HTTPS not working pls help
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
remmynl
Target OS: Raspberry Pi
Post by remmynl » Saturday 15 September 2018 19:29
Version: 4.9700
Platform: raspberry
Plugin/Hardware: model 3b+
clean fresh stretch lite image, noting else installed except domoticz easy installation.
8080 port is open and works fine
443 port is open but give an empty response
with a clean image of 2018-06-27-raspbian-stretch-lite with only :
sudo apt-get update
sudo apt-get upgrade
sudo reboot
curl -L install.domoticz.com | sudo bash
Does anyone have an idea to get https working? I want it to work for using Controlicz.
Furiousz23
Re: HTTPS not working pls help
Post by Furiousz23 » Saturday 15 September 2018 20:02
Just follow the Wiki: http://www.domoticz.com/wiki/Native_sec ... ts_Encrypt
(Don`t forget to temporary change the port to 80 instead of 8080 in /etc/init.d/domoticz.sh during the procedure)
remmynl
Post by remmynl » Saturday 15 September 2018 21:37
shouldn't I get something served on port 443 without using self signed certs/let's encrypt certs? Because this is not working at all with a clean install.
jvdz
Domoticz version: Stable
Post by jvdz » Saturday 15 September 2018 21:41
What is the domoticz.log telling you at startup of domoticz? Any errors or status for the webserver?
Jos
pedro6
Post by pedro6 » Saturday 15 September 2018 22:06
If the website is not certified with the SSL certificate oriented, then, your Website is not secured, it has become a rule, to certify with the SSL for each and every website from Linksys customer service to use the website with proper safety.
remmynl
Post by remmynl » Saturday 15 September 2018 22:18
No errors in the log, from what I read is that when I point to my local lan ip:443 it should give me standard a exception question to add the standard domoticz certificate, however with a clean install I don't get this, just an empty response, also did a source build which gave me the same issue.
jvdz
Post by jvdz » Sunday 16 September 2018 8:18
There should be some information in the log file at startup time indicating the webserver has started and it's ports.
Jos
remmynl
Post by remmynl » Sunday 16 September 2018 8:34
The standard messages that webserver has started both http 8080 is running and 443 is running. No errors in log.
Also confirmed ports are open / listening with netstat. 8080 no problem, 443 port is open but gives empty response, not a refused msg something is not there.
Again this is on a clean stretch lite image with domoticz, I think this is standard behaviour. Even without my own certs I should be given a msg to add an unsafe domoticz certificate as an exception to the browser and be able to access https page.
Can anyone confirm https is not reachable using latest stretch + domoticz clean install?
Users browsing this forum: hsluis, remko2000 and 3 guests
