Bug Ubuntu Mate ( with version 4.10276 Domoticz) plant RFXCOM (red light fixed)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pat054
Target OS: Raspberry Pi
Domoticz version: 4.10102
Post by pat054 » Friday 07 December 2018 20:27
Hello everyone,
Version: 4.10263 à 4.10276
Platform: Ubuntu Mate 18.04
Plugin/Hardware: RPI3
the current beta versions of Domoticz plant the RFXCOM RFXtrx433E hardware. The indicator of the case changes to solid red.
And the RFX hardware in Domoticz has version 25 instead of 1025. That's balo!
When will it stop?
The only way is to reinstall the site's RFXtrx433E configuration software. It's chaos
Someone have another idea?
Last edited by pat054 on Saturday 15 December 2018 13:50, edited 6 times in total.
pat054
Bug beta version 4.10266 plant RFXCOM (red light fixed)
Post by pat054 » Saturday 08 December 2018 11:16
Version: 4.10266
I have just updated Domoticz with its beta version 4.10266: my RFXtrx433E has its red light fixed when restarting Domoticz.
When will we have a Domoticz that works without disrupting RFXCOM?
SweetPants
Domoticz version: V4.10278
Re: Bug beta version 4.10266 plant RFXCOM (red light fixed)
Post by SweetPants » Saturday 08 December 2018 15:31
We already have for a long time. Your the first I hear (read) of that has this issue. Anyone else?
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
pat054
Post by pat054 » Sunday 09 December 2018 11:21
Hello SweetPants,
Version: 4.10266
the problem is this: after a good overnight operation of Domoticz and RFXCOM, I decided to stop and restart Domoticz by "sudo service domoticz stop and start". The LED of the RFXtrx433E is in solid red. The RFXCOM hardware in Domoticz "Settings / Hardware" presents a version to "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver Version: 25 " while the version before the Domoticz shutdown was" RFXCOM - RFXtrx433 USB 433.92MHz Transceiver Version: Ext / 1025 ".
Why this problem?
For me, there is a problem Domoticz!
My only way to restore the RFXtrx433E version is to unplug and reconnect the RFX433E so that the LED power off and then to do a "firmware update" in Domoticz file RFXtrx433_Ext_1025.hex.
Bizard: no?
SweetPants
Post by SweetPants » Sunday 09 December 2018 11:35
Waht happens if you try a RFXcom firmware upgrade with the update tool(s) supplied by RFXcom? http://www.rfxcom.com/epages/78165469.s ... /Downloads
pat054
Post by pat054 » Sunday 09 December 2018 12:20
I do not have a PC so no Windows. I only have an RPI3 on ​​Ubuntu Mate. And I believe that RFXmngr and RFXflash only work on Windows. So I'm stuck!
pat054
Post by pat054 » Sunday 09 December 2018 17:00
I just put the version 4.10267: same LED is fixed red RFXtrx433E and its version has increased to 25. I will have to disconnect and reconnect and flash with its version 1025. It's the brothel
b_weijenberg
Re: Bug beta version 4.10267 plant RFXCOM (red light fixed)
Post by b_weijenberg » Monday 10 December 2018 10:54
I have seen this before with an Ubuntu system. It seems the Ubuntu system transmits a data sequence that forces the RFXtrx in boot load mode.
Check with Raspbian.
RFXtrx433, RFXtrx433E, RFXtrx433XL
pat054
Post by pat054 » Monday 10 December 2018 19:55
thank you. I declared a bug on the Ubuntu-MATE website.
https://bugs.launchpad.net/ubuntu-mate/+bug/1807691
I hope the developers will find the problem
pat054
Re: Bug Ubuntu Mate ( with version 4.10276 Domoticz) plant RFXCOM (red light fixed)
Post by pat054 » Saturday 15 December 2018 13:52
Under Raspbian, the RFXtrx433E does not crash anymore.
I was able to install the Domoticz database (which I had on Ubuntu Mate) on Raspbian.
Indeed, after the installation of Domoticz on Raspbian, I initialized the minimum parameters: beta version, latitude and longitude and French then click on "apply settings". Then I updated Domoticz to the latest beta: 4.10276. Finally, I restored the database (from Ubuntu Mate) in Domoticz under Raspbian by clicking on "restore database". Oh surprise! Coincidentally, the version of the RFXtrx433E was at 25: this meant that the Ubuntu Mate registered database had stored the default version 25. Given the problem, I had to update the firmware of the RFXtrx433E. The version of Domoticz has been changed from 25 to Ext / 1025. OK.
To check the proper functioning, I realized a "sudo service domoticz stop" and a "sudo service domoticz start", the RFXtrx433E no longer had its red light fixed. Same thing when restarting my RPI.
In conclusion, having gone under Raspbian, it is Ubuntu Mate who sowed discord in the RFXtrx433E when Domoticz was installed on a RPI3 with Ubuntu Mate. This last OS transmits and transmits a sequence of special characters during the initialization of a COM port, which puts RFXtrx in the initial loading mode.
