 6277
Post by olafmarcos » Monday 05 December 2016 23:01
Up!
Any advance on disable logging?
Regards,
Olaf
Flopp
Post by Flopp » Monday 05 December 2016 23:37
I also would like to disable log for e.g. Pulse counter and other devices that sends data every minute or more often.
+1
Egregius
Post by Egregius » Monday 05 December 2016 23:43
You could opt to remove entries of devices you don't want.
I remove every night quite a lot. All unused device entries, all entries older than 1 day and for some tables everything.
<?php
$db = new SQLite3('/volume1/@appstore/domoticz/var/domoticz.db');
$clean = strftime("%G-%m-%d %k:%M:%S",time()-86400);
$tables = array( 'MultiMeter',
                'MultiMeter_Calendar',
                'Percentage',
                'Percentage_Calendar',
                'Rain',
                'Rain_Calendar',
                'Temperature',
                'UV',
                'UV_Calendar',
                'Wind',
                'Wind_Calendar');
foreach($tables as $table)
    $query=$db->exec("DELETE FROM $table WHERE DeviceRowID not in (select ID from DeviceStatus where Used = 1)");
    if ($query)
        $rows = $db->changes();
        if($rows>0)
            echo $rows." rows removed from $table<br/>";
    $query=$db->exec("DELETE FROM $table WHERE Date < '$clean'");
    if ($query)
        $rows=$db->changes();
        if($rows>0)
$tables = array('Temperature_Calendar','Meter','Meter_Calendar','LightingLog');
    $query=$db->exec("DELETE FROM $table");
    if ($query)
        if($rows>0)
$sql = 'VACUUM;';
if(!$result = $db->exec($sql))
    die('There was an error running the query [' . $db->error . ']');
Cleaning of specific devices:
$query=$db->exec("DELETE FROM $table WHERE DeviceRowID in (10,20,30)");
if ($query)
    if($rows>0)
You're database will be lots smaller, faster, easier to handle, safer,...
Of course: use at your own risk, above removes a lot!
olafmarcos
Post by olafmarcos » Thursday 07 June 2018 23:58
Umm, i think the question it isn't how to remove logs but disable them...
In my case, it is due a Hue lights system that is sync with the TV. Every change in tv light makes a log in the lights devices that are wasting my NAS disks.
Hoping this funcionality come to us in near future to extend the live of expensive disks/sd memories.
Regards,
