use tablet camera as motion detection
underscore4
Target OS: Raspberry Pi
Post by underscore4 » Saturday 15 September 2018 11:10
i'm going to install a door sersor detection and my idea would have a wall tablet camera to take a pitcure and send mail if door opened.Anyone has coded this feature with script or using apk solutions on domoticz?
Thanks in advance.
ben53252642
Re: use tablet camera as motion detection
Post by ben53252642 » Saturday 15 September 2018 11:17
underscore4, I'm not aware of any pre-built solutions however I'd suggest looking at an Android App called Tasker.
I used it successfully to turn Android tablet screens on / off when a motion sensor is activated, it can do many different things.
underscore4
Post by underscore4 » Saturday 15 September 2018 11:25
Nice, thanks a lot.
I will test it. would be also visible in Domoticz with any way?
ben53252642
Post by ben53252642 » Saturday 15 September 2018 12:07
Use a second App (for Tasker) called Autoremote to trigger it remotely from Domoticz using a script
I was also able to send text from Domoticz to the tablet and have it speak it out loud.
You will need to do some research and a small amount of coding (mostly copy and paste) to achieve what you want but it is do-able.
https://www.youtube.com/watch?v=ro_dFnrEAUY
Here is a sample bash script I use to send messages to Autoremote
#!/bin/bash
message=$(echo "message to send goes here" | sed 's/ /%20/g')
curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key=THEAUTOREMOTEKEYGOESHERE&message=${message}"
As I said what you want to do is achievable but this goes into moderate to advanced scripting level.
markk
Post by markk » Monday 17 September 2018 13:58
Thanks in advance.
I do something similar very easily.
Use this method viewtopic.php?t=17659#p135550 to turn your tablet camera into an IP camera and add it to Domoticz then use the Domoticz notification function or a simple blockly to send you a snapshot when the door sensor is triggered.
roxanekozo
Post by roxanekozo » Tuesday 18 September 2018 14:14
The nature of induct and conduct is improved for the humans. The charges and rushmyessay have been mild for the use of the movement for the humans in life.
