Neo Coolcam wallplug sending multiple kWh measurements
bramski
Post by bramski » Friday 07 December 2018 11:21
I have some strange issues with one of my Neo Coolcam wall plugs.
All measurements of my different devices are sent to InfluxDB to be visualized in Grafana. Since a few weeks my visualizations are misbehaving.
The root cause seem to be my washing machine plug is reporting wrong measurements. I have checked the logs and see the following:
2018-12-07 10:08:31.653 (Zwave USB) General/kWh (kWh wasmachine)
2018-12-07 10:08:32.143 InfluxLink: value Usage,idx=730,name=kWh-wasmachine value=105100.000
2018-12-07 10:08:32.534 (Zwave USB) General/kWh (kWh wasmachine)
2018-12-07 10:08:33.638 (Zwave USB) General/kWh (kWh wasmachine)
2018-12-07 10:08:33.671 InfluxLink: value Usage,idx=730,name=kWh-wasmachine value=218290.000
2018-12-07 10:08:34.527 (Zwave USB) General/kWh (kWh wasmachine)
2018-12-07 10:08:34.701 InfluxLink: value Usage,idx=730,name=kWh-wasmachine value=30.000
You see the concerning wallplug is sending 3 different measurements withing 3 seconds and the values are all over the place.
Anyone experienced the same issue and know how to proceed?
gizmocuz
Target OS: Raspberry Pi
Re: Neo Coolcam wallplug sending multiple kWh measurements
Post by gizmocuz » Friday 07 December 2018 11:44
could you post a screenshot of the openzwave control panel ? does this sensor report kva also ?
bramski
Post by bramski » Friday 07 December 2018 11:56
Here is a screenshot of the OpenZwave configuration panel for the concerning device. Not sure how I can see if it reports kVa.
I am not experiencing any issues with my other Neo Coolcam plugs. I have 8 of them and some fibaro's.
Actually I did a factory reset of the plug a few minutes ago, will let you know if this solves the problem.
OpenZWave Control Panel.png (36.05 KiB) Viewed 30 times
