Problem with timers and updating domoticz at the same time
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
fantom
Target OS: Raspberry Pi
Post by fantom » Tuesday 06 November 2018 17:51
Domoticz 4.10174
Switch with simple timer On/Off
Timer 'On' set On Time = 15.00
Timer 'Off' set On Time = 16.00
I started updating domoticz about 15.59 (domoticz started after 16.00). Or for example stopped domoticz (daemon or server or etc), when some timer has to be execute.
Timer set to 16 o'clock did not work.
The switch was turned on until 16.00 the next day
Fantom
Re: Problem with timers and updating domoticz at the same time
Post by waaren » Tuesday 06 November 2018 23:09
Domoticz 4.10174
Fantom
I'd say "Works as designed".
If you want to make sure an action will be performed even if domoticz is not active during the set time, you need to use a script of some kind.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
