Importing modules witin python plugin
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Ewaldharmsen
Post by Ewaldharmsen » Friday 09 November 2018 18:23
Domoticz Version: 4.10181
Platform: RPI3
Description:
I am working on a python plugin based on pychromecast.
I did a normal install using
sudo python3 -m pip install pychromecast
When I open up python3 I can import and use pychromecast just like it should.
However when doing
import pychromecast
in the plugin I get this error:
2018-11-09 17:13:40.117 Error: (Chromecast) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Chromecast/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-11-09 17:13:40.117 Error: (Chromecast) Module Import failed, exception: 'ImportError'
2018-11-09 17:13:40.118 Error: (Chromecast) Module Import failed: ' Name: pychromecast'
Changing
import pychromecast
to
import sys
sys.path.append('/usr/local/lib/python3.5/dist-packages')
import pychromecast
Does not help.
In the end I ended up installing pychromecast and all its dependencies manually via
sudo python3 -m pip install pychromecast -t /usr/lib/python3.5
But this is very ugly.
Anybody a clue how I can make Domoticz check /usr/local/lib/python3.5/dist-packages as well?
Users browsing this forum: hennykarreman and 0 guests
