Google Home vs. Amazon Alexa? Topic is solved
Alexa, Google Home and Siri
renerene
Post by renerene » Friday 12 October 2018 6:52
I have been a satisfied user of Alexa for two years. Now, google is coming with Home in my language. Should I give it a go? Time to switch?
What are your thoughts?
heggink
Target OS: Raspberry Pi
Domoticz version: V4.9999
Re: Google Home vs. Amazon Alexa?
Post by heggink » Friday 12 October 2018 7:08
I switched. The mini is a lot smarter and more accessible.
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
Hesmink
Post by Hesmink » Friday 12 October 2018 9:38
How do the both compare in Domoticz support?
Stief
Post by Stief » Friday 12 October 2018 11:07
You can use Controlicz or ITTT to integrate Domoticz with Google Home (and the Google assistant) I have no experience with Alexa buth read somewhere that Alexa also supports both.
I myself am using a KaKu ICS-2000 for the integration. I don't want my Domoticz setup available from internet. Some people use muliple Domoticz instances/ devices for that so they have only one with limited functions extern accessable.
As written above I use a KaKu ICS-2000 wich I got cheap online. KaKu (or Trust) has native support for Google Home. Made a few groups on my domoticz for certain devices I want to be able to controll with Google Home. Whitin the groups I added a activation device that I created on the Kaku for this.
So I have only the devices/switches I want to operate with Google Home created on the KaKu and my Domoticz isolated from internet.
renerene
Post by renerene » Saturday 13 October 2018 18:10
I really enjoy the alexa speak option, that came available in 2018.
Can you also make Google speak?
heggink
Post by heggink » Saturday 13 October 2018 18:16
Absolutely and without issues like caption...
Pi3, latest beta
Harmony hub, Nest
bozidar
Post by bozidar » Friday 26 October 2018 21:12
i have both the google mini and the echo dot . use it with Domoticz thru controlicz .
I am seeing much longer "reaktion times" with the mini than the Echo.
Do any of you have same experiences ?
heggink
Post by heggink » Friday 26 October 2018 21:16
Not in my case... Letting Google talk is much faster.
Pi3, latest beta
Harmony hub, Nest
ricorico94
Post by ricorico94 » Thursday 22 November 2018 16:56
Hi Heggink,
Could you describe which solution you use for Google Home Mini ? Is it controlicz ? If yes, it's not free anymore, correct ?
br,
Ricorico94
Users browsing this forum: mvzut, renerene and 1 guest
