RaZberry V1 with latest firmware won't work with OZW
kimhav
Target OS: Raspberry Pi
Domoticz version: 4.10053
Post by kimhav » Wednesday 10 October 2018 22:20
As mentioned I've recently upgraded a device with Razberry V1 (test rig) with the latest firmware and while the controller shows up in Domoticz it won't be configured. One could assume that the card doesn't work proper so I then prepared SD-card with Z Way Server which works out fine and I can include z-wave devices without any problem.
The question I have is if it's know what would be level of firmware which is supported by OZW which I could downgrade to get the system working again. I've also asked the same question within the OZW forum, so let see if thins one can be figured out.
Member of Domoticz Sweden Telegram Group
gizmocuz
Re: RaZberry V1 with latest firmware won't work with OZW
Post by gizmocuz » Thursday 11 October 2018 8:37
Razberry support has been dropped for some years now. You have to use the OpenZWave hardware now and select the serial port.
It was hard to continue to support both and openzwave has support for many more hardware, also USB zwave devices that you can use in other non-raspberry systems.
If you google for "Razberry domoticz" you would have found this guide:
https://www.vesternet.com/resources/app ... I7cfnXhDqP
Hope it helps!
kimhav
Post by kimhav » Thursday 11 October 2018 9:43
I do make use of Razberry together with OZW which works out great on my primary rig which has the Raszberry V2 card. But, when using Z Way Server to update the test rig which has the V1 card to the latest firmware I noticed that while everything works using Z Way Server I can't get it work proper with OZW and Domoticz. I can see the zwave controller, but it won't let itself to be configured nor can I include any zwave devices. So kind of stuck, but then again, happy that I broke my test rig rather than the production rig.
So for now I would say that one should go easy on the firmware upgrades on the Razberry V1 cards and I just need to figure out which firmware version which works with OZW.
Xztraz
Post by Xztraz » Wednesday 07 November 2018 17:49
what usb stick is reccomended to use with domoticz? aeon/zwave.me? looking at upgrading from a rpi to a atom sys. but then my razberry won't work
gizmocuz
Post by gizmocuz » Wednesday 07 November 2018 18:58
Both are working fine (buy the + (plus) version)
