Eternal pool probe wifth Wemos D1 ESP8266 & solar power
dyter
Domoticz version: 8841
Post by dyter » Saturday 08 December 2018 18:43
I realized an eternal pool probe for measure PH and Temp, the Wemos is connected in parallel with the battery on the 5V input
The regulation is done thanks to the rules of ESPEasy without the need of electronic regulator, if the battery voltage becomes under 4.1V, the ESP goes to sleep every 30 minutes, else the permanent consumption of the wifi prevents the battery to not exceed 4.1V (propertional to the dimensioning of the solar panel):
"on System#Boot do
timerSet,1,30
endon
On Rules#Timer=1 Do
if [Battery#Volts]<4.1
deepSleep,1800
endif
timerSet,1,300
endon"
This need a voltage divider bridge on TOUT input of Wemos for measure the voltage battery input named "Battery" and "Volts" for the unit case:
