LUA script set security status to .. by remote
AllesVanZelf
Target OS: Raspberry Pi
Domoticz version: 4.9700
Post by AllesVanZelf » Friday 07 December 2018 12:24
I have an strange problem.
In my domoticz-system (rpi3B+ with raspbian) I wanted to use the remote control (Aeontec Keyfob gen5) to switch between security panel alarm status: Disable, Arm Away, Arm Home. With some puzzling this is working well now with the following script:
 if (devicechanged['remote-1'] == 'On') then
    commandArray['Domoticz Security Panel'] = 'Arm Away'
     print('### SecPanel: status changed to ' .. globalvariables['Security'])
 if (devicechanged['remote-2'] == 'On') then
    commandArray['Domoticz Security Panel'] = 'Arm Home'
 if (devicechanged['remote-3'] == 'On') then
    commandArray['Domoticz Security Panel'] = 'Disarm'
This script is saved as device Lua.
Changing the status of Alarm by buttons works. But the log is showing the last status of the security panel instead of the new one.
What can I change in this script to fix this? Any tips?
jvdz
Domoticz version: Stable
Re: LUA script set security status to .. by remote
Post by jvdz » Friday 07 December 2018 15:12
That is because the actual change of the secpanel is done bij domoticz after the LUA script handed the CommandArray back at termination time.
Just make a script called "script_security_panel-changes.lua" and put the print statement in there as this script is only fired when the secpanel changes.
Jos
AllesVanZelf
Post by AllesVanZelf » Saturday 08 December 2018 14:20
Okay, I'll try that this evening. Thank you.
AllesVanZelf
Post by AllesVanZelf » Monday 10 December 2018 16:46
Okay. I split the script in two parts. The code is as follows
 if (devicechanged['Domoticz Security Panel'] == 'Arm Away') then
 if (devicechanged['Domoticz Security Panel'] == 'Arm Home') then
 if (devicechanged['Domoticz Security Panel'] == 'Normal') then
Is it possible to reduce this in one part? Something like this:
if (devicechanged['Domoticz Security Panel'] == 'Arm Away|Arm Home|Normal') then
jvdz
Post by jvdz » Monday 10 December 2018 17:58
As I mentioned in my previous post: That second part needs to be done in the script_security_panel-changes.lua script as that is fired when the SecPanel changes.
So just create that file and add these lines:
print('SecPanel: status changed to ' .. globalvariables['Security'])
Jos :D
AllesVanZelf
Post by AllesVanZelf » Monday 10 December 2018 19:27
Thank you! That was helping a lot.
With this separated script I could remove the "print('SecPanel: status changed to ' .. globalvariables['Security'])"
from my tag reader LUA script too. Very good.
