On FOR 10
DosN
Target OS: Raspberry Pi
On FOR 10
Post by DosN » Friday 07 December 2018 8:50
I want to switch ON a light when a sensor is seeing a Motion
The light should be ON for lets say 10min
commandArray['MyOtherDeviceName4']='On FOR 10' -- minutes
this is working fine
But when this sensor is triggered again within these 10min, it should be ON for 10min again
When i start this instruction again it will not restart over ?
Brutus
Re: On FOR 10
Post by Brutus » Saturday 08 December 2018 17:24
That's because the command to set the light off after 10 min is already been out there and can't be deleted with LUA
1x Intel NUC D54250WYK (Windows 7 x64)
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
19x Fibaro Modules
SweetPants
Domoticz version: V4.10267
Re: On FOR 10
Post by SweetPants » Saturday 08 December 2018 18:03
That's because the command to set the light off after 10 min is already been out there and can't be deleted.
I think you can in dz_Ventz using cancelQueuedCommands():
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
DosN
Re: On FOR 10
Post by DosN » Sunday 09 December 2018 1:40
i tested it again
when i use: commandArray['MyOtherDeviceName4']='On FOR 10' -- minutes
once is works fine
But when i used the command again withing this time( within those 10min) , it looks like the light is not going off at all
tozzke
Re: On FOR 10
Post by tozzke » Sunday 09 December 2018 2:39
That's because you're just telling it to be on for 10 minutes, not for it to turn off after those 10 minutes :)
Perhaps depending on the version of Domoticz you're running, the 'on for x minutes' (or off for that matter) turns the light after the x minutes to the state it was at the moment of triggering. So if the light was off, it'll turn on and after x minutes it'll turn off again. Unless it's triggered again within those x minutes..... then the state will turn "back" to on after those x minutes because the light was on on the moment of the trigger.
Check the log of the light.. I'll bet it'll show 'On' twice :)
mrf68
Domoticz version: 3.4834
Re: On FOR 10
Post by mrf68 » Sunday 09 December 2018 9:46
just let the script turn the light on. Then create a second script that checks the time difference between the last update of the motion sensor and the current time. If that difference is > 10 minutes AND the light is On then turn the light Off.
DosN
Re: On FOR 10
Post by DosN » Sunday 09 December 2018 13:46
Yes i can make a LUA script , but it is so must easier if i could used ON FOR 10min again
check motion sensor and switch on light (in a DEVICE LUA script)
check the time the light is on (in a a Time LUCA script)
tozzke
Re: On FOR 10
Post by tozzke » Sunday 09 December 2018 14:08
You could also use this:
commandArray[1]={['MyOtherDeviceName4']='On'}
commandArray[2]={['MyOtherDeviceName4']='Off AFTER 600'}
In the older versions of Domoticz, a retrigger within those 600 seconds will result in a reset of the 600 second timer. The newer versions however, don't as far as I know
DosN
Re: On FOR 10
Post by DosN » Sunday 09 December 2018 23:33
im running Version: 4.10038
and it looks like it still works
thx
Nautilus
Re: On FOR 10
Post by Nautilus » Monday 10 December 2018 1:00
When did this change (in case you know)? I have a few lua scripts that rely on this to work the "old" way. Do you know what would be the correct way to do it now?
alanlsmith
Domoticz version: Latest β
Re: On FOR 10
Post by alanlsmith » Monday 10 December 2018 12:17
As a different approach, have a device script to switch the light on every time that the sensor is triggered and then a time script to turn the light off when the sensor hasn't been triggered again after a given time. That way the 'time to off' is effectively reset each time the sensor is triggered.
script_device_sensor.lua
local sensor = 'My_PIR'
local light = 'My_Light
if(devicechanged[sensor] == 'On') then
	commandArray[#commandArray+1] = {[light] = 'On'}
script_time_check_sensor.lua
time = os.date("*t")
function timedifference (s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   difference = os.difftime (t1, t2)
   return difference
local light = 'My_Light'
local lasttrigger = myFunc.timedifference(otherdevices_lastupdate[sensor])
duration = 600 --10 minutes
if(otherdevices[sensor] == 'On') then
	if(lasttrigger > duration) then
		commandArray[#commandArray+1] = {[light] = 'Off'}
Domoticz Latest β, Ubuntu 18.04 on Intel NUC i3, 8Gb ram, 70Gb drive, RFXtrx433, z-wave and a bit of Broadlink/Android
Users browsing this forum: No registered users and 3 guests
