[Solved] Devices created from python plugin do not work as expected
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Ewaldharmsen
Post by Ewaldharmsen » Saturday 10 November 2018 12:35
Domoticz Version: 4.10181
Platform: RPI3
Description:
I have created a python plugin.
In there I create 3 devices with
Domoticz.Device(Name="Control", Unit=1, TypeName="Selector Switch", Switchtype=18, Image=2, Options=OPTIONS1, Used=1).Create()
Domoticz.Device(Name="Volume", Unit=2, Type=244, Subtype=73, Switchtype=7, Image=8, Used=1).Create()
Domoticz.Device(Name="Title", Unit=3, Type=243, Subtype=19, Used=1).Create()
The devices show up as expected. However I have problems with them:
Unit 1: If I click on the switch, I get the message "Turned on", but the switch remains off.
Unit 2: When I move the slider it seems to work, showing the percentage as expected.
However when I do a refresh the value is not stored, and it turns out the slider is still off.
When I update the device with code like so:
Devices[2].Update(50, str(50))
I get this in the log of Domoticz:
2018-11-10 11:10:16.979 (Chromecast) Update Chromecast - Volume: 52 - '52'
However, the slider is still off
Unit3: This one works. I can update the text with UpdateDevice(3,0,"Somestring"), and is shows like that in Domoticz.
I checked it with an example plugin, the Kodi one, but that plugin has the same problem. It feels the devices are somehow in readonly mode. When I try to change them, the last seen value doesn't update either.
Anybody a clue?
Last edited by Ewaldharmsen on Sunday 18 November 2018 12:09, edited 1 time in total.
Ewaldharmsen
Re: Devices created from python plugin do not work as expected
Post by Ewaldharmsen » Monday 12 November 2018 12:16
mvzut
Target OS: Raspberry Pi
Post by mvzut » Monday 12 November 2018 13:48
I noticed this too in my own plugin, but I actually liked that behavior, because my switch is intended for monitoring purposes only, not for setting by the user.
When I first saw it behaves like this, I figured that this is probably intended, i.e. that you have to capture each device click in your plugin (using the onCommand function) and perform the appropriate action there (even if it is as simple as flipping a switch). I may obviously be wrong, but in a way it sounds kind of logical doesn’t it? Hopefully others can shed more light on this.
P.S. When I update a value from within the plugin, I also noticed it is not (always) updated in the UI, so I added a Device[unit].Refresh() which seems to help, although I’m still not 100% sure if it is really needed.
Raspberry Pi 3 - RFXtrx433 - Aeon Z-Stick gen5 - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - Xiaomi Gateway - Sonos - IP cameras - Wall mounted tablet + Imperihome - MANY switches/sensors
Ewaldharmsen
Post by Ewaldharmsen » Sunday 18 November 2018 12:08
Thanks, I have solved the problem, I found that with a dimmer device the volume needs to be the string value.
Users browsing this forum: hennykarreman and 0 guests
