Speed up JSON output?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Inso
Target OS: Raspberry Pi
Post by Inso » Thursday 06 December 2018 1:29
I have Domotics (Version: 4.97) running on a RPi 3b, along with MySensors gateway, Mosquitto, NodeRed. System load is about 0-1% max, ram is fine, not much traffic on (W)Lan.
If I change the state of a device (by clicking on the http interface or by dzVents), it takes 1(+) second until the JSON-command is published to my MQTT broker (Mosquitto). If I send a command by an ESP32, it arrives almost instantly, so the broker and network are fine.
I have checked the database (~2MB).
I have checked the events - no errors, not much going on.
Then I made a db backup, kicked out all dzVents scripts and deactivated all hardware stuff (xiaomi lamps and so on), so there was not much more left then my RGB dummy and a dzVents test event. Did not change anything, time until Domoticz sends the update is about one second, which is imo "a lot" for an f.e. dimmer.
Does anyone have an Idea how this delay comes up, and what to do to reduce it? What are the response times of your Domoticz?
ben53252642
Re: Speed up JSON output?
Post by ben53252642 » Thursday 06 December 2018 1:51
System: dual xeon cpu (each 8 cores) = 16 total + 48gb of ecc ram and ssd with 2500mb write / 3500mb read.
I'm not seeing any delays. ;)
emme
Domoticz version: latest
Post by emme » Thursday 06 December 2018 9:29
does it delay in ACTING the Dim/switch or just for notifying it? (send the json response/update the switch in the UI)
I have a much loaded PI (actually a P3b+) than yours (20Mb db, about 100 devices, nodeRed for other external flows) and I have a delay of about 300ms in acting... a bit more in notifying (log) but never got more than 1sec
"We always done this way"
Inso
Post by Inso » Thursday 06 December 2018 9:49
Good to know there _has_ not to be an delay :D
Problem is, my cpu load is about 1% when processing my task - so I can´t believe it is the RPi..
Definitely acting, f.e. the NodeRed debug node shows the action after ~1 second, while the ESP-"debug node" shows the corresponding action immediately.
(ESP32 is my IoT-device btw^^)
gordonb3
Domoticz version: Custom
Post by gordonb3 » Thursday 06 December 2018 9:50
Try add `-wwwcompress static` to your domoticz command line
Post by waaren » Thursday 06 December 2018 10:18
Do you publish only sensor updates for sensors that are placed on a floorplan/plan. (Hierarchical) or do you publish all outgoing messages (Flat) ?
You probably already know but you can see the time domoticz publish with this CLI command.
mosquitto_sub -F "%U - %t - %p" -v -h <domoticzIP> -p 1883 -t '#'
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
