ZWave instances
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
rnd42
ZWave instances
Post by rnd42 » Saturday 10 November 2018 18:08
Version: 4.10007
Build Hash: 74c6ad3f-modified
Compile Date: 2018-09-21 06:16:22
dzVents Version: 2.4.7
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
Raspberry Pi 3
Hello.
I've got a ZW122 which has two water sensors. OpenZWave presents it like this:
2018-11-05 21:15:55.320 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2018-11-05 21:15:55.321 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2018-11-05 21:15:55.321 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2018-11-05 21:15:55.321 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: ALARM, Label: Alarm Type, Instance: 2
2018-11-05 21:15:55.321 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: ALARM, Label: Alarm Level, Instance: 2
2018-11-05 21:15:55.321 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2018-11-05 21:15:55.322 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: ALARM, Label: Flood, Instance: 1
2018-11-05 21:15:55.322 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: ALARM, Label: SourceNodeId, Instance: 2
2018-11-05 21:15:55.322 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: ALARM, Label: Flood, Instance: 2
2018-11-05 21:15:55.322 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: BATTERY, Label: Battery Level, Instance: 1
I get one device per Label. When setting up an event for the Flood device I get data from both instances in the same device. Is it possible, in the event, to determine which instance? Or would it be possible to get a separate device for each instance?
