Get alarm status
Emil
Target OS: Raspberry Pi
Domoticz version: 4.97
Get alarm status
Post by Emil » Friday 07 December 2018 17:51
Hello!
My goal is to get the status of my home alarm into a selector switch.
When I enter this in the browser
https://webehome.com/Public/login.aspx? ... onOnly=yes
then I get one of the following words in response: disarm, home or away
Is there any way to get this status into a selector switch?
Thanks in advance!
Re: Get alarm status
Post by waaren » Saturday 08 December 2018 0:46
Hello!
Thanks in advance!
can you show the exact response (screenshot) ? Not clear now if the response if json or xml or other format
What do you mean the get the status into a selector switch ? Should the selector switch switch to the level named disarm, home or away or do you mean something else ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Emil
Post by Emil » Saturday 08 December 2018 9:32
Yes, i want the selector switch to show the level named disarm, home or away.
/Emil
Skärmklipp 2018-12-08 08.25.16.jpg (49.96 KiB) Viewed 89 times
Post by waaren » Saturday 08 December 2018 11:22
/Emil
The script below does react to the httpResponse and set the selector switch accordingly but there is no translation in it yet.
So for now the selector labels should be exactly the same as the possible returns from the alarm system.
If you need to translate the strings to home, disarm and and away, I need the exact words that you can get from the http call.
local alarmResponse = "_alarmResponse"
return  {
        on      =    {  timer           = { 'every minute'      },
                        httpResponses   = { alarmResponse       }},
        logging =    {  level           =   domoticz.LOG_DEBUG,
                        marker          =   "älarmResponse"     },
    execute = function(dz, item )
        local alarmSelectorIDX  = nnn          -- Change to the IDX of your selector
        local url               = 'https://webehome.com/Public/login.aspx?LoginName=username&Password=password&Action=status&ActionOnly=yes' -- Change to real HTTP
        local alarmStatus       = dz.devices(alarmSelectorIDX)
        local levels            = {}
        local function logWrite(str,level)
            dz.log(str,level or dz.LOG_DEBUG)
        local function findLevel(label)
            local level = false
            for i = 1,#alarmStatus.levelNames do
                logWrite(alarmStatus.levelNames[i])
                if alarmStatus.levelNames[i] == label then
                    level = i * 10 - 10
                    logWrite("Found: ".. alarmStatus.levelNames[i])
            return level
        local function getAlarmStatus(url)
            dz.openURL  ( {
                            url = url,
                            method = 'GET',
                            callback = alarmResponse
        local function xml2Table(xml)
            local dataStart = "<body>"
            local dataEnd   = "</body>"
            local i, j = string.find(xml, dataStart)
            local k, i = string.find(xml, dataEnd)
            local payLoad= xml:sub(j+1,k-1)
            logWrite("payLoad is: " ..payLoad)
            return payLoad
        -- Main code
        if not item.isHTTPResponse then
            getAlarmStatus(url)
            logWrite("data from HTTPcall: " .. item.data)
            if item.ok then                                         -- statusCode == 2xx
                newLevel = findLevel(xml2Table(item.data))
                if newLevel and newLevel ~= alarmStatus.level then
                    alarmStatus.dimTo(newLevel)
                logWrite("Problem with the XML response")
Emil
Post by Emil » Monday 10 December 2018 10:35
I will try this, thank you for taking the time to share your knowledge with me.
Users browsing this forum: No registered users and 3 guests
