Domoticz run script but nothing happen...sometimes.
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
bueno79
Target OS: Raspberry Pi
Domoticz version: 4.9700
Post by bueno79 » Tuesday 06 November 2018 12:03
hi,
here is the info :
Version: 4.9700
Platform: rpi3
Plugin/Hardware: zwave
Description:
I used to run a script every day at 9am to start the pool. the instruction is "On FOR XXX". Sometimes the pool is not starting. No errors in logs. I reboot my rpi3 and the next day it work.
How to get more info on this problem ?
best regards
emme
Domoticz version: latest
Re: Domoticz run script but nothing happen...sometimes.
Post by emme » Tuesday 06 November 2018 12:15
could you describe a bit better how the system interact with the physical switch?
is that a zWave/ESP/MySensors/etc etc switch?
could you post the script?
ciao
M
"We always done this way"
bueno79
Post by bueno79 » Tuesday 06 November 2018 18:05
hi,
thx for your help. Yes i communicate with Zwave.The script catch the temperature outside and start the pump for X hours regarding the value of the temperature. I can see in Logs "Pompes pour 6 heures" but the pump is still off. If I click on the button in the web UI or on my phone...it works ! I f I reboot my rpi, tomorrow it will works for few days...then...it will stop to work. I did not get this problem before. here is the script :
package.path = package.path..";/home/pi/domoticz/scripts/lua/?.lua"
require "modules"
local t = os.date("*t")
if (otherdevices['Pompe Piscine - Mode Nuit'] == 'Off') then
    if (t.hour == 09) and (t.min == 00 ) and (uservariables['Pompe_Control'] == "OFF") then
        if (uservariables['Temp Ext Matin'] >= 0.0 and uservariables['Temp Ext Matin'] <= 9.0) then
            commandArray['Pompe de la Piscine'] = "On FOR 120" -- on allume 2 heures la pompe
            print("Pompe pour 2 heures")
            commandArray['Variable:Pompe_Control'] = 'ON'
        if (uservariables['Temp Ext Matin'] > 9.0 and uservariables['Temp Ext Matin'] <= 18.0) then
            commandArray['Pompe de la Piscine'] = "On FOR 360" -- on allume 6 heures la pompe
            print("Pompe pour 6 heures")
        if (uservariables['Temp Ext Matin'] > 18.0 and uservariables['Temp Ext Matin'] <= 24.0) then
            commandArray['Pompe de la Piscine'] = "On FOR 600" -- on allume 10 heures la pompe
            print("Pompe pour 10 heures")
        if (uservariables['Temp Ext Matin'] > 24.0 ) then
            commandArray['Pompe de la Piscine'] = "On FOR 840" -- on allume 12 heures la pompe
            print("Pompe pour 14 heures")
    if (t.hour == 09) and (t.min == 01 ) and (uservariables['Pompe_Control'] == "ON") then
        commandArray['Variable:Pompe_Control'] = 'OFF'
if (otherdevices['Pompe Piscine - Mode Nuit'] == 'On') then
    if (t.hour == 23) and (t.min == 01 ) and (uservariables['Pompe_Control'] == "OFF") then
            commandArray['Pompe de la Piscine'] = "On FOR 720" -- on allume 12 heures la pompe
            print("Pompe pour 12 heures")
    if (t.hour == 23) and (t.min == 02 ) and (uservariables['Pompe_Control'] == "ON") then
-- if (t.hour == 09) and (t.min == 02 ) and (uservariables['Pompe_Control'] == "ON") then
   --  commandArray['Variable:Pompe_Control'] = 'OFF'
--end
pigloox
Post by pigloox » Monday 12 November 2018 0:04
hi,
same issue for me with blockly,
V4.10181 on RPI
RPI3 Stretch (Hard disk)
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
bueno79
Post by bueno79 » Monday 12 November 2018 16:50
just remove yana server, some old programs (script to pass speech to google home) and some old programs...will see if it is more stable.
sexyboy
Post by sexyboy » Tuesday 13 November 2018 1:46
I'm running the latest beta 4.10179
Build Hash: f0985571
Build Date: 2018-11-07 14:30:43
On Ubuntu 18.04
It seems like that the new Event editor on the latest Beta is not saving the newly create scripts/event files onto the disk under domoticz/scripts/dzVents/generated_scripts/.
If I touch a new file and save data to it subsequently it starts working.
Thanks in advance.
Users browsing this forum: No registered users and 6 guests
