Devices are not working
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
InMySights
Target OS: Raspberry Pi
Post by InMySights » Wednesday 05 December 2018 1:08
Version: Latest BETAs
Platform: Raspberry Pi
Plugin/Hardware: Aeotec USB Stick
Description: I have an older Rasberry Pi 2 i think and noticed that 3-4 in wall z wave switches stopped working, i.e. if I attempt to Turn On or Off I get an error in Domoticz popup saying there is an error communicating with the device. I bought a new Raspberry Pi 3b+ and installed OS on usb, installed Domoticz and performed a DB restore, moved the Aeotec USB stick to the new RPi3b+. Started it up and waited a good 30 minutes for all nodes to be queried and then attempted to turn on a switch that was not function before but alas the switch did not work and Domoticz states there is a communication error. I have attempted a Heal on the whole network and the devices individually but the result is the same - no worky!
I ask, Can this be fixed/reset/removed and then re-added without doing a Hard Reset on the Aeotec USB stick?
please understand that my other 10-15 other devices are working but these few items do not.
Regards,
Brad
InMySights
Re: Devices are not working
Post by InMySights » Wednesday 05 December 2018 20:47
Hello last night I did some experimenting and one of the switches after rebooting the RPi3b+ a few times started working!!! However once I rebooted it did not work again.
I think there is a serious problem with the DB now. Any ideas on want I should do now?
Been looking online since I Restored the old Pis DB - how can I reset everything, i.e. DB I think, so there is nothing. I will look at doing a hard reset on my Aeotec USB stick. I just read that there is a device xml file that could be corrupted but that does not explain why some switches work sometimes.
Users browsing this forum: No registered users and 4 guests
