Error: Exception starting shared server: bind: Address already in use
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
funky
Post by funky » Saturday 08 December 2018 18:09
Every time I reboot the raspberry pi I get the following error:
i have no idea how to fix this. Already reinstalled Domoticz.. but no help.
Hopefully somebody can help me.
2018-12-08 16:52:21.976 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-12-08 16:52:21.976 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-12-08 16:52:21.976 Status: Startup Path: /home/pi/domoticz/
2018-12-08 16:52:22.034 Status: EventSystem: reset all events...
2018-12-08 16:52:22.122 Status: PluginSystem: Started, Python version '3.5.3'.
2018-12-08 16:52:22.132 Status: WebServer(HTTP) started on address: :: with port 8080
2018-12-08 16:52:22.142 Status: WebServer(SSL) started on address: :: with port 443
2018-12-08 16:52:22.143 Status: Proxymanager started.
2018-12-08 16:52:22.236 Status: RxQueue: queue worker started...
 >> HERE IS DE ERROR: 2018-12-08 16:52:22.235 Error: Exception starting shared server: bind: Address already in use
2018-12-08 16:52:24.237 Status: P1 Smart Meter: Using serial port: /dev/ttyUSB_P1
2018-12-08 16:52:24.241 Status: EventSystem: reset all events...
2018-12-08 16:52:24.241 Status: EventSystem: reset all device statuses...
2018-12-08 16:52:24.369 Status: Python EventSystem: Initalizing event module.
2018-12-08 16:52:24.369 Status: EventSystem: Started
2018-12-08 16:52:24.369 Status: EventSystem: Queue thread started...
2018-12-08 16:52:24.536 Status: PluginSystem: Entering work loop.
2018-12-08 16:52:24.753 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2018-12-08 16:52:24.755 Status: OpenZWave: Starting...
2018-12-08 16:52:24.755 Status: OpenZWave: Version: 1.4-2888-g54682370-dirty
2018-12-08 16:52:24.970 Status: OpenZWave: Driver Ready
2018-12-08 16:52:25.240 Status: RFXCOM: Using serial port: /dev/ttyUSB_RFX
2018-12-08 16:52:28.490 Status: P1 Smart Meter: Meter reports as DSMR 4.2
2018-12-08 16:52:29.049 Status: P1 Smart Meter: Found gas meter on M-Bus channel 1
2018-12-08 16:52:55.830 Status: OpenZWave: Received timeout notification from HomeID: 3849606008, NodeID: 3 (0x03)
2018-12-08 16:53:02.036 Status: Notification sent (Email)
2018-12-08 16:53:06.057 Status: OpenZWave: Received timeout notification from HomeID: 3849606008, NodeID: 4 (0x04)
2018-12-08 16:53:16.366 Status: OpenZWave: Received timeout notification from HomeID: 3849606008, NodeID: 5 (0x05)
2018-12-08 16:53:16.596 Status: OpenZWave: Awake Nodes queried
SweetPants
Domoticz version: V4.10267
Re: Error: Exception starting shared server: bind: Address already in use
Post by SweetPants » Saturday 08 December 2018 19:18
Something else running on port 443 or 8080?
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
funky
Post by funky » Saturday 08 December 2018 21:03
No there are no services running on port 8080 of 443.
SweetPants
Post by SweetPants » Sunday 09 December 2018 11:53
Are you using a slave domoticz server? The message is comming from the tcpserver/TCPServer trying to start. Check port 6144 also
funky
Post by funky » Sunday 09 December 2018 12:07
This a are all my used ports.
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
tcp6       0      0 :::8080                 :::*                    LISTEN      -
tcp6       0      0 :::22                   :::*                    LISTEN      -
tcp6       0      0 :::8090                 :::*                    LISTEN      -
udp        0      0 0.0.0.0:68              0.0.0.0:*                           -
udp        0      0 0.0.0.0:54421           0.0.0.0:*                           -
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           -
udp6       0      0 :::60778                :::*                                -
udp6       0      0 :::546                  :::*                                -
udp6       0      0 :::5353                 :::*                                -
Users browsing this forum: al300kr and 1 guest
