Is it possible to send message when domoticz started?
Mixanoid
Target OS: Raspberry Pi
Post by Mixanoid » Tuesday 09 October 2018 17:23
Sometimes we have problems on power line. I cannot see when the line is down (domoticz does not work without electricity) but can I receive the message when domoticz turns on?
Egregius
Re: Is it possible to send message when domoticz started?
Post by Egregius » Tuesday 09 October 2018 17:47
You could use a cron job for that, or alter the init.d script.
Post by waaren » Tuesday 09 October 2018 18:47
I use this dzVents script to notify when domoticz has been started.
    active when function returns true ( domoticz started less then 180 seconds ago )
    The defined tasks will only execute once after domoticz started.
    Please note that in theory this is not a failsafe way of handling this.
    If domoticz crashes / is stopped after the first excution of this script and before 120 seconds after
    it started, the Executed value is not set back to 0 and the script needs to be reloaded to reset the persistent data.
    If domoticz starts extremely slow, in theory it could be that this script will not be evaluated before the 180 seconds
    after startup has passed. On my test system (PI-3), first execution is well within that window. (somewhere between 13 and 60 seconds)
    active = function(domoticz)
              return domoticz.startTime.secondsAgo < 180
            end,
    on         = {      timer     = { 'every minute'  } },
    data     = {     Executed     = { initial = 0 } },
    execute = function(dz)
        if dz.data.Executed == 0 then
            dz.notify("Domoticz has just been started")
            print ("Älready executed; " .. tostring(dz.data.Executed) .. " seconds after domoticz started.")
            if dz.startTime.secondsAgo > 119 then
                dz.data.Executed = 0
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
EdddieN
Domoticz version: 4.9700
Post by EdddieN » Tuesday 09 October 2018 19:51
I use Monit for it with pushover, but I also like very much @waaren solution.
11101101 - www.machinon.com
