Fakro ARZ no stop
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Tonio16
Target OS: Raspberry Pi
Domoticz version: 4.9700
Fakro ARZ no stop
Post by Tonio16 » Thursday 11 October 2018 20:40
Hello
I have 4 Fakro roof blinds of the ARZ type, so zwave.
My problem is that with Domoticz I can only make them opening or closing. Means no stop or level setting though I can stop.them with the remote of fakro, which is also a zwave one. I tried with Json but it failed.
I googled and saw that it is possible with Jeedom or Openhab, so openzwave allows that. :?:
Would it be possible to implement the stop function also in Domoticz?
Antoine
<Node id="5" name="" location="" basic="4" generic="17" specific="6" type="Motor Control Class B" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">...</Node>
<Node id="6" name="" location="" basic="4" generic="17" specific="6" type="Motor Control Class B" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="85" name="Fakro">
<Product type="2" id="2" name="ARZ Roof Window Roller Shutter"/>
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="38">
<Instance index="1"/>
</CommandClass>
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="4" innif="true">
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True"/>
</CommandClass>
<CommandClass id="38" name="COMMAND_CLASS_SWITCH_MULTILEVEL" version="3" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="254"/>
<Value type="button" genre="user" instance="1" index="1" label="Open" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0"/>
<Value type="button" genre="user" instance="1" index="2" label="Close" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0"/>
<Value type="bool" genre="system" instance="1" index="3" label="Ignore Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True"/>
<Value type="byte" genre="system" instance="1" index="4" label="Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0"/>
<Value type="byte" genre="system" instance="1" index="5" label="Dimming Duration" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255"/>
<Value type="byte" genre="user" instance="1" index="6" label="Step Size" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0"/>
<Value type="button" genre="user" instance="1" index="7" label="Inc" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0"/>
<Value type="button" genre="user" instance="1" index="8" label="Dec" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0"/>
</CommandClass>
<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="3" size="1">
<Item label="Disabled" value="0"/>
<Item label="Off Enabled" value="1"/>
<Item label="On Enabled" value="2"/>
<Item label="On and Off Enabled" value="255"/>
</Value>
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Normal" value="0"/>
<Item label="-1dB" value="1"/>
<Item label="-2dB" value="2"/>
<Item label="-3dB" value="3"/>
<Item label="-4dB" value="4"/>
<Item label="-5dB" value="5"/>
<Item label="-6dB" value="6"/>
<Item label="-7dB" value="7"/>
<Item label="-8dB" value="8"/>
<Item label="-9dB" value="9"/>
</Value>
<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0"/>
<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0"/>
<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0"/>
<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0"/>
<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0"/>
<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0"/>
<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Failed" value="0"/>
<Item label="Success" value="1"/>
<Item label="In Progress" value="2"/>
</Value>
<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0"/>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6"/>
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.42"/>
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.01"/>
</CommandClass>
</CommandClasses>
</Node>
Tonio16
Re: Fakro ARZ no stop
Post by Tonio16 » Friday 12 October 2018 8:44
Hello
I saw this today: https://github.com/domoticz/domoticz/issues/1650
The last post of Gizmocuz is somehow unfair. There is a problem with the stop function of Zwave shutter in domoticz. Sadly it is not affecting people with the skills to submit a patch.
A bon entendeur,
Antoine
