refreshzwave script no longer working
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
commentator
Target OS: Raspberry Pi
Post by commentator » Monday 03 December 2018 17:38
beta v4.10242
rpi3
since v4.10241 the refreshzwavescript is no longer working.
#!/bin/bash
#~ Specify the ZWAVE NodeID to refresh
devid="$1"
name="$2"
#~ Check whether the refrsh is already running for this device and only fire when not.
chk=`sudo ps x | grep "refreshzwave.php $devid" | grep -cv grep`
if  [ "$chk" = "0" ] ; then
   /usr/bin/php /home/pi/domoticz/scripts/refreshzwave.php $devid $name
#>> /var/log/domoticz.log 2>&1 &
   echo "$(date +%Y-%m-%d) $(date +%X)     Zwave refresh already running for $devid $name"
fi
#!/usr/bin/php
<?php
$devices=file_get_contents('http://ip:port/json.htm?type=openzwavenodes&idx=idxzwavecontroller'); //Change IDX to IDX of your zwave controller
function RefreshZwave($node,$name) {
   echo date("Y-m-d H:i:s "),"     ZWave Refresh Started for $node $name\n";
   $zwaveurl='http://ip:port/ozwcp/refreshpost.html';
   $zwavedata=array('fun'=>'racp','node'=>$node);
   $zwaveoptions = array('http'=>array('header'=>'Content-Type: application/x-www-form-urlencoded\r\n','method'=>'POST','content'=>http_build_query($zwavedata),),);
   $zwavecontext=stream_context_create($zwaveoptions);
   // print_r($zwaveoptions);
   // print_r($zwavecontext);
   for ($k=1;$k<=5;$k++){
           sleep(2);
           $result=file_get_contents($zwaveurl,false,$zwavecontext);
           echo date("Y-m-d H:i:s "),"     ZWave Refresh ",$node," ",$name," ",$result,"\n";
           if($result=='OK') break;}
if(!empty($argv[1])&&!empty($argv[2])) {
   RefreshZwave($argv[1],$argv[2]);
else {
   echo date("Y-m-d H:i:s "),"     ZWave Refresh: no idx or name defined\r\n";
sometimes a zwavenode is not working as expected and the state in Domoticz is different from the real state. Before last weekends update the above scripts corrected this issue. But now it doesn't work anymore
commentator
Re: refreshzwave script no longer working
Post by commentator » Friday 14 December 2018 0:35
anyone? How to get right device state from zwavedevice in domoticz?
Siewert308SW
Post by Siewert308SW » Friday 14 December 2018 7:10
Don't know if this is Domo related.
I know last week there was a php update for the RPi.
Did you upgrade, if so maybe this is something related.
Unfortunately i can't test as i don't have any php scripts running.
Setup:
- RPi3 - PIco HV3.0A / Domo Beta 3.9XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco HV3.0A / PiHole / PiVPN / NAS / Print Server
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
MyDomoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
commentator
Post by commentator » Friday 14 December 2018 8:54
php update is days after the domo update
commentator
Post by commentator » Tuesday 18 December 2018 21:30
it looks like when clicking update status from zwave cp it doesn't update the status of switches in domoticz
