Unrecognized sensor (NODON STPH-2-1-05 EnOcean temperature and humidity)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pat054
Target OS: Raspberry Pi
Domoticz version: 4.10102
Post by pat054 » Saturday 13 October 2018 18:46
Hello everyone,
here, I have a NODON STPH-2-1-05 temperature and humidity sensor
EnOcean which I can not match with DOMOTICZ.
Someone would have an idea about why and how to do it?
Patric
pat054
Re: Unrecognized sensor (NODON STPH-2-1-05 EnOcean temperature and humidity)
Post by pat054 » Wednesday 17 October 2018 11:49
Does anyone have an idea?
Pressing the sensor button briefly lights the acquisition LED of my EnOcean USB310 controller key, but does not pair this sensor in DOMOTICZ.
While I have other sensors (AFRISO VELTA thermostats) that work well with the EnOcean USB310 controller key.
A priori it comes from the NODON sensor or DOMOTICZ.
Someone to answer
quirk
Post by quirk » Wednesday 17 October 2018 13:59
Hi Patric,
I have 2 NODON EnOcean Temp + Hum working with Domoticz without any problem (just the battery level is not reported correctly)
Association was done easily by clicking the sensor button.
Device automatically created :
Logs
2018-10-17 13:50:26.769 EnOcean: destination: 0xffffffff RSSI: 40
2018-10-17 13:50:26.769 EnOcean: 4BS data: Sender id: 0x01a4d60a Status: 00 Data: 8c
2018-10-17 13:50:26.773 (Enocean Controller) Temp + Humidity (Salle à manger)
2018-10-17 13:50:26.769 Status: EnOcean: 01 (0A/07) A5 00 83 8C 0A 01 A4 D6 0A 00 01 FF FF FF FF 3C 00
Do you have any error message in logs?
pat054
Post by pat054 » Thursday 18 October 2018 12:25
Hello quirk,
the combination of your sensors, how do you do in Domoticz? You go to the "switches" tab and click on "auto detection" and then you press the button for pairing the sensor? Or do you simply press the sensor's pairing button and it's OK?
On my side when I press the button of pairing of the sensor, the log gives me this:
2018-10-18 12: 20: 14.952 Status: EnOcean: 01 (14/07) 35 20 93 E2 F1 4F 2A EE 04 7D D9 70 71 F4 17 05 11 77 46 00 01 FF FF FF FF 2C 00
2018-10-18 12: 20: 14.953 Status: EnOcean: 01 (0F / 07) 31 AB 60 3E 1A EF 62 9E 6C B1 05 11 77 46 00 01 FF FF FF FF 2C 00
In device in DOMOTICZ, the sensor does not appear
Patric
Information 1: For the log, I cut my VELTA thermostats EnOcean
Information 2: The log gives this every 4 minutes:
2018-10-18 12:29:03.725 Status: EnOcean: 01 (0E/07) 30 A9 BF 6C 23 28 33 1C F2 05 11 77 46 00 01 FF FF FF FF 29 00
What is it about?
Information 3: After a few minutes, I have this:
2018-10-18 12: 47: 12.378 EnOcean: destination: 0xffffffff RSSI: 33
2018-10-18 12: 47: 12.379 EnOcean: Unhandled RORG (b2)
2018-10-18 12: 47: 12.378 Status: EnOcean: 01 (07/07) B2 C0 01 94 14 BF 00 01 FF FF FF FF 43 00
What's the problem?
pat054
Post by pat054 » Sunday 21 October 2018 10:35
Patric
Users browsing this forum: cencen, moroen, Pandabeer and 2 guests
