EvoHome hot water sensor no historic log
sidepipe
Target OS: Raspberry Pi
Post by sidepipe » Wednesday 07 November 2018 10:07
I've been using EvoHome via an HGI80 for some time now and have to say the integration's been brilliant. However, I've just added the hot water kit, which includes a temperature sensor for the cylinder. The sensor's showing up in Domoticz, but there's no log. This is the same on the "devices" tab or using the log button on the temperature sensors screen:
I've also got the old Domoticz script installed and can add the hot water sensor via that, but get the same result. I've had a quick search and couldn't really find anything - any ideas?
( I'm on version 4.10178 )
sexyboy
Re: EvoHome hot water sensor no historic log
Post by sexyboy » Monday 12 November 2018 1:44
It seems like it has the wrong data type. It shows % instead of temperature.
sidepipe
Post by sidepipe » Monday 12 November 2018 10:13
Yep, so it looks as though the device was created with incorrect parameters by the EvoHome subsystem. Question is, how do I fix it? I've had a quick look at the database and it does seem to be recording the information there - what information does Domoticz look at in order to decide what type of graph to create?
sexyboy
Post by sexyboy » Monday 12 November 2018 15:14
My guess was check the db, but you just done that. Not sure how to get attention on this topic or who to ask.
sidepipe
Post by sidepipe » Wednesday 14 November 2018 14:15
Ok, found the error and submitted a pull request.
sexyboy
Post by sexyboy » Wednesday 14 November 2018 18:50
Do I need to make any other changes apart from https://github.com/domoticz/domoticz/pull/2864/files and restart domoticz?
sidepipe
Post by sidepipe » Wednesday 14 November 2018 19:11
No, but bear in mind you might have cache issues. I'm not sure what the best way to clear the cache for a given page is, but on Chrome I did the following:
  1. Go to the hot water graph page
  2. Chrome Menu -> More Tools -> Developer Tools
  3. Developer Tools Menu -> Settings
  4. Under "Network", Select "Disable Cache ( while DevTools is open )
  5. Reload the page
sexyboy
Post by sexyboy » Friday 16 November 2018 18:45
That worked great.
Nice job. Thx
