Cannot start with Python 3.7
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
haden
Post by haden » Sunday 07 October 2018 20:01
Running Domoticz 4.9700 on windows server 2016.
Works perfect until I install Python 3.7. There are no plugins installed yet.
It never starts up, but loops in the startup.
after reboot:
Log:
2018-10-07 19:49:46.173 Status: WebServer(HTTP) started on address: :: with port 8080
2018-10-07 19:49:46.468 Status: WebServer(SSL) started on address: :: with port 443
2018-10-07 19:49:46.468 Status: Proxymanager started.
2018-10-07 19:49:46.483 Status: TCPServer: shared server started...
2018-10-07 19:49:46.483 Status: RxQueue: queue worker started...
2018-10-07 19:49:48.944 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-10-07 19:49:48.944 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-10-07 19:49:48.944 Status: Startup Path: C:\Program Files (x86)\Domoticz\
2018-10-07 19:49:49.022 Sunrise: 07:28:00 SunSet: 18:35:00
2018-10-07 19:49:49.022 Day length: 11:07:00 Sun at south: 13:05:00
2018-10-07 19:49:49.022 Civil twilight start: 06:52:00 Civil twilight end: 19:11:00
2018-10-07 19:49:49.022 Nautical twilight start: 06:09:00 Nautical twilight end: 19:54:00
2018-10-07 19:49:49.022 Astronomical twilight start: 05:26:00 Astronomical twilight end: 20:37:00
2018-10-07 19:49:49.100 Active notification Subsystems: email (1/13)
2018-10-07 19:49:49.395 Starting shared server on: :::6144
2018-10-07 19:49:49.022 Status: EventSystem: reset all events...
2018-10-07 19:49:49.084 Status: PluginSystem: Started, Python version '3.7.0'.
2018-10-07 19:49:49.100 Status: WebServer(HTTP) started on address: :: with port 8080
2018-10-07 19:49:49.395 Status: WebServer(SSL) started on address: :: with port 443
2018-10-07 19:49:49.395 Status: Proxymanager started.
2018-10-07 19:49:49.395 Status: TCPServer: shared server started...
2018-10-07 19:49:49.395 Status: RxQueue: queue worker started...
2018-10-07 19:49:51.444 Status: DarkSky: Started...
2018-10-07 19:49:51.444 Status: EventSystem: reset all events...
2018-10-07 19:49:51.444 Status: EventSystem: reset all device statuses...
2018-10-07 19:49:51.568 Status: PluginSystem: Entering work loop.
2018-10-07 19:49:54.855 Sunrise: 07:28:00 SunSet: 18:35:00
2018-10-07 19:49:54.871 Day length: 11:07:00 Sun at south: 13:05:00
2018-10-07 19:49:54.871 Civil twilight start: 06:52:00 Civil twilight end: 19:11:00
2018-10-07 19:49:54.871 Nautical twilight start: 06:09:00 Nautical twilight end: 19:54:00
2018-10-07 19:49:54.871 Astronomical twilight start: 05:26:00 Astronomical twilight end: 20:37:00
2018-10-07 19:49:54.933 Active notification Subsystems: email (1/13)
2018-10-07 19:49:54.793 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-10-07 19:49:54.793 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-10-07 19:49:54.793 Status: Startup Path: C:\Program Files (x86)\Domoticz\
2018-10-07 19:49:54.871 Status: EventSystem: reset all events...
2018-10-07 19:49:54.917 Status: PluginSystem: Started, Python version '3.7.0'.
When I uninstall python, Domoticz starts up again and works.
Anyone got this working?
Dnpwwo
Target OS: Raspberry Pi
Re: Cannot start with Python 3.7
Post by Dnpwwo » Monday 08 October 2018 4:44
@haden,
I did some testing with Python 3.7 a little while ago and made some code changes to make it work. Our friends maintaining Python made some changes during initialisation of interpreters that were not compatible with the way Domoticz was using them.
I suggest you either switch to the beta channel and pick up those changes if you absolutely *must* have 3.7 or go with Python 3.6 in the short term.
haden
Post by haden » Monday 08 October 2018 16:36
Thanks. Downgrading to 3.6.6 fixed the issue.
Users browsing this forum: No registered users and 3 guests
