Tradfri in domotics Topic is solved
Basssment
Target OS: Raspberry Pi
Domoticz version: 4.9700
Tradfri in domotics
Post by Basssment » Friday 23 November 2018 15:26
I'm struggeling at the moment with domoticz on mi pi3 installinge ikea tradfri.
I have been installing difrent modulles the last couple of days but I cant seem te get it to work.
I followed the next howto:
https://rutger.kirkels.nl/2018/02/01/do ... s-tradfri/
And also this one:
https://github.com/moroen/IKEA-Tradfri-plugin
But when i'm getting to the next code to enter in to the pi i get some errors
cd IKEA_tradfri
sudo cp ikea-tradfri.service /lib/systemd/system/
sudo systemctl daemon-reload
sudo systemctl start ikea-tradfri.service
The map does not seem to exsist, so manually went to the correct folder (there seems to be a typo) it looks like it is working except for the start service.
the next error apears:
Failed to start ikea-tradfri.service: Unit ikea-tradfri.service is not loaded properly: Invalid argument.
See system logs and 'systemctl status ikea-tradfri.service' for details.
I tried installing everything again but the same problem.
Installed coap first of couse, also i found that Twisted should be installed with the sudo command but still no luck.
I'm not verry good with linux so i hope someone could guid me a bit. ;)
Thank you before hand!
Bas
heggink
Domoticz version: V4.9999
Re: Tradfri in domotics
Post by heggink » Friday 23 November 2018 17:48
I noticed your signature says Synology, correct? I don't know synology at all but I suspect it does not support systemd which means that you need to use the synology way of autostarting these services.
A quick google for synology and systemd gave this: https://www.home-assistant.io/docs/autostart/synology/
The ikeas-tradfri.service file tells systemd what programme to start at boot. See what is different in the synology autostart and create your own autostart file for synology.
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
Basssment
Post by Basssment » Friday 23 November 2018 19:37
Hello Heggink,
Thank you for your reply!
You paid good attention, i am using Domoticz on my nas. But just because of the huge support for rpi i am configuring a rpi now.
So my synology is running it now but will be geplaced with the raspberry soon. Atleast when i get everything to work ;)
Basssment
Post by Basssment » Saturday 01 December 2018 0:02
Everyone,
After many hours i finaly seem go get it to work.
Had to add a lot of extra plugins ans aplications on my standard raspbian.
Learned al lot about the way everything works!
:D
