Accessing MySensors Child value via dzVents
lamptah
Target OS: Raspberry Pi
Post by lamptah » Thursday 11 October 2018 5:05
Is it possible to set the hardware value of a MySensors child via dzVents? These values seem to be purged during a restart of domoticz, and the IR Send command is relying on finding a previously received V_IR_RECEIVE in the values. Which works fine as long as domoticz was not restarted and purged any previously received V_IR_RECEIVE value, but after a restart the send function is defunct until a code is first received again.
This seems to be due to the fact that the value of the MySensors child is purged upon domoticz restart, and the WriteToHardware function uses `FindChildByValueType(V_IR_RECEIVE);` to find the child (and value to send).
After domoticz restart:
After child refreshes IR code:
So unless I force the MySensors node to periodically refresh all possible codes, I would need to manually set them with dzVents upon domoticz restart. Is that possible?
Re: Accessing MySensors Child value via dzVents
Post by waaren » Thursday 11 October 2018 5:58
Probably only if you know the JSON to set this.
You can try to catch the JSON by going into developer tools of the chrome browser by pressing <CTRL> <SHIFT> <I> and enter the command.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
