Python Plugin - Options not updated in DB
pipiche
Target OS: Raspberry Pi
Post by pipiche » Friday 28 September 2018 15:15
The Options fields seems to not be updated in the DB.
I'm using Options to store a number of plugin related information. At creation there is not issue. But when I want to update it, there is no update of the Options field !
Here is what options looks like
Options = {'ClusterType': 'Plug', 'Zigate': {'Ep': {'01': {'0000': {}, '0006': '00', '000c': {}, 'Type': 'Plug'}, '02': {'000c': '0.0', 'Type': 'Power/Meter'}}, 'Status': 'inDB', 'Heartbeat': '16', 'RIA': '7', 'RSSI': 51, 'Battery': {}, 'Model': 'lumi.plug', 'MacCapa': '8e', 'IEEE': '00158d00024d873d', 'Type': 'Plug/PowerMeter', 'ProfileID': {}, 'ZDeviceID': {}, 'DomoID': '1cb6', 'SQN': {}}}
And here after is how the device is created and how it is updated
Domoticz.Device(DeviceID=str(DeviceID),Name=str(t) + "-" + str(DeviceID) + "-" + str(Ep), Unit=FreeUnit(self, Devices), TypeName="kWh", Options={"Zigate":str(self.ListOfDevices[DeviceID]), "ClusterType":t}).Create()
Devices[Unit].Update(nValue=int(nValue), sValue=str(sValue), Options=str(Options), SignalLevel=int(rssi), BatteryLevel=int(BatteryLvl) , Color = Color_)
pipiche
Re: Python Plugin - Options not updated in DB
Post by pipiche » Friday 28 September 2018 15:16
I'm really stuck. I tried to add some debug in hardware/plugin/PythonObjects.cpp but without success
I just been able to identify the test : if (pOptionsDict && PyDict_Check(pOptionsDict)) in line 947 of hardware/plugin/PythonObjects.cpp is false. So either my object is not a Python Dict, which I would be surprise as you can see here after!
pipiche
Post by pipiche » Friday 28 September 2018 17:48
I have been able to put SetDeviceOptions in debug and here are the log that I'm getting:
Sep 28 17:34:32 pi3 domoticz[3028]: 2018-09-28 17:34:32.654 (Zigate) UpdateDevice_v2 Option before Update = {'ClusterType': 'LvlControl', 'Zigate': {'ZDeviceID': '0200', 'Heartbeat': 0, 'Type': {}, 'IEEE': '20918a0000038f65', 'Ep': {'01': {'0015': {}, '0008': {}, '0100': {}, '0004': {}, '0005': {}, '0006': {}, 'fc20': {}, '0000': {}, '000a': {}, 'fc21': {}, '0003': {}}}, 'Model': 'shutter.Profalux', 'Battery': {}, 'MacCapa': '8e', 'Status': 'inDB', 'RIA': '2', 'ProfileID': '0104', 'DomoID': 'e86c', 'RSSI': 66, 'SQN': {}}}
Here is Options before call Update
Sep 28 17:43:44 pi3 domoticz[3028]: 2018-09-28 17:43:44.390 (Zigate) UpdateDevice_v2 Option before Update = {'ClusterType': 'LvlControl', 'Zigate': {'ZDeviceID': '0200', 'Heartbeat': 0, 'Type': {}, 'IEEE': '20918a0000038f65', 'Ep': {'01': {'0015': {}, '0008': {}, '0100': {}, '0004': {}, '0005': {}, '0006': {}, 'fc20': {}, '0000': {}, '000a': {}, 'fc21': {}, '0003': {}}}, 'Model': 'shutter.Profalux', 'Battery': {}, 'MacCapa': '8e', 'Status': 'inDB', 'RIA': '0', 'ProfileID': '0104', 'DomoID': 'e86c', 'RSSI': 57}}
Devices[Unit].Update(nValue=int(nValue), sValue=str(sValue), Options=Options)
Here after we see reaching SetDeviceOptions in SQLHelper
Sep 28 17:43:44 pi3 domoticz[3028]: 2018-09-28 17:43:44.416  Status: DEBUG : reaching SetDeviceOptions
Sep 28 17:43:44 pi3 domoticz[3028]: 2018-09-28 17:43:44.416  Status: DEBUG : setting options 'ClusterType:THZsQ29udHJvbA==;Zigate:eydaRGV2aWNlSUQnOiAnMDIwMCcsICdIZWFydGJlYXQnOiAnMScsICdUeXBlJzoge30sICdJRUVFJzogJzIwOTE4YTAwMDAwMzhmNjUnLCAnRXAnOiB7JzAxJzogeycwMDE1Jzoge30sICcwMDA4Jzoge30sICcwMTAwJzoge30sICcwMDA0Jzoge30sICcwMDA1Jzoge30sICcwMDA2Jzoge30sICdmYzIwJzoge30sICcwMDAwJzoge30sICcwMDBhJzoge30sICdmYzIxJzoge30sICcwMDAzJzoge319fSwgJ01vZGVsJzogJ3NodXR0ZXIuUHJvZmFsdXgnLCAnQmF0dGVyeSc6IHt9LCAnTWFjQ2FwYSc6ICc4ZScsICdTdGF0dXMnOiAnaW5EQicsICdSSUEnOiAnMCcsICdQcm9maWxlSUQnOiAnMDEwNCd9' on device 13
Here after is Option after the Update. It is not matching what was in Options before
Sep 28 17:43:44 pi3 domoticz[3028]: 2018-09-28 17:43:44.418 (Zigate) UpdateDevice_v2 Option after Update = {'ClusterType': 'LvlControl', 'Zigate': "{'ZDeviceID': '0200', 'Heartbeat': '1', 'Type': {}, 'IEEE': '20918a0000038f65', 'Ep': {'01': {'0015': {}, '0008': {}, '0100': {}, '0004': {}, '0005': {}, '0006': {}, 'fc20': {}, '0000': {}, '000a': {}, 'fc21': {}, '0003': {}}}, 'Model': 'shutter.Profalux', 'Battery': {}, 'MacCapa': '8e', 'Status': 'inDB', 'RIA': '0', 'ProfileID': '0104'}"}
pipiche
Post by pipiche » Friday 28 September 2018 22:28
Here attached is a plugin to reproduce the probleme !!!!
Here is a short plugin.py to reproduce the problem.
A device is created in the onStart (if not yet created).
Then in onHearbeat, we display the
(1) Display Devices[1].Options Look at Heartbeat -- It is 0
(2) Display Options after increment of hearbeat
In the next cyce, you'll see that Hearbeat is not incremented !!!!!!!!!!!!
plugin.py.zip
(1.59 KiB) Downloaded 4 times
Dnpwwo
Post by Dnpwwo » Saturday 29 September 2018 15:04
@pipiche,
Your test plugin crashed Domoticz on Windows for me rather than failing to update, I will have a look into it.
I suspect your problem is because during the create you correctly pass in a dictionary with string leys and string values but in the update you pass in a nested dictionary rather than a string.
It seemed to work if I changed line 78 to be:
Options['Zigate']=str({'Ep': {'01': {'0000': {}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0300': {}, '0b05': {}, '1000': {}}}, 'Status': 'inDB', 'Heartbeat': str(self.hb), 'RIA': '0', 'RSSI': {}, 'Battery': {}, 'Model': 'Ampoule.LED1624G9.Tradfri', 'MacCapa': '8e', 'IEEE': '90fd9ffffee77f7e', 'Type': {}, 'ProfileID': 'c05e', 'ZDeviceID': '0200', 'DomoID': '3145', 'SQN': {}})
pipiche
Post by pipiche » Saturday 29 September 2018 15:21
@Dnpwwo, indeed it works. So I need to jump in the real case to understand the issue.
Might be great that the Domoticz code would complain instead of doing nothing, no ?
Dnpwwo
Post by Dnpwwo » Sunday 30 September 2018 9:11
@pipiche,
I pushed a fix today that will effectively force a 'str()' convertion inside the Device.Update so your old code will now work.
By the way, the SuppressTriggers parameter takes a Boolean value (True/False) not a string. Any string other than an empty one will always evaluate to True (see https://documentation.help/Python-3.4/s ... html#truth)
pipiche
Post by pipiche » Sunday 30 September 2018 10:00
@Dnpwwo, BTW as I think you master this part, is there any specific reason why DeviceID cannot be changed ?
I tried to update the code to accommodate it, but I'm getting an error message "CDevice_update' failed 'SystemError':'More keyword list entries (17) than format specifiers (16)'" that I cannot identify where it is coming from.
Basically trying to implement in CDevice_update() the same way as for Name update.
PS/ this is in the context of a plugin where we have to upgrade all of the DeviceID,
[EDIT]
I found it ;-)
pipiche
Post by pipiche » Tuesday 09 October 2018 11:45
@Dnpwwo , just to confirm your recent fix. It works very well.
Unfortunately, you might have seen my recent post viewtopic.php?f=65&t=25187 ; where I understood from Gizmocuz that Options is a column for the only purpose of Domoticz and must not be used by any plugin.
Dnpwwo
Post by Dnpwwo » Tuesday 09 October 2018 14:20
@pipiche,
The Options column tends to be used in certain ways by native Domoticz code, such as selector switches. The behanviour you have described where additional Options get lost would apply to Selctor switches created by any hardware and is not a limitation of the plugin framework.
The question is: What are you trying to achieve by attempting to store additional data in the Options Column for a device?
If you want to store additional information you can write it to a file local to the plugin using native Python file handling.
pipiche
Post by pipiche » Tuesday 09 October 2018 14:43
@Dnpwwo
You right, this is indeed what we are going to do. We were - and wrongly - under the impression to be able to store extra information in Options to accommodate the Plugin needs to store informations.
I do consider , that distributing information across several locations increase the risk of inconsistency and troubles. And we saw suhc benefits to use this Options field with a centrally managed set of information
More wider and outside of my current problem, I feel that it would be good to have the Plugin able to access Domoticz database as scuh as Creating 1 extra table and corresponding address, with the possibility to Create, Update and Delete rows in it.
( this is more-less what you can do with a Native plugin), and this becomes a limitation from the Python framework.
Taking in consideration, that I see Domoticz becoming more and more complex due to the large number of Native Plugin, I see a lot of benefits of the Python Framework as it allows a full plugin development in a relative light coupling with Domoticz.
This I would say a very nice feature ... Don't you agree ?
StasDemydiuk
Post by StasDemydiuk » Wednesday 10 October 2018 9:08
I also thought that we can use Options field to store additional information for device from plugin.
Currently it doesn't look like an option because Domoticz itself use this field and overwrites plugin custom keys.
@Dnpwwo Because of that maybe we could think about adding such ability to python plugins framework to store additional information inside the device somehow, as it could be extremely useful for some plugins (mine as example viewtopic.php?f=65&t=24975 :roll: ) instead of reinventing the wheel in each plugin individually.
pipiche
Post by pipiche » Wednesday 10 October 2018 10:46
@StasDemydiuk, looks like we are working on similar topic but from different angle .
As stated earlier, I really like what the Python Framework is bringing , enhancing it would make it even more valuable and would help us to reach more complex plugin and I thing what @StasDemydiuk and I are working fall into this.
Dnpwwo
Post by Dnpwwo » Monday 15 October 2018 1:32
@pipiche and @StasDemydiuk,
I'm not against adding extra functionality to the framework, I'm just trying to better understand what you are trying to achieve to inform the design.
One of the goals of the framework was to make plugins work 100% the same was as native hardware implementations. Currently there is a clear separation within Domoticz between the code that interfaces to hardware and the code that handles devices which is why the code supporting Selector Switches believes it has the right to update the DeviceStatus.Options field. If we are considering adding a per device storage capability it should not be 'plugin only' but rather it should be consumable by the broader application.
I'm currently looking at a Z-Wave plugin which may have a similar requirement because Z-Wave devices declare their capabilities at run time so remembering them from previous runs would make start up much faster.
pipiche
Post by pipiche » Monday 15 October 2018 8:16
I'm fully with you that it was a mistake willing to use Device.Options, so no issue on that.
As you stated
, and The Framework should allow the creation of one Table specific to the plugin itself. This is what a number of Native plugin are doing. EnoceanSensors, ZWaveNodes for examples.
In such you will give all freedom in the Plugin to create its own storage capability.
This for me would be the right enhacement
- Creation of 1 Plugin Table
- Insrert/Update/Delete/Query rows in that table
- Remove of the Plugin Table
- Update of Plugin Table
Logread
Post by Logread » Monday 15 October 2018 19:41
I like this idea very much... for now I have had to use a hack for plugins I wrote that need their own persistent data storage capability, like the SmartVirtualThermostat... I store/read plugin data to/from the uservariables table via the json interface... not very clean but at least the data is backed up together with the entire database (which is not the case if you use a local file as storage). Having a dedicated table for plugins data is a great idea.
