Python Plugin : Xiaomi Philips LED Ball Lamp Topic is solved
deennoo
Post by deennoo » Tuesday 13 November 2018 23:50
Hello There
I'm starting a new plugin, for some Xiaomi Philips Wifi Device.
All main work come from Kofec and his plugin for Xiaomi Air Purifier : https://github.com/kofec/domoticz-AirPurifier
I just spend some time to adapt it for the E27 Bulb aka Xiaomi Philips LED Ball Lamp aka Philips ZhiRui E27 bulb.
That a first version, With 3 Widgets
ON/OFF
Brightness
White Temp
You Can drive the Bulb directly from Domoticz and from MiHome APP (set refresh to 1 minute to have best update)
Know Issue :
- Restarting the plugin create a segmention Fault, you need to restart your domoticz
- Plugin doesn't know if your bulb are Online or not
Next evolutions are :
Using Native Domoticz CCCW Widget
Using set_brightness_and_color_temperature(brightness, cct) command avaiable on Python-miio
You can Grab it : https://github.com/deennoo/domoticz-Xia ... ree/master
Rfxtrxe / RFLink / Milight / Yeelight / ESP8266 / MQTT / BLE
http://domo-attitude.fr
deennoo
Re: Python Plugin : Xiaomi Philips LED Ball Lamp
Post by deennoo » Friday 16 November 2018 0:29
v0.1.1 is out
Adding ability to use 4 Scenes already present In the Bulb
deennoo
Post by deennoo » Saturday 17 November 2018 16:48
switching to beta branch allow you to use cccw widget
https://github.com/deennoo/domoticz-Xia ... /MyBulb.py
just missing now :
on/off from this widget
refresh this widget from bulb status
using native python-miio module to by pass MyBulb.py
arek156
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by arek156 » Sunday 18 November 2018 18:53
Hello
Great script, just how to generate a token?
N1co
Post by N1co » Sunday 09 December 2018 0:16
Hello
I cannot get this to work.
I checked the miio2.db on my android phone but the token of the light bulb is empty.
