Recognize correctly Wallmote Quad
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
funmsa
Post by funmsa » Tuesday 04 December 2018 0:43
Dear all,
I try to connect my Wallmote Quad into Domoticz and normaly I must could
- Discover 4 buttons simple click => It's ok
- Discover 4 buttons hold click => Not ok
- Discover 4 slide UP/DOWN dimmer => Not ok
From Aeotec answer is
- 4 slide UP/DOWN is only available by using into a group with other device => And in fact it's work (badly because simple click happen also in same time) but it's impossible to associate with a scene.... why ? Don't understand the logic
- 4 buttons by holding click must work.... but after some test in their side here the official answer ... so it look a problem in the recognization with Domoticz... any idea to solve it in futur ?
Hi Funmsa,
Ticket: https://aeotec.freshdesk.com/helpdesk/tickets/1013534
I have confirmed the same issues with my WallMote where only tap works allowing only 4 controllable scenes in this case. It is more of a implementation issue in this case with Domoticz unfortunately, in this case you will only be able to control 4 separate scenes with only tap control.
I am unsure how to make press and hold work with Domoticz currently.
Cheers,
Chris Cheng
Field Application Engineer
Aeotec Inc.
