Generic kWh Device returns Wrong values!
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
tillo
Target OS: Raspberry Pi
Domoticz version: 3.9030
Post by tillo » Monday 03 December 2018 23:59
Version: 4.9700
Platform: RaPi 3
Plugin/Hardware: RFXCOM - RFXtrx433 USB 433.92MHz and Generic OpenZWave USB
Description:
When using the function WhToday for a device (Generic kWh, Electricity (instant and counter) ) that have 0 usage. The function would then return the last known value that is NOT equal to 0... in my case 8146.9.
The script bellow returns pool_kwh = 8146.9 when it should be 0
See attached code and screen dumps of the sensor logs.
    local pool_obj              = domoticz.devices('Pool - Total (kWh)');
    local pool_kwh              pool_kwh = (pool_obj.WhToday);
Side note: The log only shows up till Oct 21, why dose it not show 0 all the way up till today's date?
Domoticz log 2.PNG (79.12 KiB) Viewed 33 times
Domoticz log 1.PNG (95.19 KiB) Viewed 33 times
Raspberry Pi 2 B - Raspbian Jessie + Domoticz + RFXtrxcom 433, House(dimmers, sockets, harmonyhub, Temp / Humidity Sensors, PIR, ESP8266)
